AutoCAD Forum
Custom Hatch isn't working in 2025 AutoCAD
15 REPLIES 15
Message 1 of 16
bigboyitm
1051 Views, 15 Replies
I installed AutoCAD 2025 and made sure I mapped all of the files that I was using in AutoCAD 2023. I have a hatch pattern that I am using on a job and it will show up in the 2023 version but is missing in the 2025 version. I can see the file in my support file list in the options box. When I open the hatch and gradient menu I can see the pattern in the cutom list and I can select it, but I cannot click OK to use the pattern and the drawing will not display the pattern when opened up.
15 REPLIES 15
Message 2 of 16
pendean
in reply to: bigboyitm
Share your custom hatch in a PAT file here please for others with AutoCAD2025 to test, PLUS the DWG file portion where you inserted into please.
Message 3 of 16
bigboyitm
The hatch should be showing in the area that is shaded with the yellowish brown.
Like I said it displays in my 2023 version just fine, but does not work in 2025. I installed 2025 two days ago.
*CORONADOSTRIPSTONE
; Pattern written by HatchKit v2.7 Hatch Pattern Editor
; HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2008.
; www.cadro.com.au/hatchkit/
;-Template=CORONADO STRIP STONE
;-Source =C:\Users\matthewp.CORONADO...es\Canyon Ledge\Canyonledge_Grouted3.dxf
;-Date =6/29/2015
;-Time =3:21:32 PM
;-HatchKitVersion=2.7.1.1995
;-HatchKitLicensedToName=Brian Coulter
;-HatchKitLicensedToOrganization=
;-HatchKitSerialNumber=SW660933201
;-OSRegisteredOwner=Matthewp
;-OSRegisteredOrganization=
-178.069525936,6,3.9915,354.224352877,0.067377512314,0.072415,-534.262589837
-177.709524436,1.939,1.8522,144.133297548,0.xxx-xxxxxxxx,0.061083,-150.067777183
-177.709524436,1.939,5.4078,144.133297548,0.xxx-xxxxxxxx,0.061083,-150.067777183
-177.709524436,5.8974,1.1439,144.133297548,0.xxx-xxxxxxxx,0.061083,-150.067777183
-177.709524436,5.8974,4.6994,144.133297548,0.xxx-xxxxxxxx,0.061083,-150.067777183
-176.423875265,3.826,3.289,90.2043393072,0.374270049333,0.04659,-96.1464220575
-174.289740262,0.9315,3.934,54.3322210177,0.xxx-xxxxxxxx,0.05806,-60.2447424677
-173.991344615,1.859,2.921,54.3345934635,0.314054762926,0.05553,-114.581048133
-172.056989077,2.0088,1.8619,42.4286535124,0.138196278156,0.070429,-260.4442813
-172.056989077,5.9671,4.7091,42.4286535124,0.138196278156,0.070429,-260.4442813
-172.056989077,2.0088,5.4175,42.4286535124,0.138196278156,0.070429,-260.4442813
-172.056989077,5.9671,1.1536,42.4286535124,0.138196278156,0.070429,-260.4442813
-171.703335874,1.71,3.648,248.634631632,0.123691855582,0.03525,-291.028079909
-171.57351913,3.179,0.5068,121.349346339,0.219823414051,0.02938,-163.748275459
-170.910248405,2.754,4.734,36.4979169634,0.236986255588,0.03693,-151.879742462
-170.910248405,2.754,1.179,36.4979169634,0.236986255588,0.03693,-151.879742462
-170.538223847,1.4582,5.748,30.5799616518,0.986396141073,0.035354,-36.4633323483
-170.538223847,1.458,2.192,30.5799616518,0.986396141073,0.03535,-36.4633363483
-170.074326268,1.883,1.565,103.581925723,0.147754925541,0.02951,-243.631831485
-170.074326268,1.883,5.12,103.581925723,0.147754925541,0.02951,-243.631831485
-168.690715092,1.0953,2.625,24.7120192232,1.xxx-xxxxxxxx,0.029643,-30.5662232563
-168.690715092,4.9667,2.6481,24.7120192232,1.xxx-xxxxxxxx,0.02964,-30.5662262563
-168.690715092,4.9667,4.4259,24.7120192232,1.xxx-xxxxxxxx,0.029642,-30.5662242563
-168.690715092,4.9667,0.20369,24.7120192232,1.xxx-xxxxxxxx,0.02964,-30.5662262563
-168.690715092,1.095,0.1806,24.7120192232,1.xxx-xxxxxxxx,0.02964,-30.5662262563
-168.690715092,1.0953,4.4028,24.7120192232,1.xxx-xxxxxxxx,0.029643,-30.5662232563
-167.66161569,1.8543,1.5597,55.3200982344,0.183169365642,0.0119,-196.539325922
-167.66161569,1.854,5.115,55.3200982344,0.183169365642,0.0119,-196.539325922
-167.471905376,6,4.7164,24.7314574023,0.650793602475,0.033678,-55.286723478
-167.471905376,6,1.1609,24.7314574023,0.650793602475,0.033678,-55.286723478
-166.760230838,1.0138,3.2662,24.7376329483,0.343560286344,0.04256,-104.748839936
-166.760230838,3.5,3.974,24.7376329483,0.343560286344,0.04256,-104.748839936
-165.964548849,4.9377,0.19789,18.9187974619,1.xxx-xxxxxxxx,0.011981,-24.728037544
-165.964548849,4.9377,2.6423,18.9187974619,1.xxx-xxxxxxxx,0.011981,-24.728037544
-165.964548849,4.9377,4.4201,18.9187974619,1.xxx-xxxxxxxx,0.011982,-24.728036544
-163.30168256,1.313,5.431,18.9659769859,0.574698938865,0.03035,-62.6149081231
-163.30168256,1.3129,1.8757,18.9659769859,0.574698938865,0.03035,-62.6149081231
-163.30168256,0.3407,1.195,18.9659769859,0.574698938865,0.03035,-62.6149081231
-163.30168256,0.3407,4.751,18.9659769859,0.574698938865,0.03035,-62.6149081231
-161.566061384,3.7885,3.6414,13.2822105817,1.xxx-xxxxxxxx,0.032576,-18.9421061291
-161.030627397,2.718,4.728,184.064043922,0.177317455547,0.04497,-202.992927522
-161.030627397,2.718,1.173,184.064043922,0.177317455547,0.04497,-202.992927522
-160.347242526,1.423,5.742,70.2307316375,0.403606625792,0.04321,-89.1579107635
-160.347242526,1.4233,2.1867,70.2307316375,0.403606625792,0.04321,-89.1579107635
-159.445061858,4.796,4.7478,32.3050153372,0.702252434497,0.02483,-51.2418678421
-159.445061858,4.796,1.1922,32.3050153372,0.702252434497,0.02483,-51.2418678421
-159.445061858,5.1988,5.4283,32.3050153372,0.702252434497,0.02483,-51.2418678421
-159.445061858,5.1988,1.8728,32.3050153372,0.702252434497,0.02483,-51.2418678421
-157.752156411,0.9741,3.952,110.313985284,0.252424190379,0.04598,-142.579666592
-156.802628706,1.8995,2.938,13.3938964908,0.787846301414,0.044271,-45.6526667195
-156.371858811,1.675,3.643,59.0950873955,0.343562470959,0.03171,-104.759023597
-154.29136242,5.8305,1.1074,13.4155534725,0.200224939851,0.038798,-179.769788258
-154.29136242,5.8305,4.663,13.4155534725,0.200224939851,0.038801,-179.769785258
-154.29136242,1.8722,5.3713,13.4155534725,0.200224939851,0.038801,-179.769785258
-154.29136242,1.8722,1.8157,13.4155534725,0.200224939851,0.038798,-179.769788258
-153.436295773,4.7115,5.4032,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.019489,-13.3975585515
-153.436295773,4.7115,1.8477,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.019495,-13.3975525515
-153.436295773,5.212,0.8477,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.01949,-13.3975575515
-152.526946709,2.335,0.8477,155.660609301,0.212934836303,0.01892,-169.057047058
-150.256569269,3.7797,3.2857,34.9793303097,0.7442196645,0.023431,-48.3522906929
-144.783993522,3.434,3.899,51.6151889699,0.288347424625,0.02954,-124.827352393
-144.783993522,0.9482,3.191,51.6151889699,0.288347424625,0.02955,-124.827342393
-141.341834387,2.6752,4.7138,8.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.02332,-38.3968276336
-141.341834387,2.675,1.158,8.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.02331,-38.3968376336
-140.196085015,1.383,2.172,8.xxx-xxxxxxxx,0.768240290123,0.02269,-46.8404644467
-140.196085015,1.383,5.728,8.xxx-xxxxxxxx,0.768240290123,0.0227,-46.8404544467
-135.318231662,3.15,0.5025,8.4854068295,0.0468806854118,0.02452,-767.928487768
-134.42295781,1.646,3.63,411.570123244,0.0857081666368,0.02492,-420.030306718
-131.635211448,1.336,5.457,63.7805960767,0.498289566725,0.03499,-72.2164994398
-131.635211448,0.3639,4.777,63.7805960767,0.498289566725,0.03499,-72.2164994398
-131.635211448,0.3639,1.221,63.7805960767,0.498289566725,0.03499,-72.2164994398
-131.635211448,1.3361,1.9018,63.7805960767,0.498289566725,0.03499,-72.2164994398
-131.18759399,3.5761,6,55.315800442,0.564451681515,0.021528,-63.7610145049
-130.602958562,3.759,3.274,46.8581384088,0.650813851806,0.0268,-55.2918802467
-128.661450916,4.694,5.3945,29.9860160949,0.937076770012,0.01861,-38.4010419649
-128.661450916,4.694,1.8389,29.9860160949,0.937076770012,0.018605,-38.4010469649
-128.661450916,5.194,0.8389,29.9860160949,0.937076770012,0.0186,-38.4010519649
-127.570219426,2.318,0.8389,29.9984238762,0.xxx-xxxxxxxx,0.01834,-98.3911918669
-126.871514028,1.0662,4.397,21.6004035753,1.xxx-xxxxxxxx,0.029064,-29.9715905614
-126.871514028,1.0662,2.6192,21.6004035753,1.xxx-xxxxxxxx,0.029064,-29.9715905614
-126.871514028,1.066,0.1748,21.6004035753,1.xxx-xxxxxxxx,0.02906,-29.9715945614
-121.330188494,0.9241,3.174,34.9855690528,0.222844108832,0.03984,-161.517777821
-121.330188494,3.41,3.882,34.9855690528,0.222844108832,0.03984,-161.517777821
-120.965242186,0.2779,3.961,13.3770532204,1.xxx-xxxxxxxx,0.0237,-34.9625787596
-119.746331906,1.843,5.113,13.3959162934,0.744241871244,0.01756,-48.3567182545
-119.746331906,1.843,1.557,13.3959162934,0.744241871244,0.01756,-48.3567182545
-119.746331906,1.234,2.947,13.3959162934,0.744241871244,0.02343,-48.3508482545
-118.611875298,3.458,3.965,13.4080255394,0.xxx-xxxxxxxx,0.03601,-75.1448373142
-118.611875298,0.9724,3.256,13.4080255394,0.xxx-xxxxxxxx,0.03601,-75.1448373142
-118.444338902,3.758,3.631,88.5898943859,0.xxx-xxxxxxxx,0.02602,-163.744400297
-116.566398175,4.926,0.195,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.0195,-13.3970744251
-116.566398175,4.9261,2.6394,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.019501,-13.3970734251
-116.566398175,4.9261,4.4172,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.019495,-13.3970794251
-114.624840281,5.675,0.3877,72.4986970551,0.227277394035,0.03727,-158.368996145
-112.167522468,0.3968,1.398,32.3106166341,0.xxx-xxxxxxxx,0.04117,-174.888965822
-112.167522468,0.39684,4.954,32.3106166341,0.xxx-xxxxxxxx,0.041162,-174.888973822
-107.879680507,3.576,4.25,176.466285508,0.184211595332,0.04584,-195.393341249
-107.879680507,3.576,2.472,176.466285508,0.184211595332,0.04585,-195.393331249
-106.700171074,0.3726,1.25,43.677100783,0.574727138443,0.03035,-62.611834369
-106.700171074,1.3448,1.9309,43.677100783,0.574727138443,0.030347,-62.611837369
-106.700171074,0.3726,4.806,43.677100783,0.574727138443,0.03035,-62.611834369
-106.700171074,1.3448,5.4865,43.677100783,0.574727138443,0.030347,-62.611837369
-104.421585355,1.834,1.5419,24.7381784074,0.166036622287,0.023606,-216.809059422
-104.421585355,1.834,5.0975,24.7381784074,0.166036622287,0.023606,-216.809059422
-102.529520832,4.917,0.1775,30.5872831254,0.xxx-xxxxxxxx,0.02679,-55.2906662275
-102.529520832,4.9173,2.622,30.5872831254,0.xxx-xxxxxxxx,0.026787,-55.2906692275
-102.529520832,4.9173,4.3998,30.5872831254,0.xxx-xxxxxxxx,0.026793,-55.2906632275
-101.310580075,3.4412,3.9332,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.034721,-30.559485419
-101.310580075,0.95512,3.2249,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.034714,-30.559492419
-99.6893452198,5.836,1.141,36.496372108,0.144262444496,0.03454,-249.525652149
-99.6893452198,1.878,5.4053,36.496372108,0.144262444496,0.034531,-249.525661149
-99.6893452198,1.878,1.8498,36.496372108,0.144262444496,0.034538,-249.525654149
-99.6893452198,5.8363,4.697,36.496372108,0.144262444496,0.034531,-249.525661149
-98.7466683653,4.6824,5.38,42.4240319783,0.456198044923,0.038226,-78.879611919
-98.7466683653,5.1824,0.8244,42.4240319783,0.456198044923,0.03822,-78.879617919
-98.7466683653,4.6824,1.8244,42.4240319783,0.456198044923,0.03822,-78.879617919
-98.5312596242,4.677,1.787,42.4254472711,0.296698155073,0.05878,-121.283947458
-98.5312596242,5.177,0.7866,42.4254472711,0.296698155073,0.05878,-121.283947458
-98.5312596242,4.677,5.342,42.4254472711,0.296698155073,0.05878,-121.283947458
-98.4274572004,2.3069,0.8244,42.425915172,0.219835779107,0.038187,-163.730256492
-98.2976258412,2.301,0.7866,42.4263043942,0.123698822723,0.05874,-290.988196225
-97.7656168441,1.219,2.662,90.7962266282,0.270242180152,0.0302,-133.191650667
-96.84317178,1.837,5.354,102.70333028,0.238304404974,0.04896,-151.027405425
-96.84317178,5.796,1.09,102.70333028,0.238304404974,0.04896,-151.027405425
-96.84317178,1.837,1.799,102.70333028,0.238304404974,0.04896,-151.027405425
-96.84317178,5.796,4.646,102.70333028,0.238304404974,0.04896,-151.027405425
-95.7109265566,3.407,3.717,5.xxx-xxxxxxxx,0.597057450135,0.0342,-60.2651285824
-95.7109265566,0.9206,3.0085,5.xxx-xxxxxxxx,0.597057450135,0.03421,-60.2651185824
-95.4406498656,3.742,3.254,66.2716313077,0.284444032274,0.06131,-126.508978996
-95.3896266492,0.9033,3.14,192.842097143,0.112713753715,0.03662,-319.375715953
-95.3896266492,3.389,3.848,192.842097143,0.112713753715,0.03662,-319.375715953
-94.8442837243,1.828,1.331,72.2495733366,0.101337672106,0.06888,-355.200415417
-94.8442837243,1.828,4.887,72.2495733366,0.101337672106,0.06888,-355.200415417
-94.7639203831,0.3755,1.285,5.xxx-xxxxxxxx,0.498302291516,0.03499,-72.214654405
-94.7639203831,1.3478,1.9658,5.xxx-xxxxxxxx,0.498302291516,0.034992,-72.214652405
-94.7639203831,1.3478,5.5213,5.xxx-xxxxxxxx,0.498302291516,0.034999,-72.214645405
-94.7639203831,0.3755,4.841,5.xxx-xxxxxxxx,0.498302291516,0.035,-72.214644405
-93.5765440269,1.6221,3.3424,5.xxx-xxxxxxxx,0.3742918757,0.0466,-96.140802681
-93.5216598279,2.657,4.67,294.550749493,0.0921388588087,0.04951,-390.688598044
-93.5216598279,2.657,1.115,294.550749493,0.0921388588087,0.04949,-390.688618044
-93.3666580706,1.365,5.684,5.xxx-xxxxxxxx,0.352353000825,0.0495,-102.126906285
-93.3666580706,1.365,2.129,5.xxx-xxxxxxxx,0.352353000825,0.04948,-102.126926285
-92.6027149566,1.628,3.612,5.xxx-xxxxxxxx,0.272462125064,0.06362,-132.072776425
-92.2907445288,1.222,2.735,5.xxx-xxxxxxxx,0.239822460353,0.07272,-150.047345131
-92.2907445288,1.625,3.4151,5.xxx-xxxxxxxx,0.239822460353,0.072717,-150.047348131
-90,4.9115,0.15139,0,6.xxx-xxxxxxxx,0.031982,-5.xxx-xxxxxxxx
-90,1.3884,5.4865,0,6.xxx-xxxxxxxx,0.031976,-5.xxx-xxxxxxxx
-90,2.657,1.01,0,6.xxx-xxxxxxxx,0.049398,-5.xxx-xxxxxxxx
-90,2.6813,0.91701,0,6.xxx-xxxxxxxx,0.031969,-5.xxx-xxxxxxxx
-90,1.3884,1.9309,0,6.xxx-xxxxxxxx,0.031969,-5.xxx-xxxxxxxx
-90,3.5761,4.0607,0,6.xxx-xxxxxxxx,0.037788,-5.xxx-xxxxxxxx
-90,0.39684,1.2332,0,6.xxx-xxxxxxxx,0.033054,-5.xxx-xxxxxxxx
