Cutting a path into a cylinder.
I am trying to make a enclosure for a lead screw that will allow the nut (having an arm attached to it at a 90* angle form the lead screw) to be lead a specific path around the cylinder.
More simply, i need to find a way to cut a path into the side of a cylinder. I have tried creating a grid along the side and then using a spline to draw the path but this failed when i tried to presspull the area (which is closed), Which is probably an indication that i am trying to do the impossible but I thought i would ask the community before i try and think of an alternative.
I have attached a screenshot of where i am at the moment which should hopefully stop any confusion.
Any advise would be greatly appreciated. 🙂
Kent1Cooper
Welcome to these Forums!
If your path will be regular in its curvature around the cylinder, you can use a HELIX as a path to SWEEP the cross-sectional shape of the groove along, and then SUBTRACT the result of the Sweep from the cylinder.  Here I used a small Circle to Sweep along the Helix [left part], but you can use a different shape, and "dug" it out of the surface of the cylinder by Subtracting [right part].  Your proportions, Helix characteristics, groove cross section, etc., would be different, but the concept should be the same.
Kent Cooper, AIA
Thank you for the quick reply!
I did look into using HELIX tool but unfortunately the path isn't regular. It needs to go vertically for X then curve gradually towards the top at an angle of around 45*.
I'm currently trying to create the desired path with a spline, use sweep to turn it into a cylinder and then subtract the path from the enclosure as you suggested with HILIX.
But i'm struggling to create a spline that increases in hight and also curves with the cylinder. Do you have any suggestions?
Kent1Cooper
@Anonymous wrote:
.... unfortunately the path isn't regular. It needs to go vertically for X then curve gradually towards the top at an angle of around 45*.
I had what looks like some degree of success by making a grid of stacked Circles and vertical Lines, spaced so the grid spaces look close to square [you can refine the idea for any required degree of accuracy], and drawing a Spline Osnapping to intersections [left image].  In this case, I started at the bottom, went up 3 and over 1 twice, then up 2 and over 2, then repeatedly up 1 and over 1 to the top.  I Extruded the next-to-bottom Circle to make a cylinder up to the next-to-top Circle level, so the Spline extends beyond the ends of the cylinder, and used SWEEP with [again] a small Circle along the Spline [middle image], and SUBTRACT to take the groove out of the cylinder surface [right image].
All the qualifications from before [shape of groove cross-section, etc.] apply here as well.
Kent Cooper, AIA
Briliant! I wasn't too far off with my first attempt...
Thank you for your help!
