DELOBJ 0 value is not working ?
I set DELOBJ to 0 and applied region on already regioned object but I see no copy of original object. where is the problem ?
Valentin_CAD
@Anonymous ,
Note: If the SURFACEASSOCIATIVITY system variable is set to 1, the DELOBJ setting is ignored.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2020/ENU/AutoC...
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
