Custom Linetypes in Autocad 2023
lbellino4
lbellino4
Hello. I need to add a couple of custom line types that I normally use in my drawing files into the new AutoCAD 2023 version that I just downloaded.  In the 2022 version, there was an "ACAD" line type definition file in the "support" folder where I would add these custom line types to. But in this new 2023 version, there isn't one. Where is this line type definition file located at? Or if there isn't one, where and how would I add my custom line types to so I can use them in my drawings? Thanks in advance for the help.
cadffm
same please in 2023.
If you want to use your own .lin files, use your own supportpath,
if you want to add linetype definition to the standard file:
imperial definitions, command: (findfile "acad.lin")
metric definitions, command: (findfile "acadiso.lin")
Sebastian
WeTanks
AutoCAD2022 and  AutoCAD2023 are the same.
acadiso_center_512.lin  is made by myself.
We.Tanks
A couple of Fusion improvement ideas that could your vote/support:
図面一括印刷
lbellino4
For some reason, when ACAD 2023 installed on the computer, it didn't have these files in the "support" folder. So I uninstalled and reinstalled the program and now they are there. Thanks for the help.