-90,0.38754,1.312,0,6.xxx-xxxxxxxx,0.061008,-5.xxx-xxxxxxxx
-90,3.5676,2.373,0,6.xxx-xxxxxxxx,0.06977,-5.xxx-xxxxxxxx
-90,3.5676,5.9286,0,6.xxx-xxxxxxxx,0.069756,-5.xxx-xxxxxxxx
-90,4.9057,2.3023,0,6.xxx-xxxxxxxx,0.034871,-5.xxx-xxxxxxxx
-90,1.3652,5.5795,0,6.xxx-xxxxxxxx,0.049405,-5.xxx-xxxxxxxx
-90,1.8315,5.3057,0,6.xxx-xxxxxxxx,0.060777,-5.xxx-xxxxxxxx
-90,4.9115,2.5958,0,6.xxx-xxxxxxxx,0.031982,-5.xxx-xxxxxxxx
-90,5.7898,1.0418,0,6.xxx-xxxxxxxx,0.060777,-5.xxx-xxxxxxxx
-90,0.37553,1.3491,0,6.xxx-xxxxxxxx,0.063938,-5.xxx-xxxxxxxx
-90,3.5676,4.1508,0,6.xxx-xxxxxxxx,0.069756,-5.xxx-xxxxxxxx
-90,0.37553,4.9047,0,6.xxx-xxxxxxxx,0.063938,-5.xxx-xxxxxxxx
-90,1.625,3.604,0,6.xxx-xxxxxxxx,0.040683,-5.xxx-xxxxxxxx
-90,2.6813,4.4726,0,6.xxx-xxxxxxxx,0.031976,-5.xxx-xxxxxxxx
-90,1.0487,4.3737,0,6.xxx-xxxxxxxx,0.034878,-5.xxx-xxxxxxxx
-90,2.657,4.5656,0,6.xxx-xxxxxxxx,0.049405,-5.xxx-xxxxxxxx
-90,5.8538,0.91779,0,6.xxx-xxxxxxxx,0.031589,-5.xxx-xxxxxxxx
-90,1.3478,5.5853,0,6.xxx-xxxxxxxx,0.063938,-5.xxx-xxxxxxxx
-90,1.8954,1.6529,0,6.xxx-xxxxxxxx,0.026747,-5.xxx-xxxxxxxx
-90,5.8538,0.94454,0,6.xxx-xxxxxxxx,0.026747,-5.xxx-xxxxxxxx
-90,1.8315,1.7501,0,6.xxx-xxxxxxxx,0.060777,-5.xxx-xxxxxxxx
-90,1.8954,1.6261,0,6.xxx-xxxxxxxx,0.031589,-5.xxx-xxxxxxxx
-90,1.2223,2.9234,0,6.xxx-xxxxxxxx,0.040677,-5.xxx-xxxxxxxx
-90,1.0487,2.596,0,6.xxx-xxxxxxxx,0.034871,-5.xxx-xxxxxxxx
-90,1.3652,2.0239,0,6.xxx-xxxxxxxx,0.049398,-5.xxx-xxxxxxxx
-90,1.3478,2.0297,0,6.xxx-xxxxxxxx,0.063938,-5.xxx-xxxxxxxx
-90,3.5761,2.2829,0,6.xxx-xxxxxxxx,0.037788,-5.xxx-xxxxxxxx
-90,1.3652,5.7132,0,6.xxx-xxxxxxxx,0.029066,-5.xxx-xxxxxxxx
-90,5.6746,0.24089,0,6.xxx-xxxxxxxx,0.029365,-5.xxx-xxxxxxxx
-90,1.8224,1.2623,0,6.xxx-xxxxxxxx,0.030504,-5.xxx-xxxxxxxx
-90,1.8224,4.8179,0,6.xxx-xxxxxxxx,0.030504,-5.xxx-xxxxxxxx
-90,1.3652,2.1576,0,6.xxx-xxxxxxxx,0.02908,-5.xxx-xxxxxxxx
-90,2.657,4.6993,0,6.xxx-xxxxxxxx,0.029066,-5.xxx-xxxxxxxx
-90,1.8954,5.2084,0,6.xxx-xxxxxxxx,0.026747,-5.xxx-xxxxxxxx
-90,5.8538,4.5001,0,6.xxx-xxxxxxxx,0.026747,-5.xxx-xxxxxxxx
-90,3.1321,0.48523,0,6.xxx-xxxxxxxx,0.025865,-5.xxx-xxxxxxxx
-90,2.657,1.1437,0,6.xxx-xxxxxxxx,0.02908,-5.xxx-xxxxxxxx
-90,1.8282,5.0746,0,6.xxx-xxxxxxxx,0.027961,-5.xxx-xxxxxxxx
-90,1.8282,1.5191,0,6.xxx-xxxxxxxx,0.027954,-5.xxx-xxxxxxxx
-90,5.7898,4.5973,0,6.xxx-xxxxxxxx,0.060777,-5.xxx-xxxxxxxx
-90,5.8538,4.4734,0,6.xxx-xxxxxxxx,0.031596,-5.xxx-xxxxxxxx
-90,0.39684,4.7888,0,6.xxx-xxxxxxxx,0.033054,-5.xxx-xxxxxxxx
-90,4.9057,4.0801,0,6.xxx-xxxxxxxx,0.034878,-5.xxx-xxxxxxxx
-90,3.5761,5.8385,0,6.xxx-xxxxxxxx,0.037788,-5.xxx-xxxxxxxx
-90,0.38754,4.8676,0,6.xxx-xxxxxxxx,0.061008,-5.xxx-xxxxxxxx
-90,4.9057,5.8578,0,6.xxx-xxxxxxxx,0.034878,-5.xxx-xxxxxxxx
-90,1.0487,0.15152,0,6.xxx-xxxxxxxx,0.034871,-5.xxx-xxxxxxxx
-90,5.6653,0.3109,0,6.xxx-xxxxxxxx,0.054199,-5.xxx-xxxxxxxx
-90,4.9115,4.3736,0,6.xxx-xxxxxxxx,0.031969,-5.xxx-xxxxxxxx
-90,1.8954,5.1817,0,6.xxx-xxxxxxxx,0.031596,-5.xxx-xxxxxxxx
-87.6139158989,2.293,0.6529,138.130253738,0.249798088462,0.0669,-144.058155519
-87.4737348093,1.625,3.467,270.266730278,0.0881547791622,0.06615,-408.331031757
-87.5103009397,4.668,5.208,132.13613937,0.260638806658,0.06692,-138.063559608
-87.5103009397,5.168,0.6529,132.13613937,0.260638806658,0.0669,-138.063579608
-87.5103009397,4.668,1.653,132.13613937,0.260638806658,0.0669,-138.063579608
-87.3972850434,4.9086,6,126.142581958,0.272462125064,0.06376,-132.072636425
-87.2735290101,1.3448,5.6463,120.149664228,0.xxx-xxxxxxxx,0.061104,-126.08177221
-87.2735290101,0.37263,1.4102,120.149664228,0.xxx-xxxxxxxx,0.061104,-126.08177221
-87.2735290101,0.37263,4.9657,120.149664228,0.xxx-xxxxxxxx,0.061104,-126.08177221
-87.2735290101,1.3448,2.0907,120.149664228,0.xxx-xxxxxxxx,0.061104,-126.08177221
-87.1374268171,0.3697,5.024,114.157486105,0.299643465716,0.0582,-120.091803212
-87.1374268171,0.3697,1.468,114.157486105,0.299643465716,0.0582,-120.091803212
-87.1374268171,1.342,5.704,114.157486105,0.299643465716,0.0582,-120.091803212
-87.1374268171,1.628,3.401,114.157486105,0.299643465716,0.05854,-120.091463212
-87.1374268171,1.342,2.149,114.157486105,0.299643465716,0.0582,-120.091803212
-86.9870357468,1.3623,5.6347,108.166169406,0.315371690241,0.0553,-114.10257936
-86.9870357468,1.362,2.079,108.166169406,0.315371690241,0.05531,-114.10256936
-86.8634576616,2.654,4.621,108.16659802,0.0820735332874,0.05531,-438.60209789
-86.8634576616,2.654,1.065,108.16659802,0.0820735332874,0.05531,-438.60209789
-85.1352010246,1.895,5.15,210.770207802,0.127207251833,0.03415,-282.985590223
-85.1352010246,5.854,0.8862,210.770207802,0.127207251833,0.03417,-282.985570223
-85.1352010246,5.854,4.442,210.770207802,0.127207251833,0.03415,-282.985590223
-85.1352010246,1.895,1.595,210.770207802,0.127207251833,0.03417,-282.985570223
-84.957254091,1.631,3.343,66.2720085681,0.175797988542,0.03318,-204.759626032
-84.986593103,2.296,0.5861,204.792779183,0.104866682478,0.03211,-343.281538506
-84.8052674622,4.671,5.142,60.2968814345,0.543246499977,0.0321,-66.240141735
-84.8052674622,1.365,5.53,60.2968814345,0.543246499977,0.03211,-66.240131735
-84.8052674622,1.365,1.975,60.2968814345,0.543246499977,0.03211,-66.240131735
-84.8052674622,4.671,1.586,60.2968814345,0.543246499977,0.03212,-66.240121735
-84.8052674622,5.171,0.5861,60.2968814345,0.543246499977,0.03212,-66.240121735
-84.6103733508,2.657,0.9606,126.570238809,0.112713753715,0.03213,-319.380205953
-84.5593501344,2.657,4.5162,60.2986576888,0.284444032274,0.032119,-126.538169996
-84.2890734434,0.3668,5.053,54.3291049783,0.597057450135,0.02921,-60.2701185824
-84.2890734434,1.339,5.7335,54.3291049783,0.597057450135,0.029205,-60.2701235824
-84.2890734434,0.3668,1.497,54.3291049783,0.597057450135,0.02921,-60.2701185824
-84.2890734434,1.339,2.1779,54.3291049783,0.597057450135,0.029212,-60.2701165824
-84.1436446221,3.562,2.428,174.928714112,0.153052300587,0.05549,-235.172358455
-84.1436446221,3.5619,4.206,174.928714112,0.153052300587,0.055505,-235.172343455
-84.1436446221,3.562,5.984,174.928714112,0.153052300587,0.0555,-235.172348455
-82.6938157134,0.3813,4.916,187.542237405,0.152606103607,0.04869,-235.86692882
-82.6938157134,0.3813,1.36,187.542237405,0.152606103607,0.04868,-235.86693882
-81.8694261916,5.659,0.3538,36.4867908263,0.848577571375,0.04334,-42.383144723
-81.8694261916,0.8999,3.103,36.4867908263,0.848577571375,0.04911,-42.377374723
-81.8694261916,3.386,3.8117,36.4867908263,0.848577571375,0.049114,-42.377370723
-75.9629641737,4.9057,4.0452,18.9178968854,1.xxx-xxxxxxxx,0.023971,-24.7147645998
-75.9629641737,4.9057,2.2674,18.9178968854,1.xxx-xxxxxxxx,0.023978,-24.7147575998
-75.9629641737,4.9057,5.823,18.9178968854,1.xxx-xxxxxxxx,0.023971,-24.7147645998
-74.0537145656,1.822,1.232,18.9558800036,0.824208710933,0.02115,-43.659731906
-74.0537145656,1.822,4.787,18.9558800036,0.824208710933,0.02115,-43.659731906
-73.2998289261,0.9068,3.055,18.965083586,0.574727138443,0.0482,-62.593984369
-73.2998289261,3.3929,3.7631,18.965083586,0.574727138443,0.048195,-62.593989369
-71.5640409226,1.2252,2.656,13.2817199071,1.xxx-xxxxxxxx,0.018387,-18.9554029933
-70.7089037768,0.2688,3.67,108.166943162,0.283172519752,0.01848,-127.120139947
-70.3451093091,3.745,3.05,70.2275679641,0.xxx-xxxxxxxx,0.04321,-89.1538543619
-67.3789394879,3.5676,4.081,45.6927543667,0.461561879512,0.022045,-77.9786846233
-67.3789394879,3.568,2.303,45.6927543667,0.461561879512,0.02204,-77.9786896233
-67.3789394879,3.568,5.859,45.6927543667,0.461561879512,0.02204,-77.9786896233
-66.8001902177,1.616,3.624,13.393420668,0.787878235829,0.02214,-45.6729455234
-65.7709944945,5.3754,3.8652,72.4985370763,0.273590003365,0.02131,-131.570352434
-65.7709944945,2.8893,3.1568,72.4985370763,0.273590003365,0.02131,-131.570352434
-63.4336018249,5.7898,4.5366,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.032597,-13.3839774251
-63.4336018249,1.8315,5.2449,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.032597,-13.3839774251
-63.4336018249,5.7898,0.981,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.032597,-13.3839774251
-63.4336018249,1.8315,1.6893,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.032597,-13.3839774251
-62.3526404892,0.3875,1.251,128.826942119,0.253106563851,0.02008,-142.221048877
-62.3526404892,0.3875,4.807,128.826942119,0.253106563851,0.02007,-142.221058877
-59.5329834296,5.665,0.2567,34.9849560276,0.xxx-xxxxxxxx,0.01835,-118.322013613
-59.034757814,5.3987,3.6853,21.6092255392,1.xxx-xxxxxxxx,0.033991,-34.9522877596
-59.034757814,2.9125,2.9769,21.6092255392,1.xxx-xxxxxxxx,0.033991,-34.9522877596
-56.3083782554,0.2971,1.532,8.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.03143,-21.6022831544
-56.3083782554,1.2693,5.7684,8.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.031432,-21.6022811544
-56.3083782554,0.2971,5.088,8.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.03143,-21.6022831544
-56.3083782554,1.2693,2.2128,8.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.031426,-21.6022871544
-53.1284859718,3.7594,3.0096,8.4002509861,1.xxx-xxxxxxxx,0.029069,-29.9715855614
-52.6944283831,1.634,3.31,128.408275759,0.227274806756,0.01917,-158.388899429
-51.3385490838,1.388,1.899,8.xxx-xxxxxxxx,0.937076770012,0.01861,-38.4010419649
-51.3385490838,1.3884,5.4545,8.xxx-xxxxxxxx,0.937076770012,0.01861,-38.4010419649
-50.1927727831,2.681,4.441,8.xxx-xxxxxxxx,0.768248432269,0.01895,-46.8437077758
-50.1927727831,2.681,0.885,8.xxx-xxxxxxxx,0.768248432269,0.01895,-46.8437077758
-47.4878755536,3.915,3.293,8.xxx-xxxxxxxx,0.368589084265,0.01377,-97.6618392493
-45.8052464038,3.576,5.801,8.xxx-xxxxxxxx,0.119502842447,0.02433,-301.241837658
-45.8052464038,3.576,4.023,8.xxx-xxxxxxxx,0.119502842447,0.02433,-301.241837658
-45.8052464038,3.576,2.245,8.xxx-xxxxxxxx,0.119502842447,0.02433,-301.241837658
-39.4708073841,0.3968,4.756,85.2786457473,0.272452616033,0.02402,-132.116988196
-39.4708073841,3.736,3.303,85.2786457473,0.272452616033,0.02404,-132.116968196
-39.4708073841,0.3968,1.2,85.2786457473,0.272452616033,0.02403,-132.116978196
-38.9893472382,2.705,5.121,38.419505811,0.222075276421,0.03102,-162.085915971
-38.9893472382,0.6915,4.413,38.419505811,0.222075276421,0.03102,-162.085915971
-38.9893472382,1.15,0.2043,38.419505811,0.222075276421,0.03103,-162.085905971
-38.9893472382,0.6915,0.857,38.419505811,0.222075276421,0.03103,-162.085905971
-38.9893472382,2.705,1.565,38.419505811,0.222075276421,0.03103,-162.085905971
-36.2522318936,5.675,0.2115,81.6113766155,0.322568840658,0.02299,-111.587800722
-35.2160064783,3.403,3.683,73.241703423,0.288347424625,0.02954,-124.827352393
-35.2160064783,0.9172,2.975,73.241703423,0.288347424625,0.02954,-124.827352393
-33.6885133425,1.8983,1.5605,13.3134454753,1.xxx-xxxxxxxx,0.017485,-21.6167171887
-33.6885133425,5.8567,4.4077,13.3134454753,1.xxx-xxxxxxxx,0.017489,-21.6167131887
-33.6885133425,1.8983,5.1161,13.3134454753,1.xxx-xxxxxxxx,0.017489,-21.6167131887
-33.6885133425,5.857,0.8522,13.3134454753,1.xxx-xxxxxxxx,0.01748,-21.6167221887
-30.9622709193,1.0487,2.2385,13.3775299338,1.xxx-xxxxxxxx,0.016943,-34.9703034167
-30.9622709193,1.0487,5.794,13.3775299338,1.xxx-xxxxxxxx,0.01694,-34.9703064167
-30.9622709193,1.0487,4.0162,13.3775299338,1.xxx-xxxxxxxx,0.01694,-34.9703064167
-29.7434307309,1.368,5.498,13.3963913832,0.7442196645,0.02343,-48.3522916929
-29.7434307309,1.368,1.943,13.3963913832,0.7442196645,0.02343,-48.3522916929
-28.6090440786,2.66,4.4842,13.4084995117,0.478858899506,0.024249,-75.1589905835
-28.6090440786,2.66,0.92863,13.4084995117,0.478858899506,0.024249,-75.1589905835
-26.5637042266,0.9413,2.957,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.03849,-13.3785575515
-26.5637042266,3.4274,3.6658,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.038488,-13.3785595515
-23.9612392293,3.132,0.2201,45.6928766355,0.609214006527,0.0159,-59.0801860756
-18.433938616,4.9115,4.0219,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.018372,-18.9563101291
-18.433938616,4.9115,5.7997,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.018372,-18.9563101291
-18.433938616,4.9115,2.2441,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.01837,-18.9563121291
-17.3530659589,1.872,1.66,81.6124736758,0.357932099289,0.02438,-100.559399548
-17.3530659589,5.83,4.507,81.6124736758,0.357932099289,0.02438,-100.559399548
-17.3530659589,5.831,0.9518,81.6124736758,0.357932099289,0.02437,-100.559409548
-17.3530659589,1.872,5.216,81.6124736758,0.357932099289,0.02438,-100.559399548
-16.259299564,1.8282,1.2115,43.6824023942,0.240001264083,0.01816,-149.990063939
-16.259299564,1.8282,4.767,43.6824023942,0.240001264083,0.018156,-149.990067939
-15.9445064118,1.063,5.785,24.7262869302,0.824167582736,0.02116,-43.6619017005
-15.9445064118,1.4,5.44,24.7262869302,0.824167582736,0.02116,-43.6619017005
-15.9445064118,1.4,1.884,24.7262869302,0.824167582736,0.02116,-43.6619017005
-15.9445064118,1.063,2.23,24.7262869302,0.824167582736,0.02116,-43.6619017005
-15.9445064118,1.063,4.008,24.7262869302,0.824167582736,0.02116,-43.6619017005
-24.2264851795,0.92361,2.956,59.0954528183,0.273579339515,0.07357,-131.523221746
-15.5232426255,3.766,5.475,68.4135591781,0.321174200439,0.05429,-112.041150166
-15.5232426255,3.766,1.919,68.4135591781,0.321174200439,0.0543,-112.041140166
-15.2542639141,2.693,4.426,24.7344211952,0.526237299694,0.02205,-68.3922630659
-15.2542639141,2.693,0.8705,24.7344211952,0.526237299694,0.02205,-68.3922630659
-15.0676428385,3.648,3.279,93.1499541841,0.222835437867,0.03913,-161.524774345
-14.9305788338,5.168,0.9054,24.7369993856,0.386495738711,0.05661,-93.0936107198
-14.8256469801,5.168,4.4609,117.887730236,0.170595809213,0.05661,-210.981184741
-12.5280946241,0.3145,5.062,30.5889440756,0.650793602475,0.0268,-55.293601478
-12.5280946241,1.2867,2.1867,30.5889440756,0.650793602475,0.0268,-55.293601478
