I read all solutions in here. All of them says open noun/verb selection part but mine is already choosen. It still doesn't work. Please help me.
Im using autocad 2020 student version and before this problem it was working perfectly.
Can you please provide more detail than it isnt working? What doesnt work? Does it give any error message? What displays if you type PICKFIRST at the commandline?
Christopher T. Cowgill, P.E.
Civil 3D Certified Professional
Civil 3D 2022 on Windows 10
Are you using a specialized laptop keyboard where the Function (Fn) key needs to be depressed to activate the Delete key? Does the Delete key work as expected in other programs?
Firstly I checked so many times this pickfirst. It is 1. And this delete button is not working only in the drawing. For ex when ı want to delete layer it is working but on line or rectangle whatever it is not deleting.
Also ı checked maybe because of fn button but it is not. delete or other working on any other programs so it is normal settings for fn
what does the command line show when you try to use the delete button? Does the item stay selected? What happens if while selected you hit E <enter>
