Data Extraction (more than 65536 rows in XLS)
j_masenaW7VJQ
Message 1 of 9
j_masenaW7VJQ
Hello everyone,
I have an issue with DataExtraction and the limit of rows extracted (65536 rows), I am extracting different properties for a set of drawings and in some cases this limit force me to some errors or information not extracted.
I would like to know if it possible to increase the amount of lines in XLS, via variable or LSP.
Replies (8)
Message 2 of 9
cadffm
>>"DataExtraction and the limit of rows extracted (65536 rows),"
Dataextraction use the .xls format and microsofts .xls format is limited to 65536 Rows, right.
>>"I would like to know if it possible to increase the amount of lines in XLS, via variable or LSP."
No, it is a limitation of the (old) Excel file format .xls
Workaround1
Export less files in one step
Workaround2 (prefered)
    - use another 3rd party tool to export +whatever you need+ to *.xlsx format
Sebastian
Message 3 of 9
j_masenaW7VJQ
Thanks for your response, how can I extract the data in XLSX format? it is not an option in AutiCad 2024.
Message 4 of 9
j_masenaW7VJQ
Message 5 of 9
cadffm
Workaround1
>>"I am extracting different properties for a set of drawings"
What do you extract?
Which data, objecttypes properties.. tell us more about.
Sebastian
Message 6 of 9
j_masenaW7VJQ
I am extracting different properties (Name, Length, Color, File Name, Layer, Linetype, Unit Factor, Visibility1, Area, Distance1 & Scale1) to use them in excel and quantify different components.
Message 7 of 9
cadffm
Okay,
so why not export to .csv or .txt
and open the file in your Excel (and save to .xlsx then).
untested! IF it is still limited to  65536, it is a limitation inside dataextract function.
But test it first!
Sebastian
Message 8 of 9
j_masenaW7VJQ
I will try, will this avoid the limit of rows extracted (65536 rows)?
Message 9 of 9
cadffm
stop talking and writing (no offense)
TEST IT
and then, we know it
because the ascii/txt format is NOT limited to 65536
Sebastian