-12.5280946241,0.31449,1.5061,30.5889440756,0.650793602475,0.0268,-55.293601478
-12.5280946241,1.2867,5.7422,30.5889440756,0.650793602475,0.026801,-55.293600478
-11.9754489146,3.147,0.2136,116.505424685,0.177861317388,0.0208,-202.396251088
-11.3092849078,3.7768,2.9863,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.02963,-30.5662362563
-9.xxx-xxxxxxxx,2.298,0.5541,36.4981168626,0.203888780178,0.01705,-176.560412167
-9.xxx-xxxxxxxx,5.174,0.5541,5.xxx-xxxxxxxx,0.986396141073,0.01768,-36.4810063483
-9.xxx-xxxxxxxx,4.674,1.554,5.xxx-xxxxxxxx,0.986396141073,0.01768,-36.4810063483
-9.xxx-xxxxxxxx,4.674,5.11,5.xxx-xxxxxxxx,0.986396141073,0.01768,-36.4810063483
-7.xxx-xxxxxxxx,3.462,3.6488,5.xxx-xxxxxxxx,0.744209571183,0.059127,-48.3172507869
-7.xxx-xxxxxxxx,0.9758,2.94,5.xxx-xxxxxxxx,0.744209571183,0.05913,-48.3172477869
-6.xxx-xxxxxxxx,1.313,2.181,5.xxx-xxxxxxxx,0.662590068278,0.02631,-54.3091910766
-6.xxx-xxxxxxxx,1.313,5.736,5.xxx-xxxxxxxx,0.662590068278,0.02631,-54.3091910766
-6.xxx-xxxxxxxx,0.3407,5.056,5.xxx-xxxxxxxx,0.662590068278,0.02631,-54.3091910766
-6.xxx-xxxxxxxx,0.3407,1.5,5.xxx-xxxxxxxx,0.662590068278,0.02631,-54.3091910766
0,2.93,2.9478,0,6.xxx-xxxxxxxx,0.017429,-5.xxx-xxxxxxxx
0,5.4161,3.6561,0,6.xxx-xxxxxxxx,0.017429,-5.xxx-xxxxxxxx
-4.xxx-xxxxxxxx,2.156,5.446,72.2533648753,0.259889135104,0.06711,-138.461818321
-4.xxx-xxxxxxxx,2.156,1.89,72.2533648753,0.259889135104,0.0671,-138.461828321
0,3.9503,5.0936,0,6.xxx-xxxxxxxx,0.020332,-5.xxx-xxxxxxxx
0,4.353,5.7742,0,6.xxx-xxxxxxxx,0.020332,-5.xxx-xxxxxxxx
0,4.353,2.2186,0,6.xxx-xxxxxxxx,0.020332,-5.xxx-xxxxxxxx
0,3.9503,1.5381,0,6.xxx-xxxxxxxx,0.020332,-5.xxx-xxxxxxxx
12.3383843096,3.7151,3.2743,55.3200982344,0.183169365642,0.011899,-196.539326922
-178.152498245,5.436,3.992,180.110560676,0.193447903454,0.07561,-186.032188148
-178.152498245,2.95,3.283,180.110560676,0.193447903454,0.07561,-186.032188148
-173.418438779,4.047,2.953,102.709222448,0.229248544165,0.07606,-156.968179907
-90,2.2929,0.72849,0,6.xxx-xxxxxxxx,0.075575,-5.xxx-xxxxxxxx
-90,4.6679,5.284,0,6.xxx-xxxxxxxx,0.075562,-5.xxx-xxxxxxxx
-90,2.898,3.1374,0,6.xxx-xxxxxxxx,0.075358,-5.xxx-xxxxxxxx
-90,5.3841,3.8457,0,6.xxx-xxxxxxxx,0.075358,-5.xxx-xxxxxxxx
-90,5.1679,0.72849,0,6.xxx-xxxxxxxx,0.075575,-5.xxx-xxxxxxxx
-90,4.6679,1.7285,0,6.xxx-xxxxxxxx,0.075575,-5.xxx-xxxxxxxx
-87.797272509,1.825,1.407,150.119887999,0.230612418005,0.07632,-156.03913848
-87.797272509,1.825,4.963,150.119887999,0.230612418005,0.07632,-156.03913848
-87.797272509,1.222,2.732,150.119887999,0.230612418005,0.07562,-156.03983848
-87.7092554712,0.2658,3.746,144.124855988,0.239822460353,0.07562,-150.044445131
-4.xxx-xxxxxxxx,3.818,5.46,5.xxx-xxxxxxxx,0.498273409666,0.07,-72.1838322732
-4.xxx-xxxxxxxx,3.818,1.905,5.xxx-xxxxxxxx,0.498273409666,0.07,-72.1838322732
-4.xxx-xxxxxxxx,3.4838,0.8763,5.xxx-xxxxxxxx,0.498273409666,0.07016,-72.1836722732
-4.xxx-xxxxxxxx,3.4838,4.4319,5.xxx-xxxxxxxx,0.498273409666,0.07016,-72.1836722732
-4.xxx-xxxxxxxx,5.223,0.8908,228.722912797,0.094939658731,0.0732,-379.137804647
-4.xxx-xxxxxxxx,5.223,4.446,78.2346855866,0.239235914025,0.0732,-150.414921798
-4.xxx-xxxxxxxx,3.593,2.2277,84.2188666754,0.145951418551,0.039725,-246.632515158
-4.xxx-xxxxxxxx,3.593,5.7832,84.2188666754,0.145951418551,0.039725,-246.632515158
-4.xxx-xxxxxxxx,3.593,4.0055,84.2188666754,0.145951418551,0.039725,-246.632515158
-3.xxx-xxxxxxxx,2.315,0.5512,90.2048796036,0.206406468384,0.04209,-174.381529812
-3.xxx-xxxxxxxx,4.691,1.551,5.xxx-xxxxxxxx,0.399114430128,0.04369,-90.1614257525
-3.xxx-xxxxxxxx,5.191,0.5512,5.xxx-xxxxxxxx,0.399114430128,0.04369,-90.1614257525
-3.xxx-xxxxxxxx,4.691,5.107,5.xxx-xxxxxxxx,0.399114430128,0.04369,-90.1614257525
-3.xxx-xxxxxxxx,0.4154,1.185,5.xxx-xxxxxxxx,0.352332435459,0.04342,-102.138950242
-3.xxx-xxxxxxxx,0.4154,4.74,5.xxx-xxxxxxxx,0.352332435459,0.04342,-102.138950242
-2.xxx-xxxxxxxx,5.693,0.198,348.485853666,0.077817213605,0.04341,-462.606969014
-2.xxx-xxxxxxxx,1.084,5.779,5.xxx-xxxxxxxx,0.272446178192,0.06402,-132.080110658
-2.xxx-xxxxxxxx,1.084,4.002,5.xxx-xxxxxxxx,0.272446178192,0.06402,-132.080110658
-2.xxx-xxxxxxxx,1.084,2.224,5.xxx-xxxxxxxx,0.272446178192,0.06402,-132.080110658
-1.997762534,3.576,3.282,174.113739103,0.0697250824312,0.0727,-516.271807785
-1.xxx-xxxxxxxx,3.167,0.2093,180.11065196,0.067377512314,0.06399,-534.271014837
0,0.87047,2.2151,0,6.xxx-xxxxxxxx,0.072673,-5.xxx-xxxxxxxx
0,0.87047,3.9929,0,6.xxx-xxxxxxxx,0.072673,-5.xxx-xxxxxxxx
0,3.7871,1.186,0,6.xxx-xxxxxxxx,0.072673,-5.xxx-xxxxxxxx
0,0.87047,5.7706,0,6.xxx-xxxxxxxx,0.072673,-5.xxx-xxxxxxxx
0,5.4335,3.6561,0,6.xxx-xxxxxxxx,0.072659,-5.xxx-xxxxxxxx
0,1.846,5.2157,0,6.xxx-xxxxxxxx,0.02615,-5.xxx-xxxxxxxx
0,5.8712,0.84245,0,6.xxx-xxxxxxxx,0.049398,-5.xxx-xxxxxxxx
0,2.9474,2.9478,0,6.xxx-xxxxxxxx,0.072659,-5.xxx-xxxxxxxx
0,1.9129,1.5508,0,6.xxx-xxxxxxxx,0.049398,-5.xxx-xxxxxxxx
0,4.6432,2.9612,0,6.xxx-xxxxxxxx,0.043593,-5.xxx-xxxxxxxx
0,1.9129,5.1063,0,6.xxx-xxxxxxxx,0.049398,-5.xxx-xxxxxxxx
0,1.846,1.6602,0,6.xxx-xxxxxxxx,0.02615,-5.xxx-xxxxxxxx
0,5.8712,4.398,0,6.xxx-xxxxxxxx,0.049398,-5.xxx-xxxxxxxx
0,1.6457,3.2946,0,6.xxx-xxxxxxxx,0.026164,-5.xxx-xxxxxxxx
0,5.8044,0.95182,0,6.xxx-xxxxxxxx,0.02615,-5.xxx-xxxxxxxx
0,5.6154,3.6418,0,6.xxx-xxxxxxxx,0.043593,-5.xxx-xxxxxxxx
0,5.8044,4.5074,0,6.xxx-xxxxxxxx,0.02615,-5.xxx-xxxxxxxx
0,3.7871,4.7416,0,6.xxx-xxxxxxxx,0.072673,-5.xxx-xxxxxxxx
1.xxx-xxxxxxxx,2.6191,1.5508,180.110560676,0.193447903454,0.075614,-186.032184148
1.xxx-xxxxxxxx,2.6191,5.1063,180.110560676,0.193447903454,0.075614,-186.032184148
1.xxx-xxxxxxxx,0.6053,0.8424,180.110560676,0.193447903454,0.07561,-186.032188148
1.xxx-xxxxxxxx,0.60525,4.398,180.110560676,0.193447903454,0.075614,-186.032184148
2.xxx-xxxxxxxx,0.14433,3.6901,144.133297548,0.xxx-xxxxxxxx,0.061083,-150.067777183
2.xxx-xxxxxxxx,3.6304,2.9818,144.133297548,0.xxx-xxxxxxxx,0.061083,-150.067777183
3.xxx-xxxxxxxx,2.215,0.5454,90.2043393072,0.374270049333,0.04659,-96.1464220575
3.xxx-xxxxxxxx,1.7433,1.5454,90.2043393072,0.374270049333,0.046586,-96.1464260575
3.xxx-xxxxxxxx,1.7433,5.1009,90.2043393072,0.374270049333,0.046586,-96.1464260575
3.xxx-xxxxxxxx,5.081,0.5454,90.2049089693,0.193147008418,0.04487,-186.352857116
5.xxx-xxxxxxxx,5.1102,4.4551,54.3322210177,0.xxx-xxxxxxxx,0.058058,-60.2447444677
5.xxx-xxxxxxxx,5.11,0.8996,54.3322210177,0.xxx-xxxxxxxx,0.05806,-60.2447424677
6.xxx-xxxxxxxx,3.7107,1.9135,54.3345934635,0.314054762926,0.055536,-114.581042133
6.xxx-xxxxxxxx,3.7107,5.469,54.3345934635,0.314054762926,0.055535,-114.581043133
6.xxx-xxxxxxxx,5.9334,3.6731,54.3353928517,0.108447656649,0.066954,-331.910374794
7.xxx-xxxxxxxx,3.5607,2.9721,42.4286535124,0.138196278156,0.070429,-260.4442813
7.xxx-xxxxxxxx,0.07457,3.68,42.4286535124,0.138196278156,0.07043,-260.4442803
8.xxx-xxxxxxxx,3.8598,1.186,248.634631632,0.123691855582,0.035254,-291.028075909
8.xxx-xxxxxxxx,3.8598,4.7416,248.634631632,0.123691855582,0.035254,-291.028075909
9.xxx-xxxxxxxx,3.2874,3.6554,36.4979169634,0.236986255588,0.03692,-151.879752462
9.xxx-xxxxxxxx,5.6,0.2201,36.4984265104,0.xxx-xxxxxxxx,0.02651,-261.384880149
9.xxx-xxxxxxxx,0.9431,5.771,30.5799616518,0.986396141073,0.03537,-36.4633163483
9.xxx-xxxxxxxx,0.9431,2.215,30.5799616518,0.986396141073,0.03537,-36.4633163483
9.xxx-xxxxxxxx,4.1113,2.6415,30.5799616518,0.986396141073,0.035354,-36.4633323483
9.xxx-xxxxxxxx,0.9431,3.993,30.5799616518,0.986396141073,0.03537,-36.4633163483
9.xxx-xxxxxxxx,3.6861,3.2692,103.581925723,0.147754925541,0.029508,-243.631833485
12.5280946241,3.5163,5.794,24.7314574023,0.650793602475,0.026801,-55.293600478
12.5280946241,3.5163,4.0162,24.7314574023,0.650793602475,0.026801,-55.293600478
12.5280946241,3.5163,2.2385,24.7314574023,0.650793602475,0.0268,-55.293601478
5.5990123482,0,3.6731,60.3026887988,0.xxx-xxxxxxxx,0.074928,-307.410245388
6.xxx-xxxxxxxx,1.5221,5.437,102.709222448,0.229248544165,0.076062,-156.968177907
6.xxx-xxxxxxxx,1.5221,1.8815,102.709222448,0.229248544165,0.076062,-156.968177907
13.2397691624,2.5418,4.415,24.7376329483,0.343560286344,0.04256,-104.748839936
13.2397691624,3,0.2067,24.7376329483,0.343560286344,0.04256,-104.748839936
13.2397691624,2.542,0.8595,24.7376329483,0.343560286344,0.04256,-104.748839936
13.2397691624,4.5557,1.5678,24.7376329483,0.343560286344,0.042562,-104.748837936
13.2397691624,4.5557,5.1234,24.7376329483,0.343560286344,0.04256,-104.748839936
16.259299564,1.0727,0.20475,106.325821545,0.240001264083,0.032246,-149.975977939
16.6983174396,4.2566,2.9583,18.9659769859,0.574698938865,0.030347,-62.6149111231
16.6983174396,5.2288,3.6389,18.9659769859,0.574698938865,0.03035,-62.6149081231
18.433938616,1.781,1.1926,13.2822105817,1.xxx-xxxxxxxx,0.032583,-18.9420991291
18.433938616,1.781,4.7481,13.2822105817,1.xxx-xxxxxxxx,0.032585,-18.9420971291
18.9693726034,3.3239,3.6612,184.064043922,0.177317455547,0.044977,-202.992920522
19.6527574737,4.1461,2.6473,70.2307316375,0.403606625792,0.04321,-89.1579107635
20.554938142,0.37066,2.9612,32.3050153372,0.702252434497,0.02483,-51.2418678421
20.554938142,0.77344,3.6418,32.3050153372,0.702252434497,0.02483,-51.2418678421
20.554938142,5.829,2.9612,32.3050153372,0.702252434497,0.024825,-51.2418728421
22.2478435895,5.0676,4.4377,110.313985284,0.252424190379,0.045982,-142.579664592
22.2478435895,5.0676,0.88213,110.313985284,0.252424190379,0.04598,-142.579666592
22.3789495002,4.8411,2.2364,78.0032749753,0.326359971692,0.030588,-110.283686087
22.3789495002,4.8411,5.792,78.0032749753,0.326359971692,0.030588,-110.283686087
22.3789495002,4.8411,4.0142,78.0032749753,0.326359971692,0.030588,-110.283686087
23.1973712944,3.67,5.4516,13.3938964908,0.787846301414,0.044268,-45.6526697195
23.1973712944,3.67,1.896,13.3938964908,0.787846301414,0.044266,-45.6526717195
23.6281411888,3.8947,1.1911,59.0950873955,0.343562470959,0.031711,-104.759022597
23.6281411888,3.8947,4.7467,59.0950873955,0.343562470959,0.031711,-104.759022597
25.7086375801,0.2112,3.727,13.4155534725,0.200224939851,0.0388,-179.769786258
25.7086375801,3.6973,3.0183,13.4155534725,0.200224939851,0.038801,-179.769785258
26.5637042266,0.97803,5.7765,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.032485,-13.3845625515
26.5637042266,0.97803,2.2209,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.032488,-13.3845595515
26.5637042266,0.85802,2.9863,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.019489,-13.3975585515
26.5637042266,0.97803,3.9987,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.032485,-13.3845625515
29.7434307309,1.7898,5.1038,34.9793303097,0.7442196645,0.023431,-48.3522906929
29.7434307309,1.7898,1.5483,34.9793303097,0.7442196645,0.023431,-48.3522906929
29.7434307309,2.262,0.54829,34.9793303097,0.7442196645,0.023431,-48.3522906929
30.5777520288,5.126,0.5483,34.9864585219,0.234801870224,0.02279,-153.307178513
35.2160064783,2.6074,4.4904,51.6151889699,0.288347424625,0.029547,-124.827345393
35.2160064783,4.6212,5.1987,51.6151889699,0.288347424625,0.029547,-124.827345393
35.2160064783,2.607,0.9348,51.6151889699,0.288347424625,0.02954,-124.827352393
35.2160064783,4.6212,1.6431,51.6151889699,0.288347424625,0.029544,-124.827348393
35.2160064783,3.066,0.282,51.6151889699,0.288347424625,0.02954,-124.827352393
38.6581656132,3.3665,3.6758,8.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.023311,-38.3968366336
39.8039149852,4.1868,2.6619,8.xxx-xxxxxxxx,0.768240290123,0.022699,-46.8404554467
45.5770421903,3.924,1.204,411.570123244,0.0857081666368,0.02492,-420.030306718
45.5770421903,3.924,4.759,411.570123244,0.0857081666368,0.02492,-420.030306718
48.3647885517,5.2056,3.6127,63.7805960767,0.498289566725,0.03499,-72.2164994398
48.3647885517,4.2333,2.9322,63.7805960767,0.498289566725,0.035,-72.2164894398
49.3970414382,2.282,0.5599,46.8581384088,0.650813851806,0.0268,-55.2918802467
49.3970414382,1.0071,4.0132,46.8581384088,0.650813851806,0.026799,-55.2918812467
49.3970414382,1.8101,1.5599,46.8581384088,0.650813851806,0.026799,-55.2918812467
49.3970414382,1.8101,5.1155,46.8581384088,0.650813851806,0.026799,-55.2918812467
49.3970414382,1.0071,5.791,46.8581384088,0.650813851806,0.026799,-55.2918812467
49.3970414382,1.0071,2.2354,46.8581384088,0.650813851806,0.026799,-55.2918812467
50.5258876688,5.146,0.5599,85.2776532444,0.272455686549,0.02639,-132.113128996
51.3385490838,0.87545,2.9951,29.9860160949,0.937076770012,0.01861,-38.4010419649
56.3083782554,5.6258,0.22438,13.3129639646,1.xxx-xxxxxxxx,0.031208,-21.6025051544
58.6698115061,4.6454,1.6602,34.9855690528,0.222844108832,0.039845,-161.517772821
58.6698115061,2.631,0.9518,34.9855690528,0.222844108832,0.03984,-161.517777821
58.6698115061,3.09,0.299,34.9855690528,0.222844108832,0.03984,-161.517777821
58.6698115061,4.6454,5.2157,34.9855690528,0.222844108832,0.039845,-161.517772821
58.6698115061,2.6315,4.5074,34.9855690528,0.222844108832,0.039845,-161.517772821
58.6698115061,1.104,0.2138,34.9855690528,0.222844108832,0.02381,-161.533807821
59.034757814,5.7638,0.8734,13.3770532204,1.xxx-xxxxxxxx,0.023698,-34.9625807596
59.034757814,5.7638,4.429,13.3770532204,1.xxx-xxxxxxxx,0.023698,-34.9625807596
60.2536680938,3.7268,3.2768,13.3959162934,0.744241871244,0.017564,-48.3567142545
60.2536680938,4.3356,5.4429,13.3959162934,0.744241871244,0.023431,-48.3508472545
60.2536680938,4.3356,1.8873,13.3959162934,0.744241871244,0.023431,-48.3508472545
61.3881247016,2.583,0.8692,13.4080255394,0.xxx-xxxxxxxx,0.03601,-75.1448373142
61.3881247016,4.5971,1.5775,13.4080255394,0.xxx-xxxxxxxx,0.036012,-75.1448353142
61.3881247016,4.5971,5.1331,13.4080255394,0.xxx-xxxxxxxx,0.036012,-75.1448353142
61.3881247016,3.0415,0.2164,13.4080255394,0.xxx-xxxxxxxx,0.036012,-75.1448353142
61.3881247016,2.5832,4.4247,13.4080255394,0.xxx-xxxxxxxx,0.036012,-75.1448353142
61.5556610981,1.812,4.7583,88.5898943859,0.xxx-xxxxxxxx,0.026015,-163.744405297
