Define distance between columns and rows using the Array command
Davidhova
Observer Observer
Davidhova
Observer
Observer
I would like to define the distance between two rectangles within the array command. AutoCAD only lets you define 1 basepoint and change the distance between those basepoints. Is there a way to specify two point and change the distance between them. See image for clarity.
 Thanks in advance.
imadHabash
You can only redefine base point of the array by Arrayedit command ( Base point ) .. would you clarify more your need ?
Imad Habash
Davidhova
Observer
Observer
Would like to specify the gap between two rectangles. Not between 2 basepoints. Is that possible?
imadHabash
Nope ..
Imad Habash
Davidhova
Observer
Observer
Unfortunately. Thanks anyway.
