Delete faces error
Delete faces error
jason_vardy
Observer Observer
Message 1 of 12
Delete faces error
jason_vardy
Observer
Observer
Hi
I am getting an error when I try and delete a face from a 3D object.  I have tried on multiple objects, even a simple box.
The message returned in Modelling operation error: Error code number 103013.
Can anyone assist in solving this?
Many thanks
Replies (11)
Message 2 of 12
imadHabash
Would you try:
  • Move the 3d object near to 0,0,0 then try again, any changes?
  • Scale down the 3d object size then try again, any changes?
Imad Habash
Message 3 of 12
j.palmeL29YX
Show us examples what you have and want to get.
The result of such an operation must be an intact solid as you can see here:
(view in My Videos)
What should be the result if you delete a face of "a simple box"?
Jürgen Palme
Message 4 of 12
jason_vardy
Observer
Observer
I am trying to remove the top face to create an open tank as closed roof tank.  I am using the delete faces command/button under solid edit.  I select the face as below hit enter and then I get the error message referenced above.
Message 5 of 12
jason_vardy
Observer
Observer
It is already on the origin.  I have tried drawing a completely new object and no luck. I have tried closing and reopening the file, shutting down. None of those tricks have worked.
Message 6 of 12
j.palmeL29YX
I think your problem has nothing to do with the origin. You simply use the wrong commands.
Unfortunately I do not know what is (or how looks) "an open tank as closed roof tank", but here an example (without exact dimensions) how you can model similar geometry:
(view in My Videos)
We can help better if you tell us more detailed what you want to achieve
Jürgen Palme
Message 7 of 12
willard_oliver
I am having the same issue as the OP.
Description:
Box with no top.
  1. Create 6x6x6 box
  2. Create a shell using SOLIDEDIT with an offset of .25
  3. I should be able to delete the face thus making a box with no top. (this is as I see it, there is always multiple ways to do things)
When I do this I get an error message:
Modeling Operation Error:
Error Code Number is 103013
No other explanation
Message 8 of 12
j.palmeL29YX
Post your dwg file please.
Which Version do you use? (screenshot of the about command).
Jürgen Palme
Message 9 of 12
te240112824
Community Visitor
Community Visitor
I have the same Error code, I am trying to delete a face of any 3D object, I am using Solidedit/Faces/Delete and shows the error code 103013, and when selecting with Ctrl + Delete, does not work either. Already tried to close the program, restart pc and restore defaults of Autocad and still got the error code, I am using Autocad 2026
Message 10 of 12
j.palmeL29YX
The result after deleting a face of a solid must be a valid solid. If you have e.g. a box (6 faces) and want to delete one of the faces, the result can not be a solid, you will get the error code 103013. See also post #3 above.
Post your file please and tell us what you want to achieve, then we can try to help you.
Jürgen Palme
Message 11 of 12
imadHabash
I suggest to read carefully the following hints and matched to your situation:
  • According to Autodesk docs, to use SOLIDEDIT → Faces → Delete, the face must be bounded by faces that lie on the adjacent planes. If deleting it would leave a gap or malformed solid, AutoCAD blocks it. >> Click <<
  • AutoCAD will “heal” adjacent faces when you delete one, but only if it can maintain a valid solid. If the healing fails, the deletion is denied.
  • If the object is degenerate or already has flawed geometry or faces that aren’t properly joined, the command may fail.
  • Sometimes a face deletion is better done in a surface modeling environment rather than on a solid, depending on what you want (open shell or surface body). Some commands are disabled for solids when they would break the “watertight” requirement.
  • Some faces are integral to the solid’s definition; deleting them would require leaving an open solid or invalid geometry, so AutoCAD disallows it.
Imad Habash
Message 12 of 12
j.palmeL29YX
@te240112824
If you want to achieve what I think (guessing) you want to get, here you see one of the possible ways:
(view in My Videos)
The other way may be to create a surface model (instead of a 3DSolid)...
Jürgen Palme