61.5556610981,1.812,1.2027,88.5898943859,0.xxx-xxxxxxxx,0.026021,-163.744399297
63.4336018249,3.5425,5.7998,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.039003,-13.3775714251
63.4336018249,3.5425,4.0221,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.039003,-13.3775714251
63.4336018249,3.5425,2.2443,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.039003,-13.3775714251
66.5002029636,4.8694,5.8036,45.6944591997,0.239247649981,0.028504,-150.452235816
66.5002029636,4.8694,4.0258,45.6944591997,0.239247649981,0.028504,-150.452235816
66.5002029636,4.8694,2.248,45.6944591997,0.239247649981,0.02851,-150.452229816
73.2998289261,4.2246,2.9031,43.677100783,0.574727138443,0.030347,-62.611837369
73.2998289261,5.1968,3.5837,43.677100783,0.574727138443,0.030347,-62.611837369
75.5784146447,3.7355,3.2921,24.7381784074,0.166036622287,0.023606,-216.809059422
-94.2366428847,4.912,5.936,84.2138021148,0.221628156943,0.07869,-162.365305676
-94.2366428847,4.912,2.381,84.2138021148,0.221628156943,0.07869,-162.365305676
-94.2366428847,4.912,4.159,84.2138021148,0.221628156943,0.07869,-162.365305676
-82.4049154701,2.6951,1.6431,42.424631788,0.396514318269,0.07846,-90.7181687962
-82.4049154701,2.6951,5.1987,42.424631788,0.396514318269,0.07846,-90.7181687962
-82.4049154701,1.1395,0.28204,42.424631788,0.396514318269,0.07846,-90.7181687962
-82.4049154701,0.68118,4.4904,42.424631788,0.396514318269,0.07846,-90.7181687962
-82.4049154701,0.6812,0.9348,42.424631788,0.396514318269,0.07846,-90.7181687962
67.8324775316,5.1726,3.4355,32.3106166341,0.xxx-xxxxxxxx,0.041159,-174.888976822
78.6894199246,2.6005,0.90078,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.034721,-30.559485419
78.6894199246,4.6144,5.1647,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.034714,-30.559492419
78.6894199246,2.6005,4.4563,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.034714,-30.559492419
78.6894199246,4.6144,1.6091,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.034721,-30.559485419
78.6894199246,3.0588,0.24801,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.034721,-30.559485419
80.3106547802,3.6915,2.9842,36.496372108,0.144262444496,0.034538,-249.525654149
80.3106547802,0.2054,3.693,36.496372108,0.144262444496,0.03454,-249.525652149
81.2533316347,0.88707,3.0096,42.4240319783,0.456198044923,0.038226,-78.879611919
81.4687403758,0.8929,3.047,42.4254472711,0.296698155073,0.05878,-121.283947458
82.6938157134,5.6433,0.25026,48.3733814152,0.152606103607,0.045645,-235.86997382
83.15682822,0.2461,3.744,102.70333028,0.238304404974,0.04896,-151.027405425
83.15682822,3.7322,3.0353,102.70333028,0.238304404974,0.048958,-151.027407425
84.2890734434,2.635,1.1171,5.xxx-xxxxxxxx,0.597057450135,0.034203,-60.2651255824
84.2890734434,4.6489,1.8255,5.xxx-xxxxxxxx,0.597057450135,0.034203,-60.2651255824
84.2890734434,2.635,4.6727,5.xxx-xxxxxxxx,0.597057450135,0.034203,-60.2651255824
84.2890734434,3.093,0.4643,5.xxx-xxxxxxxx,0.597057450135,0.0342,-60.2651285824
84.2890734434,4.6489,5.381,5.xxx-xxxxxxxx,0.597057450135,0.034203,-60.2651255824
84.5593501344,3.5599,4.0569,66.2716313077,0.284444032274,0.061311,-126.508977996
84.5593501344,1.8275,1.5803,66.2716313077,0.284444032274,0.061312,-126.508976996
84.5593501344,3.5599,5.8347,66.2716313077,0.284444032274,0.061311,-126.508977996
84.5593501344,3.5599,2.2792,66.2716313077,0.284444032274,0.061311,-126.508977996
84.5593501344,1.8275,5.1358,66.2716313077,0.284444032274,0.061312,-126.508976996
84.5593501344,2.3,0.5803,66.2716313077,0.284444032274,0.06131,-126.508978996
84.6103733508,4.6661,5.2497,192.842097143,0.112713753715,0.036621,-319.375714953
84.6103733508,4.6661,1.6942,192.842097143,0.112713753715,0.036621,-319.375714953
84.6103733508,2.6522,4.5414,192.842097143,0.112713753715,0.036621,-319.375714953
84.6103733508,3.111,0.3331,192.842097143,0.112713753715,0.03662,-319.375715953
84.6103733508,2.652,0.9859,192.842097143,0.112713753715,0.03662,-319.375715953
84.7096096366,5.162,0.5803,66.2721493722,0.110644373049,0.06129,-325.325011862
85.1557162757,3.7413,3.503,72.2495733366,0.101337672106,0.068877,-355.200418417
85.2360796169,4.2217,2.8682,5.xxx-xxxxxxxx,0.498302291516,0.034992,-72.214652405
85.2360796169,5.1939,3.5488,5.xxx-xxxxxxxx,0.498302291516,0.034999,-72.214645405
86.4234559731,4.3501,2.1721,5.xxx-xxxxxxxx,0.3742918757,0.046614,-96.140788681
86.4234559731,3.9473,1.4916,5.xxx-xxxxxxxx,0.3742918757,0.046614,-96.140788681
86.4234559731,4.3501,5.7277,5.xxx-xxxxxxxx,0.3742918757,0.0466,-96.140802681
86.4234559731,3.9473,5.0471,5.xxx-xxxxxxxx,0.3742918757,0.0466,-96.140802681
86.4783401721,3.385,3.719,294.550749493,0.0921388588087,0.04949,-390.688618044
86.6333419294,4.2043,2.7055,5.xxx-xxxxxxxx,0.352353000825,0.049497,-102.126909285
87.3972850434,3.9412,4.7772,5.xxx-xxxxxxxx,0.272462125064,0.063617,-132.072779425
87.3972850434,3.9412,1.2216,5.xxx-xxxxxxxx,0.272462125064,0.063611,-132.072785425
87.7092554712,1.0245,4.0336,5.xxx-xxxxxxxx,0.239822460353,0.072724,-150.047341131
87.7092554712,4.3472,2.0995,5.xxx-xxxxxxxx,0.239822460353,0.072703,-150.047362131
87.7092554712,3.9444,4.9745,5.xxx-xxxxxxxx,0.239822460353,0.072717,-150.047348131
87.7092554712,1.0245,5.8113,5.xxx-xxxxxxxx,0.239822460353,0.072724,-150.047341131
87.7092554712,1.0245,2.2558,5.xxx-xxxxxxxx,0.239822460353,0.072717,-150.047348131
87.7092554712,3.9444,1.4189,5.xxx-xxxxxxxx,0.239822460353,0.072703,-150.047362131
87.7092554712,4.3472,5.655,5.xxx-xxxxxxxx,0.239822460353,0.072717,-150.047348131
90,3.7471,3.5717,0,6.xxx-xxxxxxxx,0.030504,-5.xxx-xxxxxxxx
90,5.1819,3.522,0,6.xxx-xxxxxxxx,0.061008,-5.xxx-xxxxxxxx
90,3.674,3.2079,0,6.xxx-xxxxxxxx,0.031596,-5.xxx-xxxxxxxx
90,4.2217,2.8043,0,6.xxx-xxxxxxxx,0.063938,-5.xxx-xxxxxxxx
90,3.7413,3.3149,0,6.xxx-xxxxxxxx,0.027961,-5.xxx-xxxxxxxx
90,4.2043,2.6764,0,6.xxx-xxxxxxxx,0.029066,-5.xxx-xxxxxxxx
90,5.1726,3.6008,0,6.xxx-xxxxxxxx,0.033054,-5.xxx-xxxxxxxx
90,3.3847,3.6903,0,6.xxx-xxxxxxxx,0.02908,-5.xxx-xxxxxxxx
90,4.181,2.9031,0,6.xxx-xxxxxxxx,0.031982,-5.xxx-xxxxxxxx
90,3.9444,4.7856,0,6.xxx-xxxxxxxx,0.040683,-5.xxx-xxxxxxxx
90,3.674,3.1811,0,6.xxx-xxxxxxxx,0.026747,-5.xxx-xxxxxxxx
90,4.2043,2.8101,0,6.xxx-xxxxxxxx,0.049411,-5.xxx-xxxxxxxx
90,0.18792,3.8895,0,6.xxx-xxxxxxxx,0.026747,-5.xxx-xxxxxxxx
90,0.18792,3.9162,0,6.xxx-xxxxxxxx,0.031589,-5.xxx-xxxxxxxx
90,3.9444,1.23,0,6.xxx-xxxxxxxx,0.040677,-5.xxx-xxxxxxxx
90,5.1939,3.4848,0,6.xxx-xxxxxxxx,0.063938,-5.xxx-xxxxxxxx
90,3.738,3.0839,0,6.xxx-xxxxxxxx,0.060777,-5.xxx-xxxxxxxx
90,0.25187,3.7922,0,6.xxx-xxxxxxxx,0.060777,-5.xxx-xxxxxxxx
90,4.3472,5.4661,0,6.xxx-xxxxxxxx,0.040683,-5.xxx-xxxxxxxx
90,3.3847,3.824,0,6.xxx-xxxxxxxx,0.049398,-5.xxx-xxxxxxxx
90,4.3472,1.9106,0,6.xxx-xxxxxxxx,0.040677,-5.xxx-xxxxxxxx
90,3.3604,3.917,0,6.xxx-xxxxxxxx,0.031969,-5.xxx-xxxxxxxx
97.1254308143,1.0274,5.977,42.4199563291,0.744251965875,0.023186,-48.350436132
90,0.65758,0.98828,0,6.xxx-xxxxxxxx,0.075358,-5.xxx-xxxxxxxx
90,0.90161,3.1055,0,6.xxx-xxxxxxxx,0.075562,-5.xxx-xxxxxxxx
90,2.6715,1.6966,0,6.xxx-xxxxxxxx,0.075358,-5.xxx-xxxxxxxx
90,0.65758,4.5438,0,6.xxx-xxxxxxxx,0.075358,-5.xxx-xxxxxxxx
90,2.6715,5.2522,0,6.xxx-xxxxxxxx,0.075358,-5.xxx-xxxxxxxx
92.202727491,1.0274,2.4214,150.119887999,0.230612418005,0.075631,-156.03982748
92.202727491,3.7442,3.4268,150.119887999,0.230612418005,0.076323,-156.03913548
92.202727491,1.0274,4.1992,150.119887999,0.230612418005,0.075624,-156.03983448
92.202727491,4.3472,5.6579,150.119887999,0.230612418005,0.075617,-156.03984148
92.202727491,4.3472,2.1024,150.119887999,0.230612418005,0.075617,-156.03984148
92.2907445288,5.7759,4.644,144.124855988,0.239822460353,0.075623,-150.044442131
92.2907445288,5.7759,1.0885,144.124855988,0.239822460353,0.075623,-150.044442131
92.5262651907,3.944,1.367,270.266730278,0.0881547791622,0.06614,-408.331041757
92.4896990603,0.9016,3.181,132.13613937,0.260638806658,0.06692,-138.063559608
92.4896990603,1.0245,4.2748,132.13613937,0.260638806658,0.066917,-138.063562608
92.4896990603,1.0245,2.497,132.13613937,0.260638806658,0.066903,-138.063576608
92.4896990603,1.025,0.05257,132.13613937,0.260638806658,0.0669,-138.063579608
92.5262651907,3.944,4.922,270.266730278,0.0881547791622,0.06615,-408.331031757
92.7264709899,4.2246,2.7432,120.149664228,0.xxx-xxxxxxxx,0.061104,-126.08177221
92.7264709899,5.1968,3.4238,120.149664228,0.xxx-xxxxxxxx,0.061104,-126.08177221
92.8625731829,3.9412,4.9882,114.157486105,0.299643465716,0.058544,-120.091459212
92.8625731829,4.2275,2.6851,114.157486105,0.299643465716,0.058205,-120.091798212
92.8625731829,5.1998,3.3657,114.157486105,0.299643465716,0.058205,-120.091798212
92.8625731829,3.9412,1.4326,114.157486105,0.299643465716,0.058557,-120.091446212
93.0129642532,4.2072,2.7549,108.166169406,0.315371690241,0.055293,-114.10258636
93.1365423384,3.388,3.769,108.16659802,0.0820735332874,0.05531,-438.60209789
93.1800166294,1.0274,0,102.175864171,0.332839838393,0.052652,-108.113977157
94.3989628723,1.0216,0.11941,72.24817871,0.460206184503,0.0379,-78.1926074998
94.3989628723,1.0216,2.5639,72.24817871,0.460206184503,0.0379,-78.1926074998
94.3989628723,1.0216,4.3416,72.24817871,0.460206184503,0.037893,-78.1926144998
94.8647989754,0.1879,3.948,210.770207802,0.127207251833,0.03417,-282.985570223
94.8647989754,3.674,3.2395,210.770207802,0.127207251833,0.034154,-282.985586223
95.042745909,3.9383,1.4911,66.2720085681,0.175797988542,0.033169,-204.759637032
95.042745909,3.9383,5.0467,66.2720085681,0.175797988542,0.033176,-204.759630032
95.1947325378,4.2043,2.8595,60.2968814345,0.543246499977,0.0321,-66.240141735
95.1947325378,0.8987,3.248,60.2968814345,0.543246499977,0.0321,-66.240141735
95.3896266492,3.3847,3.8734,126.570238809,0.112713753715,0.032125,-319.380210953
95.7109265566,5.2027,3.3366,54.3291049783,0.597057450135,0.029205,-60.2701235824
95.7109265566,4.2304,2.656,54.3291049783,0.597057450135,0.029212,-60.2701165824
97.3061842866,5.1881,3.4737,187.542237405,0.152606103607,0.048687,-235.86693182
97.5950845299,5.3605,3.8992,42.424631788,0.396514318269,0.07846,-90.7181687962
97.5950845299,2.8744,3.1909,42.424631788,0.396514318269,0.07846,-90.7181687962
98.1305738084,3.114,0.36953,36.4867908263,0.848577571375,0.049114,-42.377370723
98.1305738084,2.6557,1.0223,36.4867908263,0.848577571375,0.049114,-42.377370723
98.1305738084,4.6696,1.7306,36.4867908263,0.848577571375,0.049114,-42.377370723
98.1305738084,2.6557,4.5779,36.4867908263,0.848577571375,0.049108,-42.377376723
98.1305738084,4.6696,5.2862,36.4867908263,0.848577571375,0.049108,-42.377376723
105.946285434,3.7471,3.6022,18.9558800036,0.824208710933,0.021154,-43.659727906
106.700171074,4.6627,1.7793,18.965083586,0.574727138443,0.048195,-62.593989369
106.700171074,2.6488,4.6265,18.965083586,0.574727138443,0.048202,-62.593982369
106.700171074,3.1071,0.41816,18.965083586,0.574727138443,0.048195,-62.593989369
106.700171074,4.6627,5.3348,18.965083586,0.574727138443,0.048202,-62.593982369
106.700171074,2.6488,1.0709,18.965083586,0.574727138443,0.048195,-62.593989369
108.435959077,4.3443,5.7335,13.2817199071,1.xxx-xxxxxxxx,0.018387,-18.9554029933
108.435959077,4.3443,2.1779,13.2817199071,1.xxx-xxxxxxxx,0.018387,-18.9554029933
108.971443062,5.1595,0.78371,184.055525386,0.177325674576,0.04303,-202.985456734
109.291096223,5.7729,1.164,108.166943162,0.283172519752,0.018475,-127.120144947
109.291096223,5.7729,4.7196,108.166943162,0.283172519752,0.018475,-127.120144947
109.654890691,1.8246,5.3393,70.2275679641,0.xxx-xxxxxxxx,0.043205,-89.1538593619
109.654890691,1.8246,1.7837,70.2275679641,0.xxx-xxxxxxxx,0.043205,-89.1538593619
109.654890691,2.297,0.7837,70.2275679641,0.xxx-xxxxxxxx,0.04321,-89.1538543619
109.984188058,3.56,0.08466,51.2618644984,0.512641542442,0.03403,-70.1946978489
109.984188058,3.5599,4.3069,51.2618644984,0.512641542442,0.034021,-70.1947068489
109.984188058,3.5599,2.5291,51.2618644984,0.512641542442,0.034034,-70.1946938489
113.199809782,3.9532,4.7652,13.393420668,0.787878235829,0.022142,-45.6729435234
113.199809782,4.3559,1.8902,13.393420668,0.787878235829,0.022148,-45.6729375234
113.199809782,3.9532,1.2096,13.393420668,0.787878235829,0.022148,-45.6729375234
113.199809782,4.3559,5.4458,13.393420668,0.787878235829,0.022142,-45.6729435234
114.229005506,0.6663,0.9688,72.4985370763,0.273590003365,0.02131,-131.570352434
114.229005506,0.66629,4.5244,72.4985370763,0.273590003365,0.02131,-131.570352434
114.229005506,2.6802,5.2327,72.4985370763,0.273590003365,0.02131,-131.570352434
114.229005506,2.6802,1.6772,72.4985370763,0.273590003365,0.02131,-131.570352434
115.71127003,5.6433,0.43564,13.4150801838,0.200232278472,0.026423,-179.775573176
116.566398175,3.738,3.1447,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.032597,-13.3839774251
116.566398175,0.25187,3.853,8.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.032597,-13.3839774251
117.647359511,5.1819,3.583,128.826942119,0.253106563851,0.020075,-142.221053877
120.965242186,2.6569,1.8571,21.6092255392,1.xxx-xxxxxxxx,0.033991,-34.9522877596
120.965242186,0.64304,4.7043,21.6092255392,1.xxx-xxxxxxxx,0.033997,-34.9522817596
120.965242186,0.64304,1.1487,21.6092255392,1.xxx-xxxxxxxx,0.033991,-34.9522877596
120.965242186,2.6569,5.4126,21.6092255392,1.xxx-xxxxxxxx,0.033997,-34.9522817596
123.691621745,1.0187,2.6016,8.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.020961,-21.6127521544
123.691621745,5.2724,3.3017,8.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.031432,-21.6022811544
123.691621745,1.0187,4.3794,8.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.020955,-21.6127581544
123.691621745,1.0187,0.1572,8.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.020961,-21.6127521544
123.691621745,4.3002,2.6212,8.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.031426,-21.6022871544
