Message 1 of 16
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When I import a annotative dimension style using express > dimension > DimStyle import it corrupts everything, from the name to the values
Doesn't matter if I export Text Style Name Only or if I export Full Text Style Information
Also, doesn't matter if I import overwriting or not the existent styles
The damaged dimension style has a weird name, like 000000001A3F4D5B
The damaged dimension style loses the annotative feature
Even after modifying the imported damaged style, like making text annotative, or marking Annotative on the "adjust" tab, the text doesn't appear (probably something I can't see has changed)
AutoCad 2014
