- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I am trying to use a custom tick at the ends of my dimensions. Choosing the blocks is simple, and it basically works the way I want. But when using the custom block, a gap is added to the end of the dimension line. I want to eliminate this gap so that it looks like a normal, out of the box dimension. According to the software documentation:
Arrowhead sizing relies on the overall dimension scale factor. When you create a dimension, the block is inserted where the arrowheads would normally go. The object's X and Y scale factors are set to arrowhead size overall scale. The dimension line is trimmed by text gap x overall scale units at each end. To trim the dimension line, the rightmost block is inserted with a zero rotation angle for horizontal dimensioning. The leftmost block is rotated 180 degrees about its insertion point."
I have bolded the one line for clarity, and I think this loosely addresses the why. But what it doesn't clarify is how to adjust this variable. I am sure it is something obvious I am missing, but does anyone have any insight?