125.839251306,5.1455,0.8244,81.6100888215,0.270237025314,0.028689,-133.195702907
126.25544361,4.7251,2.6346,29.9989203103,0.322574539153,0.014384,-111.594435043
126.25544361,4.7251,0.19016,29.9989203103,0.322574539153,0.014384,-111.594435043
126.25544361,4.7251,4.4124,29.9989203103,0.322574539153,0.014395,-111.594424043
126.871514028,2.2823,0.8244,8.4002509861,1.xxx-xxxxxxxx,0.029074,-29.9715805614
126.871514028,1.8101,5.38,8.4002509861,1.xxx-xxxxxxxx,0.029069,-29.9715855614
126.871514028,1.8101,1.8244,8.4002509861,1.xxx-xxxxxxxx,0.029074,-29.9715805614
127.305571617,3.9354,5.0797,128.408275759,0.227274806756,0.019171,-158.388898429
127.305571617,3.9354,1.5241,128.408275759,0.227274806756,0.019171,-158.388898429
128.661450916,4.181,2.9351,8.xxx-xxxxxxxx,0.937076770012,0.018605,-38.4010469649
129.291057249,3.5483,0.11665,46.86075611,0.422173667463,0.041291,-85.236797481
129.291057249,3.5483,4.3389,46.86075611,0.422173667463,0.041302,-85.236786481
129.291057249,3.5483,2.5611,46.86075611,0.422173667463,0.041291,-85.236797481
129.807227217,3.3604,3.949,8.xxx-xxxxxxxx,0.768248432269,0.01895,-46.8437077758
132.512124446,1.654,1.5408,8.xxx-xxxxxxxx,0.368589084265,0.013767,-97.6618422493
132.512124446,1.654,5.0964,8.xxx-xxxxxxxx,0.368589084265,0.013772,-97.6618372493
134.23778466,4.8892,2.623,8.4847821626,0.113130517293,0.024344,-318.211303019
134.23778466,4.8892,4.4008,8.4847821626,0.113130517293,0.024344,-318.211303019
134.23778466,4.8892,0.17852,8.4847821626,0.113130517293,0.024344,-318.211303019
135.856780363,0.9457,0.5142,275.812785832,0.126635580411,0.01295,-284.284427177
137.727987088,5.632,0.4594,80.7234097343,0.403614675816,0.03529,-89.1640516627
140.529192616,5.1726,3.6338,85.2786457473,0.272452616033,0.024034,-132.116974196
140.529192616,1.8336,5.0862,85.2786457473,0.272452616033,0.024044,-132.116964196
140.712243505,1.8336,1.5307,38.4178281236,0.422168754156,0.024035,-85.255045969
141.010652762,2.864,3.2686,38.419505811,0.222075276421,0.031023,-162.085912971
141.010652762,5.3502,3.977,38.419505811,0.222075276421,0.031022,-162.085913971
143.974228408,1.125,0.5051,51.6141092519,0.441138033044,0.023,-81.5890140894
144.783993522,2.6384,1.1512,73.241703423,0.288347424625,0.029544,-124.827348393
144.783993522,3.097,0.4984,73.241703423,0.288347424625,0.02954,-124.827352393
144.783993522,4.6523,5.415,73.241703423,0.288347424625,0.029547,-124.827345393
144.783993522,4.6523,1.8595,73.241703423,0.288347424625,0.029544,-124.827348393
144.783993522,2.6384,4.7067,73.241703423,0.288347424625,0.029547,-124.827345393
146.311486658,0.18502,3.9818,13.3134454753,1.xxx-xxxxxxxx,0.017485,-21.6167171887
146.311486658,3.6711,3.2735,13.3134454753,1.xxx-xxxxxxxx,0.017489,-21.6167131887
150.256569269,4.2014,2.8915,13.3963913832,0.7442196645,0.023431,-48.3522906929
151.390955921,3.3817,3.9054,13.4084995117,0.478858899506,0.02426,-75.1589795835
153.436295773,4.6281,1.8765,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.038488,-13.3785595515
153.436295773,4.6281,5.4321,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.038485,-13.3785625515
153.436295773,2.6143,1.1682,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.038488,-13.3785595515
153.436295773,3.0726,0.51538,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.038488,-13.3785595515
153.436295773,2.6143,4.7237,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.038485,-13.3785625515
162.646934041,0.2112,3.882,81.6124736758,0.357932099289,0.02438,-100.559399548
162.646934041,3.6973,3.1738,81.6124736758,0.357932099289,0.024375,-100.559404548
162.89821753,5.0045,4.4143,62.6437049389,0.441131306332,0.039537,-81.5737215728
162.89821753,5.0045,2.6365,62.6437049389,0.441131306332,0.039535,-81.5737235728
162.89821753,5.005,0.1921,62.6437049389,0.441131306332,0.03953,-81.5737285728
163.740700436,3.7413,3.6225,43.6824023942,0.240001264083,0.018158,-149.990065939
164.055493588,4.1694,2.9496,24.7262869302,0.824167582736,0.021157,-43.6619047005
164.745736086,3.3482,3.9635,24.7344211952,0.526237299694,0.022045,-68.3922680659
164.932357161,1.9212,5.1102,93.1499541841,0.222835437867,0.039133,-161.524771345
164.932357161,1.9212,1.5546,93.1499541841,0.222835437867,0.039133,-161.524771345
167.471905376,4.2828,2.6473,30.5889440756,0.650793602475,0.026803,-55.293598478
167.471905376,5.255,3.3279,30.5889440756,0.650793602475,0.026801,-55.293600478
168.311298918,5.1287,0.84766,30.5951954184,0.202606226419,0.02859,-177.66665661
168.690715092,2.2649,0.84766,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.029627,-30.5662392563
168.690715092,1.7927,1.8477,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.029627,-30.5662392563
168.690715092,1.7927,5.4032,5.xxx-xxxxxxxx,1.xxx-xxxxxxxx,0.029628,-30.5662382563
170.538223847,0.8958,3.28,5.xxx-xxxxxxxx,0.986396141073,0.01768,-36.4810063483
173.66017784,5.2288,3.3337,5.xxx-xxxxxxxx,0.662590068278,0.026312,-54.3091890766
173.66017784,4.2566,2.6531,5.xxx-xxxxxxxx,0.662590068278,0.026311,-54.3091900766
180,0.23733,3.8822,0,6.xxx-xxxxxxxx,0.02615,-5.xxx-xxxxxxxx
180,0.6256,4.7335,0,6.xxx-xxxxxxxx,0.017429,-5.xxx-xxxxxxxx
180,0.6256,1.1779,0,6.xxx-xxxxxxxx,0.017429,-5.xxx-xxxxxxxx
180,2.6395,5.4418,0,6.xxx-xxxxxxxx,0.017429,-5.xxx-xxxxxxxx
180,3.9237,5.0949,0,6.xxx-xxxxxxxx,0.026164,-5.xxx-xxxxxxxx
180,3.9237,1.5394,0,6.xxx-xxxxxxxx,0.026164,-5.xxx-xxxxxxxx
180,1.0071,0.17464,0,6.xxx-xxxxxxxx,0.026164,-5.xxx-xxxxxxxx
180,1.0071,4.3969,0,6.xxx-xxxxxxxx,0.026164,-5.xxx-xxxxxxxx
180,1.6192,3.2959,0,6.xxx-xxxxxxxx,0.020332,-5.xxx-xxxxxxxx
180,3.7234,3.1738,0,6.xxx-xxxxxxxx,0.02615,-5.xxx-xxxxxxxx
180,2.6395,1.8862,0,6.xxx-xxxxxxxx,0.017429,-5.xxx-xxxxxxxx
180,1.0071,2.6191,0,6.xxx-xxxxxxxx,0.026164,-5.xxx-xxxxxxxx
-178.854304482,0.4018,4.7335,294.078663701,0.119976089136,0.12209,-299.955730735
-178.854304482,0.12108,3.9915,294.078663701,0.119976089136,0.1211,-299.956720735
-178.854304482,2.4157,1.8862,294.078663701,0.119976089136,0.12209,-299.955730735
-178.854304482,2.4157,5.4418,294.078663701,0.119976089136,0.12209,-299.955730735
-178.854304482,0.4018,1.1779,294.078663701,0.119976089136,0.12209,-299.955730735
-178.683164963,2.207,3.643,258.085078737,0.0689473489175,0.1105,-522.058429385
-178.430737382,3.327,3.9693,216.096134563,0.082161008999,0.10646,-438.083915299
-178.36351909,4.1491,2.9554,204.10026371,0.171358764611,0.10178,-209.996392976
-178.386555846,1.077,3.955,210.098155994,0.0844735939482,0.1034,-426.090889665
-178.315414636,1.998,2.941,198.102572363,0.176394434896,0.09885,-204.001485645
-178.210194518,2.152,0.8593,186.107703788,0.1874086486,0.09305,-192.012083019
-178.210194518,1.679,1.859,186.107703788,0.1874086486,0.09305,-192.012083019
-178.210194518,1.6793,5.4148,186.107703788,0.1874086486,0.09305,-192.012083019
-178.152498245,5.019,0.8593,180.110560676,0.193447903454,0.08962,-186.018178148
-177.510593208,3.029,3.9664,132.143873648,0.260623546428,0.13389,-138.00467753
-177.397590543,3.8642,2.9525,126.149962454,0.272446178192,0.12802,-132.016110658
-176.947296567,2.792,3.963,336.501729833,0.0798865303725,0.1096,-450.556653752
-176.820356379,3.6375,2.9496,102.181828222,0.3328203974,0.1048,-108.06814748
-176.308830361,2.1221,1.8692,90.2049089693,0.193147008418,0.11358,-186.284147116
-176.308830361,2.1221,5.4248,90.2049089693,0.193147008418,0.11358,-186.284147116
-176.121702747,0.1082,1.161,264.628560462,0.101462097797,0.1085,-354.725119152
-176.121702747,0.1082,4.716,264.628560462,0.101462097797,0.1085,-354.725119152
-175.364807817,0.2797,4.731,72.2536514876,0.161631906162,0.0904,-222.651286485
-175.364807817,0.2797,1.175,72.2536514876,0.161631906162,0.0904,-222.651286485
-175.364807817,2.294,1.884,72.2536514876,0.161631906162,0.0904,-222.651286485
-175.364807817,2.294,5.439,72.2536514876,0.161631906162,0.0904,-222.651286485
-174.898133025,0.1896,1.168,66.2759870813,0.106718445549,0.08171,-337.274809608
-174.898133025,2.204,5.432,66.2759870813,0.106718445549,0.08171,-337.274809608
-174.898133025,0.1896,4.724,66.2759870813,0.106718445549,0.08171,-337.274809608
-174.898133025,2.204,1.876,66.2759870813,0.106718445549,0.08171,-337.274809608
-173.66017784,3.2205,3.9664,48.3718399711,0.662590068278,0.079512,-54.2559890766
-91.9979971858,1.828,5.047,174.103530547,0.0697291705308,0.08393,-516.230305407
-91.9979971858,1.828,1.491,174.103530547,0.0697291705308,0.08394,-516.230295407
-91.7358065418,4.912,4.342,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.09596,-197.995069545
-91.7358065418,4.912,2.564,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.09595,-197.995079545
-91.3972631135,4.912,0.1194,5.xxx-xxxxxxxx,0.146306644698,0.1195,-245.953830727
-90,1.6254,3.5488,0,6.xxx-xxxxxxxx,0.081346,-5.xxx-xxxxxxxx
-90,1.0487,0.11665,0,6.xxx-xxxxxxxx,0.11665,-5.xxx-xxxxxxxx
-88.0907354404,4.909,4.246,174.10342975,0.xxx-xxxxxxxx,0.08725,-180.012852755
-88.0907354404,4.9086,2.468,174.10342975,0.xxx-xxxxxxxx,0.087248,-180.012854755
-87.3972850434,0.39064,1.5357,126.142581958,0.272462125064,0.1374,-131.998996425
-87.3972850434,0.3906,5.091,126.142581958,0.272462125064,0.1374,-131.998996425
-87.0889913849,5.668,0.5096,234.307658901,0.101569726308,0.1221,-354.335519182
-85.9141439029,2.6882,5.2959,78.2293393871,0.427507579388,0.09748,-84.1166137472
-85.9141439029,0.6743,1.032,78.2293393871,0.427507579388,0.09747,-84.1166237472
-85.9141439029,1.133,0.3793,78.2293393871,0.427507579388,0.09747,-84.1166237472
-85.9141439029,0.6743,4.588,78.2293393871,0.427507579388,0.09748,-84.1166137472
-85.9141439029,2.688,1.74,78.2293393871,0.427507579388,0.09747,-84.1166237472
-83.2897724206,2.8748,3.2808,48.3723519881,0.350544294474,0.12481,-102.57879675
-83.2897724206,5.3609,3.9891,48.3723519881,0.350544294474,0.12481,-102.57879675
-80.3106547802,5.384,3.77,213.063820041,0.144262444496,0.08632,-249.473872149
-80.3106547802,2.898,3.062,213.063820041,0.144262444496,0.086316,-249.473876149
-5.xxx-xxxxxxxx,1.529,3.633,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.08763,-60.2151724677
-5.xxx-xxxxxxxx,4.745,2.245,5.xxx-xxxxxxxx,0.543215096158,0.09663,-66.179443001
-5.xxx-xxxxxxxx,4.745,4.023,5.xxx-xxxxxxxx,0.543215096158,0.09663,-66.179443001
-5.xxx-xxxxxxxx,4.745,5.801,5.xxx-xxxxxxxx,0.543215096158,0.09663,-66.179443001
-4.6351921827,1.5977,1.8902,150.488034997,0.161631906162,0.1079,-222.633786485
-4.6351921827,1.5977,5.4458,150.488034997,0.161631906162,0.1079,-222.633786485
-4.xxx-xxxxxxxx,2.9002,4.4319,5.xxx-xxxxxxxx,0.460179455863,0.11282,-78.1222313687
-4.xxx-xxxxxxxx,2.9002,0.8763,5.xxx-xxxxxxxx,0.460179455863,0.11282,-78.1222313687
-4.xxx-xxxxxxxx,1.6757,4.7557,84.2189228599,0.108803649063,0.10557,-330.785569022
-4.xxx-xxxxxxxx,1.6757,1.2002,84.2189228599,0.108803649063,0.10557,-330.785569022
-4.xxx-xxxxxxxx,3.633,4.003,5.xxx-xxxxxxxx,0.427482709362,0.08228,-84.1367131423
-4.xxx-xxxxxxxx,3.633,2.225,5.xxx-xxxxxxxx,0.427482709362,0.08228,-84.1367131423
-4.xxx-xxxxxxxx,3.633,5.78,5.xxx-xxxxxxxx,0.427482709362,0.08228,-84.1367131423
-3.xxx-xxxxxxxx,3.806,2.981,90.2048796036,0.206406468384,0.0845,-174.339119812
-3.xxx-xxxxxxxx,4.994,0.5512,5.xxx-xxxxxxxx,0.399114430128,0.08699,-90.1181257525
-3.xxx-xxxxxxxx,2.125,0.5512,96.1928181463,0.193147008418,0.09029,-186.307437116
-3.xxx-xxxxxxxx,4.929,4.0161,96.1928181463,0.193147008418,0.090289,-186.307438116
-3.xxx-xxxxxxxx,0.9674,0.2115,96.1928181463,0.193147008418,0.1055,-186.292227116
-3.xxx-xxxxxxxx,4.929,5.7939,96.1928181463,0.193147008418,0.090289,-186.307438116
-3.xxx-xxxxxxxx,4.929,2.2383,96.1928181463,0.193147008418,0.090288,-186.307439116
-3.xxx-xxxxxxxx,1.653,5.107,96.1928181463,0.193147008418,0.09029,-186.307437116
-3.xxx-xxxxxxxx,1.653,1.551,96.1928181463,0.193147008418,0.09029,-186.307437116
-3.xxx-xxxxxxxx,0.4588,4.738,108.172888431,0.113026719796,0.08995,-318.437947059
-3.xxx-xxxxxxxx,0.4588,1.182,108.172888431,0.113026719796,0.08995,-318.437947059
-3.2243334976,1.846,1.206,108.172914575,0.0843733204377,0.09024,-426.61056046
-3.2243334976,1.846,4.762,108.172914575,0.0843733204377,0.09024,-426.61056046
-3.xxx-xxxxxxxx,0.3415,4.0045,5.xxx-xxxxxxxx,0.3328203974,0.1048,-108.06814748
-3.xxx-xxxxxxxx,0.3415,2.2267,5.xxx-xxxxxxxx,0.3328203974,0.1048,-108.06814748
-3.xxx-xxxxxxxx,0.3415,5.7823,5.xxx-xxxxxxxx,0.3328203974,0.1048,-108.06814748
-2.xxx-xxxxxxxx,5.737,0.1957,5.xxx-xxxxxxxx,0.299625943166,0.08992,-120.067109754
-2.xxx-xxxxxxxx,3.258,1.196,126.150219622,0.0966611798599,0.1048,-372.352513478
-2.xxx-xxxxxxxx,3.258,4.752,126.150219622,0.0966611798599,0.1048,-372.352513478
-1.xxx-xxxxxxxx,5.589,4.004,5.9972374714,0.193447903454,0.09013,-186.017668148
-1.xxx-xxxxxxxx,5.589,2.227,5.9972374714,0.193447903454,0.09013,-186.017668148
-1.xxx-xxxxxxxx,5.589,5.782,5.9972374714,0.193447903454,0.09013,-186.017668148
-1.xxx-xxxxxxxx,1.833,5.443,5.xxx-xxxxxxxx,0.176394434896,0.09885,-204.001485645
-1.xxx-xxxxxxxx,1.833,1.887,5.xxx-xxxxxxxx,0.176394434896,0.09885,-204.001485645
-1.xxx-xxxxxxxx,2.505,1.196,216.096133672,0.0844735939482,0.09012,-426.104169665
-1.xxx-xxxxxxxx,3.146,0.8734,216.096133672,0.0844735939482,0.1034,-426.090889665
-1.xxx-xxxxxxxx,3.1464,4.429,216.096133672,0.0844735939482,0.10338,-426.090909665
-1.xxx-xxxxxxxx,2.505,4.752,216.096133672,0.0844735939482,0.09012,-426.104169665
0,2.4037,1.1962,0,6.xxx-xxxxxxxx,0.10173,-5.xxx-xxxxxxxx
0,2.7296,1.5459,0,6.xxx-xxxxxxxx,0.093201,-5.xxx-xxxxxxxx
0,5.487,2.2267,0,6.xxx-xxxxxxxx,0.10173,-5.xxx-xxxxxxxx
0,2.4037,4.7518,0,6.xxx-xxxxxxxx,0.10173,-5.xxx-xxxxxxxx
0,5.487,4.0045,0,6.xxx-xxxxxxxx,0.10173,-5.xxx-xxxxxxxx
0,0.71571,0.83758,0,6.xxx-xxxxxxxx,0.093201,-5.xxx-xxxxxxxx
0,2.7296,5.1015,0,6.xxx-xxxxxxxx,0.093201,-5.xxx-xxxxxxxx
0,5.487,5.7823,0,6.xxx-xxxxxxxx,0.10173,-5.xxx-xxxxxxxx
0,0.71571,4.3931,0,6.xxx-xxxxxxxx,0.093201,-5.xxx-xxxxxxxx
0,1.174,0.1848,0,6.xxx-xxxxxxxx,0.093201,-5.xxx-xxxxxxxx
