Hello, I have been using custom hatches for years including on this version of AutoCAD. I had to redownload AutoCAD a few months back and when I went to add custom hatches "Support File Search Paths" The folder can be added but it shows as empty. These patterns work on other people's computers but not mine. Note I am running windows on a MAC, but it was working fine and the files are saved in the windows side too.
Solved by paullimapa. Go to Solution.
Restart your CAD application to ensure the new path is recognized.
Imad Habash
Click on the links and try these suggestions:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
As a test copy your custom •.pat files into the same location as acad.pat.
The default location for the acad.pat file is:
Glad to have helped...but make sure you keep a copy of all your custom files like *.pat so that when you install the next version of AutoCAD you'll have them to copy over...until you can resolve the problem with AutoCAD not seeing another folder location outside of its folder structure...cheers!!!
