data extraction template
11:00 AM
as far as I see from experimenting with data extraction, the data extraction template is always binded to a single file. For example, if I create my template in a certain drawing, but want to extract data in accordance with that template on a different drawing, I need to "save as" the current drawing into the drawing where I defined the data extraction template.
Is a way to create a general template which will work on any file except writing Lisp code which will do that? Thanks in advance for any replies.
Link copied
