Custom Hatch Pattern: missing parameter?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello everyone. First of all: I'm working on AutoCad 2019 on a late-2013 MacBook Pro, if this can help.
I'm working on an architectural drawing which includes many brick walls, and I'd like to create a custom Hatch Pattern. I got it to work with SuperHatch, but I also need to explode the pattern in some points so that's not the best solution.
I therefore added a custom line of text in the dedicated section of the acadiso.pat file found in the Support Files folder of Autocad 2019 (see picture #1). I can see the pattern in the Hatch window of Autocad, but as I try to insert it, I get an error message in the Command Line informing me that there is a "missing parameter in line 421" (see picture #2).
Line 421 is of course one of the lines I added (I can't know which one since MacOS's text editor doesn't have a row count function)
Do you see anything wrong in the lines of text I added?
Thanks to everyone in advance!!
