Custom shaped Viewports
I have been away from current versions of Autocad for a while... I am finally back to using a fairly newer version 2013lt. In previous versions I was able to create a custom shaped viewport, and for some reason now I either cant do it or cant find the tab that creates a poly viewport. Any advice is appreciated. Thanks in advance!!!
Patchy
Try MVIEW, Polygonal.
Thank you! It worked. Do you know if there is a little icon you can click? It used to have one that would create a rec viewport and a poly viewport...
Patchy
Someone else would definitely knows, me, i'm stuck with older autocad.
I feel your pain. I just came from 98lt. Good Luck and thank you again.
