Data Extraction Error
Autocad 2016 SP1
Using the Data Extraction Wizard I am experiencing an error while selecting blocks in my file. Steps:
In a saved file:
-‘DATAEXTRACTION’
-‘Create a new data extraction’
  -Data Source: ‘Select Objects in the current drawing’
   -after selecting the blocks that I want to be included in the selection and pressing enter, a window pops up asking “Do you want to quit the Data Extraction Wizard?”
    -Click No, data extraction wizard still closes
I have several data extractions in a file that display attributes from different instances of the same block. I need to update the extraction to include changes that were made to some of the blocks.
What I have tried:
-Reset my settings to default
-Create new data extractions instead of updating the existing
-Start new file, try to extract a different block
Data extraction works if the data source is set to “Drawings/Sheet set (Include current drawing)”.
Sofia.Xanthopoulou
Hi josh.harmon,
and welcome to the community Smiley Happy
I have followed your steps, but couldn't recreate the described outcome. Command works perfectly fine.
Can you please send me a screencast, showing exactly what you are doing. Maybe I missed something...
Thank you
TheCADnoob
I have had issues with data extraction when there was junk in the files. Have you run AUDIT?
CADnoob
Sofia.Xanthopoulou
Hi @Anonymous,
just checking how things are evolving here. Can you please give us an update on the situation? Did it work finally or do you still need assistance?
If so, please provide us more information.
If not, please share your experience here with all readers.
Thank you
I received your message, thank you. I don't know if it is a coincidence or not, but as soon as I downloaded the Screencast Recorder I could not recreate the problem. Thank you for your help, sometimes things just fix themselves.
Josh Harmon
Field Engineer - Main Span
Tappan Zee Constructors, LLC
Josh.Harmon@tzc-llc.com
O +1.914.789.3409
M +1.914.351.6000
555 White Plains Road, Suite 400, Tarrytown, NY 10591
http://www.tappanzeeconstructors.com/
[cid:image003.jpg@01CECF03.823F2170]
Please visit our equipment sales website at www.tappanzeesales.com
----------------------------------- The information transmitted is intended only for the person or entity to which it is addressed and may contain proprietary, business-confidential and/or privileged material. If you are not the intended recipient of this message you are hereby notified that any use, review, retransmission, dissemination, distribution, reproduction or any action taken in reliance upon this message is prohibited. If you received this in error, please contact the sender and delete the material from any computer. Any views expressed in this message are those of the individual sender and may not necessarily reflect the views of the company. ------------------------------------------------------------