1.xxx-xxxxxxxx,4.964,0.8792,210.098155994,0.0844735939482,0.1034,-426.090889665
1.xxx-xxxxxxxx,2.7147,4.4203,216.096134563,0.082161008999,0.10645,-438.083925299
1.xxx-xxxxxxxx,4.9643,4.4348,210.098155994,0.0844735939482,0.10339,-426.090899665
1.xxx-xxxxxxxx,2.7147,0.86469,216.096134563,0.082161008999,0.10645,-438.083925299
1.xxx-xxxxxxxx,1.4204,1.8786,204.10026371,0.171358764611,0.10178,-209.996392976
1.xxx-xxxxxxxx,1.4204,5.4341,204.10026371,0.171358764611,0.10178,-209.996392976
1.xxx-xxxxxxxx,3.5712,5.4487,198.102572363,0.176394434896,0.098852,-204.001483645
1.xxx-xxxxxxxx,3.5712,1.8931,198.102572363,0.176394434896,0.098852,-204.001483645
1.xxx-xxxxxxxx,5.921,0.8424,390.207735475,0.0611958666389,0.07942,-588.230956919
1.xxx-xxxxxxxx,3.8902,2.9747,186.107703788,0.1874086486,0.093049,-192.012084019
1.xxx-xxxxxxxx,5.9206,4.398,390.207735475,0.0611958666389,0.079424,-588.230952919
3.xxx-xxxxxxxx,1.932,1.8844,102.181828222,0.3328203974,0.1048,-108.06814748
3.xxx-xxxxxxxx,1.932,5.4399,102.181828222,0.3328203974,0.1048,-108.06814748
4.6351921827,5.762,3.6585,72.2536514876,0.161631906162,0.090397,-222.651289485
4.6351921827,3.2759,2.9502,72.2536514876,0.161631906162,0.090397,-222.651289485
5.xxx-xxxxxxxx,5.8521,3.6658,66.2759870813,0.106718445549,0.081706,-337.274813608
5.xxx-xxxxxxxx,3.366,2.9575,66.2759870813,0.106718445549,0.081706,-337.274813608
5.xxx-xxxxxxxx,0,5.7794,259.129120502,0.110637980905,0.094857,-325.310244156
5.xxx-xxxxxxxx,0,2.2238,259.129120502,0.110637980905,0.094858,-325.310243156
6.xxx-xxxxxxxx,2.821,0.8676,48.3718399711,0.662590068278,0.07951,-54.2559910766
6.xxx-xxxxxxxx,2.8212,4.4232,48.3718399711,0.662590068278,0.079513,-54.2559880766
88.0020028142,3.741,3.343,174.103530547,0.0697291705308,0.08393,-516.230305407
90,1.0274,5.884,0,6.xxx-xxxxxxxx,0.093004,-5.xxx-xxxxxxxx
90,1.0274,4.1062,0,6.xxx-xxxxxxxx,0.093004,-5.xxx-xxxxxxxx
90,1.0274,2.3284,0,6.xxx-xxxxxxxx,0.093004,-5.xxx-xxxxxxxx
90,3.9441,1.2852,0,6.xxx-xxxxxxxx,0.081353,-5.xxx-xxxxxxxx
90,3.9441,4.8407,0,6.xxx-xxxxxxxx,0.081346,-5.xxx-xxxxxxxx
93.9007222845,3.5657,0,174.413412724,0.136055825143,0.084861,-264.528310323
153.436295773,5.6055,0.48306,5.xxx-xxxxxxxx,2.xxx-xxxxxxxx,0.048648,-13.3683995515
93.1800166294,3.5657,5.8958,102.175864171,0.332839838393,0.10441,-108.062219157
94.0858560971,5.3674,3.802,78.2293393871,0.427507579388,0.097466,-84.1166277472
94.0858560971,2.8813,3.0936,78.2293393871,0.427507579388,0.09748,-84.1166137472
99.6893452198,0.6576,1.064,213.063820041,0.144262444496,0.08632,-249.473872149
99.6893452198,0.65758,4.6192,213.063820041,0.144262444496,0.08631,-249.473882149
99.6893452198,2.6715,1.772,213.063820041,0.144262444496,0.086316,-249.473876149
99.6893452198,2.6715,5.3275,213.063820041,0.144262444496,0.08631,-249.473882149
146.311486658,3.5222,2.593,13.3134454753,1.xxx-xxxxxxxx,0.052413,-21.5817891887
146.311486658,3.5222,0.1486,13.3134454753,1.xxx-xxxxxxxx,0.052413,-21.5817891887
146.311486658,3.5222,4.3708,13.3134454753,1.xxx-xxxxxxxx,0.052406,-21.5817961887
159.146662192,3.4785,2.6221,51.2660025685,0.266998660381,0.065313,-134.774926711
159.146662192,3.478,0.1777,51.2660025685,0.266998660381,0.06531,-134.774929711
159.146662192,3.4785,4.3999,51.2660025685,0.266998660381,0.065315,-134.774924711
164.292239815,5.562,0.5046,155.777547674,0.180497947893,0.06343,-199.396806465
164.476757375,1.8035,2.9147,68.4135591781,0.321174200439,0.054293,-112.041147166
165.069421166,0.8737,3.929,24.7369993856,0.386495738711,0.05661,-93.0936107198
172.875398093,4.5936,5.4491,5.xxx-xxxxxxxx,0.744209571183,0.059127,-48.3172507869
172.875398093,4.5936,1.8935,5.xxx-xxxxxxxx,0.744209571183,0.059127,-48.3172507869
172.875398093,2.5797,1.1852,5.xxx-xxxxxxxx,0.744209571183,0.059127,-48.3172507869
172.875398093,2.5797,4.7407,5.xxx-xxxxxxxx,0.744209571183,0.059127,-48.3172507869
172.875398093,3.0381,0.5324,5.xxx-xxxxxxxx,0.744209571183,0.059127,-48.3172507869
176.186148662,0.8784,3.283,5.xxx-xxxxxxxx,0.399114430128,0.04369,-90.1614257525
176.633736732,5.1541,3.6491,5.xxx-xxxxxxxx,0.352332435459,0.043423,-102.138947242
-3.xxx-xxxxxxxx,0.23395,4.0103,114.164437035,0.161925908552,0.1077,-222.22956332
-3.xxx-xxxxxxxx,0.23395,5.7881,114.164437035,0.161925908552,0.1077,-222.22956332
-3.xxx-xxxxxxxx,0.23395,2.2325,114.164437035,0.161925908552,0.1077,-222.22956332
-2.7261510073,3.1506,4.7569,5.xxx-xxxxxxxx,0.285391122642,0.10766,-126.042596654
-2.7261510073,3.1506,1.2013,5.xxx-xxxxxxxx,0.285391122642,0.10766,-126.042596654
-2.xxx-xxxxxxxx,2.4825,5.1112,5.xxx-xxxxxxxx,0.214149340329,0.13668,-167.980407416
-2.xxx-xxxxxxxx,0.4687,4.403,5.xxx-xxxxxxxx,0.214149340329,0.1367,-167.980387416
-2.xxx-xxxxxxxx,2.4825,1.5556,5.xxx-xxxxxxxx,0.214149340329,0.13668,-167.980407416
-2.xxx-xxxxxxxx,0.4687,0.8473,5.xxx-xxxxxxxx,0.214149340329,0.1367,-167.980387416
-1.xxx-xxxxxxxx,4.2223,1.8902,5.xxx-xxxxxxxx,0.153795712116,0.11339,-233.977423541
-1.xxx-xxxxxxxx,4.2223,5.4458,5.xxx-xxxxxxxx,0.153795712116,0.11339,-233.977423541
0,0.76294,2.2151,0,6.xxx-xxxxxxxx,0.10753,-5.xxx-xxxxxxxx
0,3.6796,4.7416,0,6.xxx-xxxxxxxx,0.10753,-5.xxx-xxxxxxxx
0,0.76294,3.9929,0,6.xxx-xxxxxxxx,0.10753,-5.xxx-xxxxxxxx
0,3.6796,1.186,0,6.xxx-xxxxxxxx,0.10753,-5.xxx-xxxxxxxx
0,0.76294,5.7706,0,6.xxx-xxxxxxxx,0.10753,-5.xxx-xxxxxxxx
1.xxx-xxxxxxxx,0,4.398,276.081580199,0.127630776505,0.11409,-281.966489263
1.xxx-xxxxxxxx,0,0.84245,276.081580199,0.127630776505,0.11409,-281.966489263
1.xxx-xxxxxxxx,3.3628,4.7467,258.085078737,0.0689473489175,0.11046,-522.058469385
1.xxx-xxxxxxxx,3.3628,1.1911,258.085078737,0.0689473489175,0.11046,-522.058469385
1.xxx-xxxxxxxx,0.44614,2.2209,222.094199845,0.157840203038,0.11047,-227.982010086
1.xxx-xxxxxxxx,0.44614,3.9987,222.094199845,0.157840203038,0.11047,-227.982010086
1.xxx-xxxxxxxx,0.44614,5.7765,222.094199845,0.157840203038,0.11047,-227.982010086
3.xxx-xxxxxxxx,3.2498,0.8705,336.501729833,0.0798865303725,0.10961,-450.556643752
3.xxx-xxxxxxxx,3.2498,4.4261,336.501729833,0.0798865303725,0.10961,-450.556643752
3.xxx-xxxxxxxx,3.4473,2.9648,90.2049089693,0.193147008418,0.11358,-186.284147116
174.289740262,4.4431,5.437,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.087633,-60.2151694677
174.289740262,4.4431,1.8815,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.087633,-60.2151694677
174.289740262,4.0404,4.7565,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.087633,-60.2151694677
174.289740262,4.0404,1.2009,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.087633,-60.2151694677
175.030549886,3.4137,2.9438,72.2533648753,0.259889135104,0.067105,-138.461823321
175.236636986,2.5578,3.9577,5.xxx-xxxxxxxx,0.498273409666,0.07016,-72.1836722732
175.236636986,1.7512,2.9293,5.xxx-xxxxxxxx,0.498273409666,0.069999,-72.1838332732
-1.xxx-xxxxxxxx,5.6452,4.4319,5.xxx-xxxxxxxx,0.146298056317,0.11859,-245.969186382
-1.xxx-xxxxxxxx,5.6452,0.8763,5.xxx-xxxxxxxx,0.146298056317,0.11859,-245.969186382
0,2.0366,1.8902,0,6.xxx-xxxxxxxx,0.11915,-5.xxx-xxxxxxxx
175.426346414,3.4175,4.4232,78.2346855866,0.239235914025,0.072891,-150.415230798
175.426346414,3.417,0.2009,78.2346855866,0.239235914025,0.07289,-150.415231798
175.426346414,3.4175,2.6454,78.2346855866,0.239235914025,0.072891,-150.415230798
175.462493068,0.819,3.943,228.722912797,0.094939658731,0.0732,-379.137804647
176.633736732,5.501,0.5219,5.xxx-xxxxxxxx,0.352332435459,0.07279,-102.109580242
0,3.3592,0.8763,0,6.xxx-xxxxxxxx,0.12462,-5.xxx-xxxxxxxx
0,3.0201,2.9478,0,6.xxx-xxxxxxxx,0.13371,-5.xxx-xxxxxxxx
0,5.5062,3.6561,0,6.xxx-xxxxxxxx,0.13371,-5.xxx-xxxxxxxx
0,3.5206,3.6415,0,6.xxx-xxxxxxxx,0.12771,-5.xxx-xxxxxxxx
0,2.0366,5.4458,0,6.xxx-xxxxxxxx,0.11915,-5.xxx-xxxxxxxx
0,3.3592,4.4319,0,6.xxx-xxxxxxxx,0.12462,-5.xxx-xxxxxxxx
0,1.0345,2.9332,0,6.xxx-xxxxxxxx,0.12771,-5.xxx-xxxxxxxx
1.xxx-xxxxxxxx,3.1538,2.9478,294.078663701,0.119976089136,0.12209,-299.955730735
1.xxx-xxxxxxxx,5.6399,3.6561,294.078663701,0.119976089136,0.12209,-299.955730735
2.xxx-xxxxxxxx,1.7053,5.437,126.149962454,0.272446178192,0.12802,-132.016110658
2.xxx-xxxxxxxx,1.7053,1.8815,126.149962454,0.272446178192,0.12802,-132.016110658
2.xxx-xxxxxxxx,5.88,0.53666,246.307093856,0.0966611798599,0.12019,-372.337123478
3.xxx-xxxxxxxx,5.8736,2.2238,84.2187402083,0.206406468384,0.12674,-174.296879812
3.xxx-xxxxxxxx,5.8736,4.0016,84.2187402083,0.206406468384,0.12674,-174.296879812
3.xxx-xxxxxxxx,5.8736,5.7794,84.2187402083,0.206406468384,0.12674,-174.296879812
96.7102275794,0.6808,0.8449,48.3723519881,0.350544294474,0.1248,-102.57880675
96.7102275794,0.68083,4.4004,48.3723519881,0.350544294474,0.12481,-102.57879675
96.7102275794,2.6947,1.5532,48.3723519881,0.350544294474,0.12481,-102.57879675
96.7102275794,2.6947,5.1088,48.3723519881,0.350544294474,0.12481,-102.57879675
175.364807817,3.9718,2.9438,150.488034997,0.161631906162,0.1079,-222.633786485
175.601552147,3.1415,3.9577,5.xxx-xxxxxxxx,0.460179455863,0.11282,-78.1222313687
175.840601315,3.8938,3.6338,84.2189228599,0.108803649063,0.10557,-330.785569022
175.914622523,5.101,0.8535,5.xxx-xxxxxxxx,0.427482709362,0.0814,-84.1375931423
176.055044902,1.7636,1.8535,90.2048796036,0.206406468384,0.084496,-174.339123812
176.055044902,1.7636,5.409,90.2048796036,0.206406468384,0.084497,-174.339122812
176.055044902,2.236,0.8535,90.2048796036,0.206406468384,0.0845,-174.339119812
2.xxx-xxxxxxxx,3.0127,4.4232,132.143873648,0.260623546428,0.13389,-138.00467753
2.xxx-xxxxxxxx,3.0127,0.86759,132.143873648,0.260623546428,0.13389,-138.00467753
92.6027149566,5.1788,3.2983,126.142581958,0.272462125064,0.13741,-131.998986425
176.308830361,3.9163,3.2828,96.1928181463,0.193147008418,0.090289,-186.307438116
176.760489699,5.1107,3.6516,108.172888431,0.113026719796,0.089947,-318.437950059
176.775666502,3.724,3.628,108.172914575,0.0843733204377,0.09024,-426.61056046
177.709524436,5.0772,4.4114,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.072717,-150.056143183
177.709524436,5.0772,2.6336,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.072716,-150.056144183
177.709524436,5.077,0.1892,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.07272,-150.056140183
177.79753116,1.1708,4.3999,5.9959239092,0.230598904696,0.075618,-156.048988991
177.79753116,1.1708,0.17768,5.9959239092,0.230598904696,0.075617,-156.048989991
177.79753116,1.1708,2.6221,5.9959239092,0.230598904696,0.075617,-156.048989991
178.002237466,1.994,5.108,174.113739103,0.0697250824312,0.0727,-516.271807785
178.002237466,1.994,1.552,174.113739103,0.0697250824312,0.0727,-516.271807785
178.36351909,3.2542,0.50463,5.9979092652,0.171358764611,0.075592,-210.022580976
178.386555846,3.064,3.638,216.096133672,0.0844735939482,0.09012,-426.104169665
180,0.60817,1.1779,0,6.xxx-xxxxxxxx,0.072659,-5.xxx-xxxxxxxx
180,1.7823,3.6479,0,6.xxx-xxxxxxxx,0.072673,-5.xxx-xxxxxxxx
180,1.2153,2.6319,0,6.xxx-xxxxxxxx,0.048611,-5.xxx-xxxxxxxx
180,0.92632,5.4283,0,6.xxx-xxxxxxxx,0.043593,-5.xxx-xxxxxxxx
180,3.6566,3.2832,0,6.xxx-xxxxxxxx,0.049398,-5.xxx-xxxxxxxx
180,6,0.17754,0,6.xxx-xxxxxxxx,0.077026,-5.xxx-xxxxxxxx
180,6,4.3998,0,6.xxx-xxxxxxxx,0.077026,-5.xxx-xxxxxxxx
180,6,4.7478,0,6.xxx-xxxxxxxx,0.061713,-5.xxx-xxxxxxxx
180,0.60817,4.7335,0,6.xxx-xxxxxxxx,0.072659,-5.xxx-xxxxxxxx
180,5.326,3.9964,0,6.xxx-xxxxxxxx,0.093208,-5.xxx-xxxxxxxx
180,2.8399,3.2881,0,6.xxx-xxxxxxxx,0.093201,-5.xxx-xxxxxxxx
180,6,1.1922,0,6.xxx-xxxxxxxx,0.061713,-5.xxx-xxxxxxxx
180,0.17048,3.9915,0,6.xxx-xxxxxxxx,0.049398,-5.xxx-xxxxxxxx
180,2.6221,5.4418,0,6.xxx-xxxxxxxx,0.072659,-5.xxx-xxxxxxxx
180,2.6221,1.8862,0,6.xxx-xxxxxxxx,0.072659,-5.xxx-xxxxxxxx
180,0.92632,1.8728,0,6.xxx-xxxxxxxx,0.043593,-5.xxx-xxxxxxxx
-179.131999559,3.3315,3.6403,390.069317128,0.0908987189476,0.1657,-395.903285185
-179.157525248,3.607,3.283,402.068653838,0.0882258139536,0.1657,-407.902661797
-178.386555846,1.107,0.5187,210.098155994,0.0844735939482,0.1611,-426.033189665
-178.191366909,1.8151,5.1015,378.212877971,0.0631264721246,0.1611,-570.156900619
-178.191366909,1.8151,1.5459,378.212877971,0.0631264721246,0.1611,-570.156900619
-177.739630803,4.872,2.64,150.128839457,0.0788859926616,0.1473,-456.234906188
-177.739630803,4.872,4.418,150.128839457,0.0788859926616,0.1473,-456.234906188
-177.739630803,4.872,0.196,150.128839457,0.0788859926616,0.1473,-456.234906188
-176.248490793,4.0486,3.644,90.2050623552,0.0981499532634,0.15516,-366.652588462
-90,1.2223,2.8828,0,6.xxx-xxxxxxxx,0.14823,-5.xxx-xxxxxxxx
-90,1.625,3.5633,0,6.xxx-xxxxxxxx,0.14823,-5.xxx-xxxxxxxx
-88.2375054579,3.57,0.1843,192.093842656,0.0922695058574,0.1844,-390.000450712
-87.9298477877,3.57,4.407,330.218345233,0.072246270557,0.1571,-498.168461868
-87.9298477877,3.57,2.629,330.218345233,0.072246270557,0.157,-498.168561868
-86.4962629496,3.7361,3.1927,96.1873250226,0.122227363769,0.14268,-294.408083904
-84.2890734434,0.6605,1.171,54.3291049783,0.597057450135,0.1392,-60.1601285824
-84.2890734434,0.6605,4.726,54.3291049783,0.597057450135,0.1392,-60.1601285824
-84.2890734434,2.6744,5.4345,54.3291049783,0.597057450135,0.13924,-60.1600885824
-84.2890734434,2.6744,1.8789,54.3291049783,0.597057450135,0.13925,-60.1600785824
-84.2890734434,1.119,0.5178,54.3291049783,0.597057450135,0.1392,-60.1601285824
-3.xxx-xxxxxxxx,5.1789,2.2325,198.375012279,0.122220233982,0.14268,-294.425266692
-3.xxx-xxxxxxxx,5.1789,5.7881,198.375012279,0.122220233982,0.14268,-294.425266692
-3.xxx-xxxxxxxx,5.1789,4.0103,198.375012279,0.122220233982,0.14268,-294.425266692
-3.xxx-xxxxxxxx,2.0956,4.7569,114.164501737,0.106989531292,0.14262,-336.359119315
-3.xxx-xxxxxxxx,2.0956,1.2013,114.164501737,0.106989531292,0.14262,-336.359119315
-1.xxx-xxxxxxxx,5.8522,2.9699,252.086381327,0.0722682290479,0.1478,-498.026347098
0,3.0111,4.7569,0,6.xxx-xxxxxxxx,0.1395,-5.xxx-xxxxxxxx
0,5.0191,2.2325,0,6.xxx-xxxxxxxx,0.15986,-5.xxx-xxxxxxxx
0,5.0191,5.7881,0,6.xxx-xxxxxxxx,0.15986,-5.xxx-xxxxxxxx
