Curser jumps after a command
Hi, I am using AutoCAD 2015. After I issue a command like line, copy, move etc the curser jumps around and I can't place it exactly where I want it.. The curser moves smoothly until a command is made. Can't draw like that.
Does anybody know how to fix this?
Thanx,
Frank
Alfred.NESWADBA
Maybe your snap is turned on, try <F9> to toggle it and see if the cursor works than in a normal way.
You might also try to disable object-snap <F3>.
If nothing helps then let us please know if that is drawing specific or if that happens with a new drawing too.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
stanpotter
Community Visitor
Community Visitor
i have the same problem and the snap is turned off, it does not make a difference
stanpotter
Community Visitor
Community Visitor
it seems to be drawing specific, other drawings are just fine
pendean
Community Legend
Community Legend
Fix that one troublesome DWG anytime you want, the long list of things to try is here file https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-File-Corru...
or share it over here for all of us to explore it too.
