Ctrl-Click xref layer in filter
AndrewBrownie
Message 1 of 10
AndrewBrownie
For some reason in AutCAD 2015 i can not shift-click or Ctrl-click xref layers in the filter section of the layer manager. See attached
Replies (9)
Message 2 of 10
wispoxy
Works fine for me. Might be a registry error, looking further into the matter.
Message 3 of 10
VinodBalasubramanian
Autodesk Support
Autodesk Support
Dear Andrew,
Can you able to try resetting your AutoCAD to defaults and see whether it helps to get the shortcut key back. If you have any customizations in AutoCAD, please make sure to back them up before checking.
http://knowledge.autodesk.com/article/How-to-reset-AutoCAD-to-defaults
Hope it helps.
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Message 4 of 10
wispoxy
I believe this reply is for you abrown
Message 5 of 10
Autodesk Support
Autodesk Support
Yes Andrew it was for Andrew Brown. Thanks for confirming it.
Message 6 of 10
AndrewBrownie
Unfortunately this has not resolved my problem
Andrew
Message 7 of 10
Autodesk Support
Autodesk Support
Thanks Andrew. Can you try the following.
  1. Type "LAYERDLGMODE" in command bar
  2. Set variable to "0"
Then try and see whether it helps or not. If not I could take a quick remote on your machine to troubleshoot the problem.
Message 8 of 10
AndrewBrownie
Hi there,
unfortunately that also didn't work
Message 9 of 10
Autodesk Support
Autodesk Support
Can we have a quick remote on your machine tomorrow. Let me know your convenience on the timing.
Message 10 of 10
Autodesk Support
Autodesk Support
Good day to you.
Just wanted to check with you for an update. Please let us know, if you need further assistance.
We will be glad to assist you further.
