Custom Command Combo
Hello all, I'm looking to create a custom command combo that will run the OVERKILL command and the JOIN command with a single operation.  I've already created a new command, but when I try to combine the macros for each command it will do one or the other, but not both.  Any ideas on how to accomplish this?? Thanks!
cadffm
I cant see your code, so we cant know what object selection and overkill option you use.
Menumacro, ActionMacro? Script, Vba, .Net?
Post your single solution, then we can help you.
Sebastian
I'm probably going about this all wrong.  Please note that I'm using LT version software, if that changes things.  Attached is a screenshot of the new command.
I got one part of the command combo to work..... the overkill portion works with this macro
^C^C-OVERKILL;ALL;;;
I'm having trouble with the join part, when I input "all" to select all it gives me "invalid selection"
the join macro I have is
^C^C_JOIN;ALL;
I got it figured out Smiley Happy I used PEDIT to get it to work
^C^C-OVERKILL;ALL;;;_PEDIT;M;ALL;;J;;;
this worked like a charm
