Cursor becomes mis-aligned or detached from mouse pointer when using 3D orbit
I've searched all over for this one but nobody has the answer.
When i use 3D orbit or shift + middle mouse click to look around my drawing in 3D the AutoCAD cursor becomes completely detached from my mouse pointer which makes it impossible for me to do anything accurately. Here's a screenshot:
This is either a setting that i have inadvertently turned on/off or a terrible bug. I urgently need to get to the bottom of why its happening!
System Info:
OS Name Microsoft Windows 10 Home
Version 10.0.15063 Build 15063
System Manufacturer Micro-Star International Co., Ltd.
System Model GE62 2QF
System Type x64-based PC
Processor Intel(R) Core(TM) i7-5700HQ CPU @ 2.70GHz, 2701 Mhz, 4 Core(s), 8 Logical Processor(s)
Installed Physical Memory (RAM) 16.0 GB
Alfred.NESWADBA
are you using a 4K diisplay? ... and which graphic card do you have built in and using in AutoCAD.
Please start command _GRAPHICSCONFIG and turn off hardware acceleration for a test.
When the dialog for hw-acceleration is active please create a screenshot from that dialog and show that image here.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Graphics Card - NVIDIA GeForce GTX 970M - Up to date Drivers
I forgot to mention that i am already using AutoCAD with Hardware Acceleration turned off. No i don't have a 4k display.
Alfred.NESWADBA
does the same happen when you turn on the hw acceleration?
One other try (before we reset the AutoCAD profile) ... what about creating a new Windows user, login with that account, open a new drawing, create a simple box, run orbit to get a new view, not try the selection ... same issue?
- alfred -
Alfred NESWADBA
The same happens with hardware acceleration on.
I'm afraid to say i solved this but the solution does not make much sense!
I started a new drawing and copied everything including an xref and pasted it into my new drawing. Now the problem is gone. I wish i could understand why it was happening in the first place but nevermind!
thanks for your help!
Alfred.NESWADBA
thank you for your feedback, good to know you've got it working!
- alfred -
Alfred NESWADBA
