- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello.
The entire drawing window seems to be unresponsive; I can't see any drawing. The cursor also disappears when I hover over it. It is however visible and perfectly functional when I hover over any other part of the screen, including AutoCad's ribbon/bottom controls. This goes for both Models and Layouts of every dwg file I've opened.
When I click Layout then Start, going back to the drawing the drawing window appears completely white in both Model and Layout; when I click Model then Start, the drawing window appears black.
This first happened in AutoCAD 2018; I tried to repair and reinstall to no avail. After shutting the computer off then back on the program appeared to work fine for a short while, but all the lines in a drawing had multiplied 10x.
Then I uninstalled the program and downloaded the 2019 version, where the invisible cursor + drawing problem is showing again.
Any suggestions?
