Hi all,
Having an issue with the 'Create Date' Field in AutoCAD 2019. I'm posting this on April 2, 2021, and I have three drawings open, all of which are saying different date. One drawing is saying March 31, 2021, one is saying April 1, 2021, and one is saying April 2, 2021 (the correct date). When I go to create a new field, the prompt is for the correct date, but after placing the field, it seems to reset to an incorrect date.
Solved by vladimir_michl. Go to Solution.
Solved by ChicagoLooper. Go to Solution.
The 'Create Date' is too general. What exactly does 'create' mean? Think about it. If you start a new drawing from scratch is the current date the 'create' date? If you later revise that drawing 24-hours later then 'save that revision' over writing the original, is the revision considered a new creation? Or the is original date still the 'create date' even though the original drawing isn't the same drawing as the revised drawing? Yeah, they're 'different' dates because one is pre-revision and the other is post-revision.
It's ambiguous to what create means. When the drawing was first started is definitely a creation. When you revised the drawing, is that not a creation? Afterall, didn't you just create a 'revision?'
Instead of using 'Create Date' use another date field such as Save Date field. See image below.
When you revise or update a drawing, the former date is replaced with the 'save date' and that makes more sense.
Chicagolooper
This is as designed. The field dialog just show examples of the result. The real "creation date" of a DWG file is fixed in the history - it is a date it was created (not updated as you probably expect).
Vladimir Michl, www.cadforum.cz - www.arkance-systems.cz