0,5.0191,4.0103,0,6.xxx-xxxxxxxx,0.15986,-5.xxx-xxxxxxxx
0,1.9357,4.7569,0,6.xxx-xxxxxxxx,0.15986,-5.xxx-xxxxxxxx
0,0.094455,2.2325,0,6.xxx-xxxxxxxx,0.1395,-5.xxx-xxxxxxxx
0,1.9357,1.2013,0,6.xxx-xxxxxxxx,0.15986,-5.xxx-xxxxxxxx
0,0.094455,5.7881,0,6.xxx-xxxxxxxx,0.1395,-5.xxx-xxxxxxxx
0,1.6719,3.2946,0,6.xxx-xxxxxxxx,0.13951,-5.xxx-xxxxxxxx
0,3.0111,1.2013,0,6.xxx-xxxxxxxx,0.1395,-5.xxx-xxxxxxxx
-178.246698125,0.1895,3.297,390.207735475,0.0611958666389,0.1896,-588.120776919
0.xxx-xxxxxxxx,1.962,1.551,402.068653838,0.0882258139536,0.1657,-407.902661797
0.868000441202,2.238,1.1937,390.069317128,0.0908987189476,0.1657,-395.903285185
0.xxx-xxxxxxxx,1.962,5.106,402.068653838,0.0882258139536,0.1657,-407.902661797
0.881352203661,2.238,4.7492,384.069681006,0.0922968324087,0.1657,-389.903627719
1.xxx-xxxxxxxx,5.3213,2.2238,336.073517412,0.105247033626,0.1657,-341.907250922
1.xxx-xxxxxxxx,5.3213,4.0016,336.073517412,0.105247033626,0.1657,-341.907250922
1.xxx-xxxxxxxx,5.3213,5.7794,336.073517412,0.105247033626,0.1657,-341.907250922
1.xxx-xxxxxxxx,3.7544,3.2881,378.212877971,0.0631264721246,0.1611,-570.156900619
3.3175866142,0.8126,0.2025,102.182333366,0.0868108486076,0.1551,-414.564534074
3.7311783203,5.8263,0.19119,90.2050218487,0.130158392922,0.17403,-276.428673521
3.7515092069,1.5209,4.7456,90.2050623552,0.0981499532634,0.15515,-366.652598462
3.7515092069,1.5209,1.19,90.2050623552,0.0981499532634,0.15515,-366.652598462
4.xxx-xxxxxxxx,4.6034,5.7891,72.2537657696,0.0980319904319,0.14197,-367.107161734
4.xxx-xxxxxxxx,4.6034,4.0113,72.2537657696,0.0980319904319,0.14197,-367.107161734
4.xxx-xxxxxxxx,4.6034,2.2335,72.2537657696,0.0980319904319,0.14197,-367.107161734
87.1374268171,4.8807,5.8297,5.xxx-xxxxxxxx,0.299643465716,0.17047,-119.979533212
87.2735290101,4.8807,0,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.17872,-125.96415621
90,3.9444,1.2707,0,6.xxx-xxxxxxxx,0.14825,-5.xxx-xxxxxxxx
90,3.9444,4.8262,0,6.xxx-xxxxxxxx,0.14823,-5.xxx-xxxxxxxx
90,4.3472,5.5068,0,6.xxx-xxxxxxxx,0.14823,-5.xxx-xxxxxxxx
90,4.3472,1.9512,0,6.xxx-xxxxxxxx,0.14825,-5.xxx-xxxxxxxx
92.3860841011,5.6491,0.29553,138.130253738,0.249798088462,0.14023,-143.984825519
95.7109265566,5.3812,3.6634,54.3291049783,0.597057450135,0.13925,-60.1600785824
95.7109265566,2.8951,2.9551,54.3291049783,0.597057450135,0.13924,-60.1600885824
91.7624945421,3.5657,4.118,192.093842656,0.0922695058574,0.18901,-389.995840712
91.7624945421,3.5657,2.3402,192.093842656,0.0922695058574,0.189,-389.995850712
93.3666580706,5.1679,0.64129,96.1867573104,0.352353000825,0.14266,-102.033746285
93.5037370504,1.8334,1.6413,96.1873250226,0.122227363769,0.14268,-294.408083904
93.5037370504,1.8334,5.1968,96.1873250226,0.122227363769,0.14268,-294.408083904
93.5037370504,2.3056,0.64129,96.1873250226,0.122227363769,0.14268,-294.408083904
176.933694376,3.4739,3.6327,114.164501737,0.106989531292,0.14262,-336.359119315
177.273848993,2.4189,3.6327,5.xxx-xxxxxxxx,0.285391122642,0.10766,-126.042596654
177.229946758,2.3113,3.6378,126.150219622,0.0966611798599,0.10476,-372.352553478
177.95471162,5.573,3.9867,5.xxx-xxxxxxxx,0.214149340329,0.13668,-167.980407416
177.95471162,3.0869,3.2784,5.xxx-xxxxxxxx,0.214149340329,0.13668,-167.980407416
178.315414636,3.7363,2.9467,5.xxx-xxxxxxxx,0.176394434896,0.098852,-204.001483645
178.386555846,2.8953,3.9606,216.096133672,0.0844735939482,0.10338,-426.090909665
178.531285571,1.3472,2.9438,5.xxx-xxxxxxxx,0.153795712116,0.11339,-233.977423541
178.602901054,0.39647,3.9577,5.xxx-xxxxxxxx,0.146298056317,0.11859,-245.969186382
180,2.6825,3.9577,0,6.xxx-xxxxxxxx,0.12462,-5.xxx-xxxxxxxx
180,3.1658,3.6378,0,6.xxx-xxxxxxxx,0.10173,-5.xxx-xxxxxxxx
180,0.98092,4.3969,0,6.xxx-xxxxxxxx,0.13951,-5.xxx-xxxxxxxx
180,2.5494,5.4418,0,6.xxx-xxxxxxxx,0.13371,-5.xxx-xxxxxxxx
180,2.5584,3.6327,0,6.xxx-xxxxxxxx,0.1395,-5.xxx-xxxxxxxx
180,0.98092,2.6191,0,6.xxx-xxxxxxxx,0.13951,-5.xxx-xxxxxxxx
180,3.5329,2.9438,0,6.xxx-xxxxxxxx,0.11915,-5.xxx-xxxxxxxx
180,3.8976,5.0949,0,6.xxx-xxxxxxxx,0.13951,-5.xxx-xxxxxxxx
180,0.98092,0.17464,0,6.xxx-xxxxxxxx,0.13951,-5.xxx-xxxxxxxx
180,4.535,5.4564,0,6.xxx-xxxxxxxx,0.12771,-5.xxx-xxxxxxxx
180,2.5494,1.8862,0,6.xxx-xxxxxxxx,0.13371,-5.xxx-xxxxxxxx
180,2.9794,0.5397,0,6.xxx-xxxxxxxx,0.12771,-5.xxx-xxxxxxxx
180,2.5211,4.748,0,6.xxx-xxxxxxxx,0.12771,-5.xxx-xxxxxxxx
180,0.53551,1.1779,0,6.xxx-xxxxxxxx,0.13371,-5.xxx-xxxxxxxx
180,0.53551,4.7335,0,6.xxx-xxxxxxxx,0.13371,-5.xxx-xxxxxxxx
180,2.5211,1.1925,0,6.xxx-xxxxxxxx,0.12771,-5.xxx-xxxxxxxx
180,3.8976,1.5394,0,6.xxx-xxxxxxxx,0.13951,-5.xxx-xxxxxxxx
180,1.8899,3.6479,0,6.xxx-xxxxxxxx,0.10753,-5.xxx-xxxxxxxx
180,4.535,1.9008,0,6.xxx-xxxxxxxx,0.12771,-5.xxx-xxxxxxxx
180,6,0.51191,0,6.xxx-xxxxxxxx,0.10862,-5.xxx-xxxxxxxx
-179.409377496,5.428,0.5262,576.065478037,0.0618524244924,0.2093,-581.856215841
-179.415403836,5.891,0.5119,582.065512622,0.0612213433449,0.223,-587.842556899
-179.34897788,0.6136,5.094,522.065499746,0.0681774618505,0.223,-527.842469013
-179.341495522,0.6136,1.538,516.065543884,0.0689610079171,0.223,-521.842504197
-179.181592633,3.774,0.1872,414.068070284,0.0857055982441,0.2038,-419.864014773
-179.204323207,3.345,0.2067,426.067559734,0.0833253528386,0.2093,-431.858037752
-179.181592633,3.7742,4.4095,414.068070284,0.0857055982441,0.2038,-419.864014773
-179.181592633,3.7742,2.6317,414.068070284,0.0857055982441,0.2038,-419.864014773
-179.204323207,3.345,2.651,426.067559734,0.0833253528386,0.2093,-431.858037752
-179.204323207,3.3449,4.429,426.067559734,0.0833253528386,0.20929,-431.858047752
-178.025181966,2.7792,3.6403,168.116960256,0.xxx-xxxxxxxx,0.22102,-173.892733063
-90,1.0487,6,0,6.xxx-xxxxxxxx,0.20598,-5.xxx-xxxxxxxx
-90,3.1321,0.45936,0,6.xxx-xxxxxxxx,0.23929,-5.xxx-xxxxxxxx
-90,1.2223,2.9264,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
-90,0.26576,3.9402,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
-2.xxx-xxxxxxxx,0.5566,4.002,144.133472315,0.xxx-xxxxxxxx,0.2066,-426.198808949
-2.xxx-xxxxxxxx,0.5566,5.779,144.133472315,0.xxx-xxxxxxxx,0.2066,-426.198808949
-2.xxx-xxxxxxxx,0.5566,2.224,144.133472315,0.xxx-xxxxxxxx,0.2066,-426.198808949
-2.xxx-xxxxxxxx,3.4732,1.1937,5.xxx-xxxxxxxx,0.222070127383,0.20651,-161.914184901
-2.xxx-xxxxxxxx,3.4732,4.7492,5.xxx-xxxxxxxx,0.222070127383,0.20651,-161.914184901
-1.xxx-xxxxxxxx,0.6313,2.992,5.xxx-xxxxxxxx,0.153795712116,0.2268,-233.864013541
-0.616023704664,0.9907,2.926,6.0000097937,0.xxx-xxxxxxxx,0.2315,-557.833919465
0,5.6788,5.7794,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
0,5.6788,2.2238,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
0,2.5955,1.1937,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
0,5.6788,4.0016,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
0,2.5955,4.7492,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
0,0,4.0103,0,6.xxx-xxxxxxxx,0.23395,-5.xxx-xxxxxxxx
0.xxx-xxxxxxxx,4.956,3.296,522.065499746,0.0681774618505,0.223,-527.842469013
1.xxx-xxxxxxxx,2.7902,1.1937,168.116960256,0.xxx-xxxxxxxx,0.22102,-173.892733063
1.xxx-xxxxxxxx,2.7902,4.7492,168.116960256,0.xxx-xxxxxxxx,0.22102,-173.892733063
90,5.7759,4.4493,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
90,5.7759,0.89375,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
90,4.3472,1.9076,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
90,4.3472,5.4632,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
177.879028149,2.0962,3.6403,5.xxx-xxxxxxxx,0.222070127383,0.20651,-161.914184901
180,3.6338,3.6327,0,6.xxx-xxxxxxxx,0.15986,-5.xxx-xxxxxxxx
178.47256429,2.5532,0.84184,228.092466067,0.0799716267947,0.21844,-449.968267601
88.0473762816,1.116,0.2341,354.203582358,0.0681462778867,0.2712,-528.035913531
178.531285571,4.9382,5.3974,5.xxx-xxxxxxxx,0.153795712116,0.22679,-233.864023541
178.531285571,4.9382,1.8418,5.xxx-xxxxxxxx,0.153795712116,0.22679,-233.864023541
178.531285571,5.4382,0.84184,5.xxx-xxxxxxxx,0.153795712116,0.22679,-233.864023541
180,0.20562,0.51191,0,6.xxx-xxxxxxxx,0.20562,-5.xxx-xxxxxxxx
180,2.974,3.6403,0,6.xxx-xxxxxxxx,0.19474,-5.xxx-xxxxxxxx
-178.264397358,4.5879,2.6299,192.105047057,0.xxx-xxxxxxxx,0.28788,-197.814770896
-178.264397358,5.5602,3.3105,192.105047057,0.xxx-xxxxxxxx,0.28788,-197.814770896
-91.7358065418,3.7451,3.6084,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.30519,-197.785839545
-90,1.0487,2.5611,0,6.xxx-xxxxxxxx,0.32262,-5.xxx-xxxxxxxx
-90,1.0487,4.3389,0,6.xxx-xxxxxxxx,0.32262,-5.xxx-xxxxxxxx
-1.4877801245,3.888,5.4545,234.09080058,0.0778958606041,0.33436,-461.848907365
-1.4877801245,3.888,1.8989,234.09080058,0.0778958606041,0.33436,-461.848907365
0,4.6555,3.2957,0,6.xxx-xxxxxxxx,0.30035,-5.xxx-xxxxxxxx
1.xxx-xxxxxxxx,0.98154,5.7597,192.105047057,0.xxx-xxxxxxxx,0.28788,-197.814770896
1.xxx-xxxxxxxx,0.98154,2.2041,192.105047057,0.xxx-xxxxxxxx,0.28788,-197.814770896
180,4.0487,4.4095,0,6.xxx-xxxxxxxx,0.2745,-5.xxx-xxxxxxxx
180,0.28712,1.8418,0,6.xxx-xxxxxxxx,0.28712,-5.xxx-xxxxxxxx
180,4.0487,2.6317,0,6.xxx-xxxxxxxx,0.2745,-5.xxx-xxxxxxxx
180,4.0487,0.18724,0,6.xxx-xxxxxxxx,0.2745,-5.xxx-xxxxxxxx
180,0.28712,5.3974,0,6.xxx-xxxxxxxx,0.28712,-5.xxx-xxxxxxxx
-179.607592354,3.4415,3.2808,870.072394872,0.0410949536904,0.3546,-875.71801075
-179.607592354,5.9276,3.9891,870.072394872,0.0410949536904,0.3546,-875.71801075
-179.53040058,0.8827,1.873,726.067938989,0.0491787084569,0.3546,-731.713494057
-179.53040058,5.9383,4.7478,726.067938989,0.0491787084569,0.35461,-731.713484057
-179.53040058,5.9383,1.1922,726.067938989,0.0491787084569,0.35461,-731.713484057
-179.53040058,0.8827,5.428,726.067938989,0.0491787084569,0.3546,-731.713494057
-1.xxx-xxxxxxxx,5.296,0.885,5.xxx-xxxxxxxx,0.149953251354,0.3497,-239.739548104
-1.xxx-xxxxxxxx,5.2956,4.4406,5.xxx-xxxxxxxx,0.149953251354,0.34969,-239.739558104
-0.923991055015,4.286,2.967,5.9995763649,0.0967616735988,0.3575,-371.712990611
-0.939135758326,5.258,3.648,5.xxx-xxxxxxxx,0.0983475078448,0.3575,-365.713427034
-0.451112033969,0,2.9641,6.xxx-xxxxxxxx,0.0472426613131,0.37067,-761.698239065
-0.392407646473,2.73,3.292,6.xxx-xxxxxxxx,0.0410949536904,0.372,-875.70061075
0.392407646473,2.128,1.5532,870.072394872,0.0410949536904,0.3546,-875.71801075
0.392407646473,0.1141,4.4,870.072394872,0.0410949536904,0.3546,-875.71801075
0.392407646473,2.128,5.1088,870.072394872,0.0410949536904,0.3546,-875.71801075
0.392407646473,0.1141,0.8449,870.072394872,0.0410949536904,0.3546,-875.71801075
0.469599420424,4.687,2.961,726.067938989,0.0491787084569,0.3546,-731.713494057
0.489666814576,5.659,3.6418,696.067224305,0.0512802123103,0.34105,-701.72631178
1.xxx-xxxxxxxx,0,1.5235,198.102572363,0.176394434896,0.29719,-203.803145645
1.xxx-xxxxxxxx,0,5.0791,198.102572363,0.176394434896,0.29719,-203.803145645
0.970964873966,0,1.5367,348.072385492,0.xxx-xxxxxxxx,0.3453,-353.726580511
88.2641934582,1.8244,4.7812,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.30519,-197.785839545
88.2641934582,1.8244,1.2256,5.xxx-xxxxxxxx,0.xxx-xxxxxxxx,0.3052,-197.785829545
178.512219875,1.6815,2.9351,234.09080058,0.0778958606041,0.33436,-461.848907365
178.939150646,0.31159,4.742,5.xxx-xxxxxxxx,0.111092139535,0.31165,-323.763154202
178.939150646,0.31159,1.1864,5.xxx-xxxxxxxx,0.111092139535,0.31165,-323.763154202
180,0.91395,5.0938,0,6.xxx-xxxxxxxx,0.30035,-5.xxx-xxxxxxxx
180,0.91395,1.5383,0,6.xxx-xxxxxxxx,0.30035,-5.xxx-xxxxxxxx
88.6027368865,4.8807,4.052,5.xxx-xxxxxxxx,0.146306644698,0.34889,-245.724440727
88.6027368865,4.8807,2.2742,5.xxx-xxxxxxxx,0.146306644698,0.34887,-245.724460727
178.567987947,0.74605,3.949,5.xxx-xxxxxxxx,0.149953251354,0.34969,-239.739558104
-0.830266694525,1.231,2.6386,5.9997266205,0.0869474494188,0.39822,-413.669859154
179.076008945,1.2838,5.4225,5.9995763649,0.0967616735988,0.35754,-371.712950611
179.060864242,1.2838,1.8669,5.xxx-xxxxxxxx,0.0983475078448,0.35754,-365.713387034
-0.795676793194,0.2749,3.653,5.999778018,0.0833253528386,0.4165,-431.650837752
179.157525248,6,2.6154,5.xxx-xxxxxxxx,0.0882258139536,0.39485,-407.673511797
179.157525248,4.3385,2.1954,5.xxx-xxxxxxxx,0.0882258139536,0.39822,-407.670141797
179.169733305,4.3385,5.7509,5.9997266205,0.0869474494188,0.39822,-413.669859154
179.204323207,5.7668,4.7371,5.999778018,0.0833253528386,0.41649,-431.650847752
179.204323207,5.7668,1.1815,5.999778018,0.0833253528386,0.41649,-431.650847752
179.545307862,5.923,4.3998,6.xxx-xxxxxxxx,0.0476175795499,0.37204,-755.696699917
179.552412135,5.923,0.17754,6.xxx-xxxxxxxx,0.0468736006333,0.37204,-767.697041141
179.602142421,2.8396,1.5419,6.xxx-xxxxxxxx,0.0416656896039,0.37204,-863.700142902
179.607592354,2.8396,5.0975,6.xxx-xxxxxxxx,0.0410949536904,0.37204,-875.70057075
180,0.34441,4.3998,0,6.xxx-xxxxxxxx,0.34441,-5.xxx-xxxxxxxx
180,0.34441,2.622,0,6.xxx-xxxxxxxx,0.34441,-5.xxx-xxxxxxxx
180,0.34441,0.17754,0,6.xxx-xxxxxxxx,0.34441,-5.xxx-xxxxxxxx
-179.169733305,3.702,0.5111,408.068352534,0.0869474494188,0.4476,-413.620479154
-178.876763287,1.6184,4.4086,300.077797681,0.117624529832,0.44768,-305.629321283
-178.876763287,1.618,0.1864,300.077797681,0.117624529832,0.4477,-305.629301283
-178.876763287,1.6184,2.6308,300.077797681,0.117624529832,0.44768,-305.629321283
0,2.3084,3.2921,0,6.xxx-xxxxxxxx,0.42144,-5.xxx-xxxxxxxx
180,3.2611,5.0975,0,6.xxx-xxxxxxxx,0.42144,-5.xxx-xxxxxxxx
180,3.2611,1.5419,0,6.xxx-xxxxxxxx,0.42144,-5.xxx-xxxxxxxx
-0.923991055015,3.102,3.29,5.9995763649,0.0967616735988,0.4738,-371.596690611
-0.295319097003,1.8114,3.2946,6.xxx-xxxxxxxx,0.0309274446224,0.497,-1163.58764417
0,4.4627,0.87922,0,6.xxx-xxxxxxxx,0.50159,-5.xxx-xxxxxxxx
0,4.4627,4.4348,0,6.xxx-xxxxxxxx,0.50159,-5.xxx-xxxxxxxx
0,3.0916,5.4487,0,6.xxx-xxxxxxxx,0.47957,-5.xxx-xxxxxxxx
0,3.0916,1.8931,0,6.xxx-xxxxxxxx,0.47957,-5.xxx-xxxxxxxx
178.854304482,6,3.3017,5.xxx-xxxxxxxx,0.119976089136,0.43993,-299.637890735
178.939150646,5.5509,0.18045,5.xxx-xxxxxxxx,0.111092139535,0.47384,-323.600964202
