Custom keyboard shortcuts
Hello everyone,
I want to assign a keyboard shortcut for "Zoom extends" command for CTRL+E , how could I do so.
Thanks in advance.
Eyal
imadHabash
Ctrl+E in autocad is already exist for Toggle coordinate display  . But you can make your own from Customize User Interface (CUI) Editor . >> Click <<
Imad Habash
ВeekeeCZ
It's not really an issue that it already exists. The CUI marks the old-one with red cross and you can un-assign it easily manually.
Thank you @imadHabash, but I can't find the "Toggle coordinate display", I want to change the shortcut to be for Zoom extends.
As you can see in the photo, there is no shortcut CTRL+E , where can I find it, so I could change it.
I realized that it can be changed but how exactly.
ВeekeeCZ
Don't worry about it. Default setting for CTRL+E (Cycles through isometric planes in the fact) is not listened, so if you set the new shortcut it replaces the old one automatically - you'll get a green tick.
See the SCREENCAST
Thank you @ВeekeeCZ , it works perfectly!
