ctrl+shift+c problem in autocad2010
Message 1 of 13
when i try to press ctrl+shift+c to copy objects into another drawing, my current step is :
1.press ctrl+shift+c
2. select base point
3. select objects
4. ctrl+shift+v to paste objects
I would like to set the follow priority:
1.select objects
2. press ctrl+shift+c
3. select base point
yet, i checked my setting of options-->selection,the "noun/verb selection" is ticked already. what should i do for the prefered result?
p.s. i have the similar problem for layer isolate. so far i found these two sitiations do not fit my habit....
Replies (12)
Message 2 of 13
pendean
Community Legend
Community Legend
Ensure PICKFIRST and PICKADD variables are both on: explore them in HELP.
Message 3 of 13
i checked, both are 1, but the problem is not solved
Message 4 of 13
anyone can help me? it annoys me a lot 😞
Message 5 of 13
Jonathan3891
3. select objects
This is the correct order to complete that task.
Autocad works in this order: Command > Object > options
The order that you want relates to Microstation
Microstation works in this order: Object > Command > Options
Jonathan Norton
Blog | Linkedin
Message 6 of 13
i want to change the setting into object>command>options
how can i set this? 😞
Message 7 of 13
i am working in a company and need to use autocad frequently
the original setting is "object>command>options"
oneday it suddently changed into "command>object>options"(i dont know why, i did not change anything)
it really annoys me because i waste time on this
Message 8 of 13
pendean
Community Legend
Community Legend
No, incorrect: the way the OP wants it to work is working fine here in AutoCAD through R2016.
Message 9 of 13
Jonathan3891
PICKFIRST system variable:
0 - Turns OFF PICKFIRST. Select objects after a command is invoked.
1 - Turns ON PICKFIRST. Select objects before or after a command is invoked.
Jonathan Norton
Blog | Linkedin
Message 10 of 13
steve216586
1. A routine add-on which effects the noun-verb action.
2. Repair is in order.
3. QAFLAGS = 0...Not sure if this is culprit but has been mentioned with problems similar. (Undocumented SYSTVAR.)
"No one can make you feel inferior without your consent. "-Eleanor Roosevelt
Message 11 of 13
pendean
Community Legend
Community Legend
I think we did that already 🙂
Message 12 of 13
the problem is not solved yet..
any advice?:(
Message 13 of 13
ACADY7VVU
If you recently updated you video card, this may help. Check your Radeon video card setting, mine had the same shortcut for video, which over rides CAD. New PC build, it worked on mine.
Andy