178.939150646,5.5509,2.6249,5.xxx-xxxxxxxx,0.111092139535,0.47384,-323.600964202
178.939150646,5.5509,4.4027,5.xxx-xxxxxxxx,0.111092139535,0.47384,-323.600964202
179.076008945,2.4676,1.5445,5.9995763649,0.0967616735988,0.47382,-371.596670611
179.076008945,2.4676,5.1,5.9995763649,0.0967616735988,0.47382,-371.596670611
179.627976578,6,2.622,6.xxx-xxxxxxxx,0.0389602433679,0.44907,-923.625326257
-1.xxx-xxxxxxxx,0.3939,2.97,5.xxx-xxxxxxxx,0.157840203038,0.5299,-227.562580086
179.704680903,3.7581,5.0949,6.xxx-xxxxxxxx,0.0309274446224,0.497,-1163.58764417
179.664960473,0.8414,2.6191,6.0002540173,0.035087142548,0.497,-1025.58152204
179.6609956,0.8414,4.3969,6.0002515749,0.0355023605529,0.497,-1013.58101643
179.704680903,3.7581,1.5394,6.xxx-xxxxxxxx,0.0309274446224,0.497,-1163.58764417
180,2.4778,2.9409,0,6.xxx-xxxxxxxx,0.47957,-5.xxx-xxxxxxxx
179.681712095,0.5281,5.425,6.xxx-xxxxxxxx,0.033332840984,0.5281,-1079.55275436
179.664960473,0.8414,0.17464,6.0002540173,0.035087142548,0.497,-1025.58152204
179.681712095,0.5281,1.87,6.xxx-xxxxxxxx,0.033332840984,0.5281,-1079.55275436
180,1.579,3.9548,0,6.xxx-xxxxxxxx,0.50159,-5.xxx-xxxxxxxx
-0.868000441202,5.423,2.213,5.9996680577,0.0908987189476,0.5775,-395.491485185
-0.868000441202,5.423,5.768,5.9996680577,0.0908987189476,0.5775,-395.491485185
179.090672987,0.5496,3.302,5.xxx-xxxxxxxx,0.0952261639677,0.5497,-377.520379358
0.550871603974,4.39,0.5454,618.065851394,0.0576896792455,0.6047,-623.461230667
180,6,0.84184,0,6.xxx-xxxxxxxx,0.56184,-5.xxx-xxxxxxxx
-179.46952986,4.5441,3.2886,642.066189407,0.0555532111269,0.62782,-647.438468842
-179.754111329,5.224,3.292,1392.0956622,0.0257508528076,0.6801,-1397.41586355
-179.029035126,4.211,3.9867,348.072385492,0.xxx-xxxxxxxx,0.71119,-353.360690511
-179.012297641,1.7249,3.2784,342.072935284,0.103432973521,0.71119,-347.361210344
-178.754708902,4.717,0.2018,270.082670281,0.130404062071,0.6681,-275.413509701
-178.754708902,4.7166,2.6462,270.082670281,0.130404062071,0.66806,-275.413549701
-178.754708902,4.7166,4.424,270.082670281,0.130404062071,0.66806,-275.413549701
-1.xxx-xxxxxxxx,2.357,0.5483,5.xxx-xxxxxxxx,0.113187478695,0.6216,-317.453895481
-1.xxx-xxxxxxxx,4.7347,5.1038,5.xxx-xxxxxxxx,0.107125851153,0.64534,-335.428193892
-1.xxx-xxxxxxxx,5.235,0.5483,5.xxx-xxxxxxxx,0.107125851153,0.6453,-335.428233892
-1.xxx-xxxxxxxx,4.7347,1.5483,5.xxx-xxxxxxxx,0.107125851153,0.64534,-335.428193892
0,0,2.9922,0,6.xxx-xxxxxxxx,0.63131,-5.xxx-xxxxxxxx
0.xxx-xxxxxxxx,5.38,1.5367,630.066010038,0.0566012925174,0.62008,-635.446019677
0.530470140303,1.025,5.101,642.066189407,0.0555532111269,0.6278,-647.438488842
0.xxx-xxxxxxxx,5.38,5.0922,630.066010038,0.0566012925174,0.62008,-635.446019677
0.530470140303,1.025,1.545,642.066189407,0.0555532111269,0.6278,-647.438488842
0.530470140303,1.498,0.5454,642.066189407,0.0555532111269,0.6278,-647.438488842
-179.118647796,0.9364,0.5232,384.069681006,0.0922968324087,0.7309,-389.338427719
-179.012297641,1.6448,5.1065,342.072935284,0.103432973521,0.73091,-347.341490344
-179.012297641,1.6448,1.551,342.072935284,0.103432973521,0.73091,-347.341490344
-0.489666814576,2.833,5.8,6.xxx-xxxxxxxx,0.0512802123103,0.683,-701.38436178
-0.489666814576,2.833,2.244,6.xxx-xxxxxxxx,0.0512802123103,0.683,-701.38436178
-0.489666814576,2.833,4.022,6.xxx-xxxxxxxx,0.0512802123103,0.683,-701.38436178
-0.362605362559,4.917,0.2244,6.xxx-xxxxxxxx,0.0379739481099,0.683,-947.392329541
0.254631266628,3.735,0.5425,1344.09327113,0.0266664209124,0.6551,-1349.43846848
178.977029923,0.83476,3.2857,5.xxx-xxxxxxxx,0.107125851153,0.64534,-335.428193892
-1.xxx-xxxxxxxx,0.7967,3.651,5.xxx-xxxxxxxx,0.142816766615,0.7326,-251.353791686
0,5.2824,2.9922,0,6.xxx-xxxxxxxx,0.71765,-5.xxx-xxxxxxxx
0.244837877979,0.8175,0.5425,1398.09596331,0.0256408084418,0.6801,-1403.41616513
0.244837877979,0.3453,1.542,1398.09596331,0.0256408084418,0.6801,-1403.41616513
0.970964873966,3.8446,1.5556,348.072385492,0.xxx-xxxxxxxx,0.71119,-353.360690511
0.987702359363,1.8307,4.4029,342.072935284,0.103432973521,0.71119,-347.361210344
0.987702359363,3.8446,5.1112,342.072935284,0.103432973521,0.71119,-347.361210344
0.970964873966,2.289,0.19453,348.072385492,0.xxx-xxxxxxxx,0.71119,-353.360690511
0.970964873966,1.8307,0.8473,348.072385492,0.xxx-xxxxxxxx,0.71119,-353.360690511
-179.5692381,6,3.2973,792.06979612,0.0451115367431,0.77581,-797.294173144
0.987702359363,3.9247,3.283,342.072935284,0.103432973521,0.73091,-347.341490344
178.636152598,5.1756,5.4196,5.xxx-xxxxxxxx,0.142816766615,0.73263,-251.353761686
178.636152598,5.1756,1.864,5.xxx-xxxxxxxx,0.142816766615,0.73263,-251.353761686
178.636152598,4.7728,4.739,5.xxx-xxxxxxxx,0.142816766615,0.73263,-251.353761686
178.636152598,4.7728,1.1835,5.xxx-xxxxxxxx,0.142816766615,0.73263,-251.353761686
-0.211410155612,5.041,2.964,6.xxx-xxxxxxxx,0.0221400852872,0.7877,-1625.32000922
-0.215383993626,0,3.6447,6.xxx-xxxxxxxx,0.0225562464772,0.77344,-1595.33269427
0.444118331295,2.979,0.5367,768.069079733,0.0465102613048,0.7559,-773.313356078
0.409224556857,0,0.53666,834.071148108,0.0428560779948,0.8175,-839.253851666
179.787806851,5.5837,1.1893,6.xxx-xxxxxxxx,0.0222220844805,0.78766,-1619.31973361
179.787806851,5.5837,4.7449,6.xxx-xxxxxxxx,0.0222220844805,0.78766,-1619.31973361
-179.421308444,3.347,2.95,588.065553776,0.0606030093407,0.8691,-593.19650433
0.440702171704,4.074,0.2179,774.069254703,0.0461525113122,0.8429,-779.22653381
0.590622503525,1.99,5.791,576.065478037,0.0618524244924,0.8429,-581.222615841
0.795676793194,0,0.19119,426.067559734,0.0833253528386,0.81264,-431.254697752
179.792419705,6.0004,5.4254,6.xxx-xxxxxxxx,0.0217390020988,0.80155,-1655.30774171
179.792419705,6.0004,1.8699,6.xxx-xxxxxxxx,0.0217390020988,0.80155,-1655.30774171
-179.443780462,2.488,3.963,612.065780224,0.0582497206895,0.909,-617.156854086
0.550871603974,3.554,0.8705,618.065851394,0.0576896792455,0.909,-623.156930667
0.578691555576,2.223,5.44,588.065553776,0.0606030093407,0.8691,-593.19650433
0.590622503525,1.99,4.013,576.065478037,0.0618524244924,0.8429,-581.222615841
0.578691555576,2.223,1.884,588.065553776,0.0606030093407,0.8691,-593.19650433
0.590622503525,1.99,2.236,576.065478037,0.0618524244924,0.8429,-581.222615841
0.734477870366,3.231,0.2071,462.066409268,0.0769168074167,0.8429,-467.223372865
0.550871603974,3.554,4.426,618.065851394,0.0576896792455,0.909,-623.156930667
0.939135758326,3.715,5.775,360.071376455,0.0983475078448,0.8888,-365.182127034
0.939135758326,3.715,3.997,360.071376455,0.0983475078448,0.8888,-365.182127034
0.939135758326,3.7147,2.219,360.071376455,0.0983475078448,0.88876,-365.182167034
0.987702359363,1.1476,5.7766,342.072935284,0.103432973521,0.84299,-347.229410344
0.987702359363,1.1476,3.9988,342.072935284,0.103432973521,0.84299,-347.229410344
0.987702359363,1.1476,2.221,342.072935284,0.103432973521,0.84299,-347.229410344
-179.396944247,1.1667,2.6319,564.065429413,0.0631544380342,1.0199,-569.045553654
-179.246195966,5.021,3.657,450.066734304,0.0789405880828,0.9724,-455.094171615
-179.454374474,2.7467,3.2881,624.065928051,0.0571403037925,1.0218,-629.044212581
-179.454374474,5.2328,3.9964,624.065928051,0.0571403037925,1.0218,-629.044212581
-0.511525803478,0,2.2128,6.xxx-xxxxxxxx,0.053569328936,0.98158,-671.085143315
-0.511525803478,5.02,5.088,6.xxx-xxxxxxxx,0.053569328936,0.9802,-671.086523315
-0.511525803478,0,5.7684,6.xxx-xxxxxxxx,0.053569328936,0.98158,-671.085143315
-0.511525803478,5.02,1.532,6.xxx-xxxxxxxx,0.053569328936,0.9802,-671.086523315
0.753804033678,0.5486,4.733,450.066734304,0.0789405880828,0.9724,-455.094171615
0.753804033678,0.5486,1.177,450.066734304,0.0789405880828,0.9724,-455.094171615
-0.320066012432,4.373,2.219,6.xxx-xxxxxxxx,0.0335190521779,1.049,-1073.03159086
-0.320066012432,3.971,1.538,6.xxx-xxxxxxxx,0.0335190521779,1.049,-1073.03159086
-0.318287904603,3.9706,5.0936,6.xxx-xxxxxxxx,0.033332840984,1.0493,-1079.03155436
-0.318287904603,4.3734,5.7742,6.xxx-xxxxxxxx,0.033332840984,1.0493,-1079.03155436
0.162301016816,0,5.098,2112.13404689,0.0169971101541,1.0254,-2117.10897942
0.545625526451,0.8089,0.8376,624.065928051,0.0571403037925,1.022,-629.044012581
0.545625526451,1.2672,0.1848,624.065928051,0.0571403037925,1.0218,-629.044212581
0.545625526451,2.8228,5.1015,624.065928051,0.0571403037925,1.0218,-629.044212581
0.545625526451,2.8228,1.5459,624.065928051,0.0571403037925,1.0218,-629.044212581
0.545625526451,0.8089,4.393,624.065928051,0.0571403037925,1.022,-629.044012581
179.506112128,5.6052,2.6212,6.xxx-xxxxxxxx,0.0517222503997,1.0173,-695.049926194
179.679933988,1.5989,3.2959,6.xxx-xxxxxxxx,0.0335190521779,1.0493,-1073.03129086
180,6,5.3974,0,6.xxx-xxxxxxxx,1.0618,-4.xxx-xxxxxxxx
180,6,1.8418,0,6.xxx-xxxxxxxx,1.0618,-4.xxx-xxxxxxxx
0,1.6292,2.6328,0,6.xxx-xxxxxxxx,1.1655,-4.xxx-xxxxxxxx
180,3.9403,5.7568,0,6.xxx-xxxxxxxx,1.1655,-4.xxx-xxxxxxxx
180,3.9403,2.2012,0,6.xxx-xxxxxxxx,1.1655,-4.xxx-xxxxxxxx
180,3.6786,0.84184,0,6.xxx-xxxxxxxx,1.1254,-4.xxx-xxxxxxxx
-179.33383918,4.9299,0.85636,510.065597447,0.0697627723328,1.2514,-514.814148492
0,0.69134,3.6467,0,6.xxx-xxxxxxxx,1.219,-4.xxx-xxxxxxxx
180,5.3504,1.1873,0,6.xxx-xxxxxxxx,1.219,-4.xxx-xxxxxxxx
180,5.3504,4.7429,0,6.xxx-xxxxxxxx,1.219,-4.xxx-xxxxxxxx
-179.620585598,2.7748,5.7568,900.073488396,0.0397342543264,1.3167,-904.757013439
-179.615492939,2.7748,2.2012,888.073045397,0.0402675761615,1.3167,-892.756566884
-179.356292116,1.5863,5.4119,528.06546471,0.0674115201889,1.2993,-532.766142633
-179.356292116,1.5863,1.8564,528.06546471,0.0674115201889,1.2993,-532.766142633
0.379414402154,2.7946,2.6328,900.073488396,0.0397342543264,1.3167,-904.757013439
0.643707883708,3.9832,2.9776,528.06546471,0.0674115201889,1.2993,-532.766142633
-179.635085111,4.1314,4.7429,936.074858958,0.0382158106108,1.3771,-940.697993864
-179.632745977,4.1314,1.1873,930.074626397,0.0384607737231,1.3771,-934.697759738
0.364914888596,1.9103,3.6467,936.074858958,0.0382158106108,1.3771,-940.697993864
-179.506112128,5.219,0.524,690.067092513,0.0517222503997,1.517,-694.550226194
-179.341495522,3.1356,2.6483,516.065543884,0.0689610079171,1.5173,-520.548204197
-179.341495522,3.1356,4.4261,516.065543884,0.0689610079171,1.5173,-520.548204197
-179.341495522,3.136,0.2038,516.065543884,0.0689610079171,1.517,-520.548504197
-179.274818319,4.4072,1.9008,468.066266704,0.0759433339049,1.733,-472.333142702
-179.274818319,4.4072,5.4564,468.066266704,0.0759433339049,1.733,-472.333142702
-179.274818319,2.3934,1.1925,468.066266704,0.0759433339049,1.733,-472.333142702
-179.274818319,2.3934,4.748,468.066266704,0.0759433339049,1.733,-472.333142702
-179.274818319,2.8517,0.5397,468.066266704,0.0759433339049,1.733,-472.333142702
0.725181681373,3.6483,3.6415,468.066266704,0.0759433339049,1.733,-472.333142702
0.725181681373,1.1622,2.9332,468.066266704,0.0759433339049,1.733,-472.333142702
-179.590775443,2.059,0.8564,834.071148108,0.0428560779948,2.059,-838.012351666
Message 4 of 16
paullimapa
in reply to: bigboyitm
I'm getting an error attempting to select your custom hatch pattern.
Perhaps you can try zipping up the pat file and then post ?
Paul Li
IT Specialist
@The Office
Message 5 of 16
gbattinPH5TG
Quick note to anyone who copies the hatch pattern:
This is one of the longest hatch patterns I have ever seen. Regardless of that... At the end of any hatch pattern, there MUST be at least one carriage return (Enter button) at the end of the .PAT file code.
Message 6 of 16
paullimapa
in reply to: gbattinPH5TG
yep, tried putting the carriage return at the end, even removed all the comment lines and added hatch description ...but still same error:
Paul Li
IT Specialist
@The Office
Message 7 of 16
bigboyitm
in reply to: paullimapa
Here is the zip file.
Message 8 of 16
Patchy
Never seen this before:
Go get another one:
https://coronado.com/hatchpatterns/
Message 9 of 16
pendean
@bigboyitm The Hatch pattern as you posted is incomplete or problematic, AutoCAD 2023-23-25 report this issue
A new copy of the single PAT file from the actual vendor seems to work in 2023-2024 but not in 2025
Wonder if you need to handicap 2025's graphics for it to work: GFXDX12 is worth turning off first (requires a program restart to take effect) or turning off hardware acceleration altogether for a quick test.
And report this to Autodesk through your Account Portal.
Message 10 of 16
bigboyitm
in reply to: pendean
Neither of these solutions helped.
Message 11 of 16
pendean
Then your only choices today are:
1) roll back to your old version if you still have it or install/switch to AutoCAD2024.
2) Open a support case with Autodesk if you are on subscription to seek out Autodesk Support's help with 2025's quirk that seems easy to repeat:
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-find-my-sup...
Message 12 of 16
caseyMG5WP
Didn't realized I signed into my old student account and posted this question. I filed a case through Autodesk, hopefully we get it resolved soon.
Message 13 of 16
pendean
in reply to: caseyMG5WP
Ha! cool login name though...
Message 14 of 16
Kent1Cooper
[The multiple x's are because the website sees certain number formats as possibly being serial numbers, and it won't let those be posted, so it makes that substitution.  That's why the attachment .pat file is needed, rather than the code pasted into the message body.]
Kent Cooper, AIA
Message 15 of 16
ajolly
you need to change the HPMAXLINES parameter to 10000000
Message 16 of 16
Kent1Cooper
That is a phenomenally long pattern definition, but it works for me [Acad2020 here -- I could test it in a newer version later]:
But I agree, the HPMAXLINES setting could be your problem.  The pattern at a scale of 1 is a 6-drawing-unit square repeat, if that helps you decide on the size of a smallish area to try in.
Kent Cooper, AIA
AutoCAD Inside the Factory
