Afternoon guys (and gals),
I am trying to set up 400+ layers for a project I am currently woirking on and the wayI have been told to do this is through a script file.
I have created this but whenever I run it, the description will not show in Autocad 2013 - an extract from the scr file is below and I would love to find a solution or a fix to any error???
'-LAYER
N W-51CD-SEZE------------ C red W-51CD-SEZE------------ LT continuous W-51CD-SEZE------------ D DRAINAGE - EXISTING GRAVITY PIPE (PLAN/PROFILE/MODEL)
Many thanks in advance
Welcome to the Autodesk Forums, mart.
try:
LAYER
N W-51CD-SEZE------------ C red W-51CD-SEZE------------ LT continuous W-51CD-SEZE------------ D DRAINAGE - EXISTING GRAVITY PIPE (PLAN/PROFILE/MODEL)\U+000DW-51CD-SEZE------------
<<<empty line>>>
<<<empty line>>>
affter the description you'll need to use \U+000DW (carriage return) and then the layer name.
Not tested...
Hope that helps
Henrique
Or in the Script file use this format.
After the description text use a New line
-layer M NewLay01 C 3 NewLay01 L dashed2 NewLay01 LW 0.05 NewLay01 D Mylayer NewLay01 plot plot NewLay01
Thanks for the responses guys, I have tried the following and can run the script file but this still leaves the descriptions blank 😞
LAYER N W-51CD-SEZE------------ C red W-51CD-SEZE------------ LT continuous W-51CD-SEZE------------ D DRAINAGE - EXISTING GRAVITY PIPE (PLAN/PROFILE/MODEL)\U+000DW-51CD-SEZE------------
<<<empty line>>>
Anyone any idea what I could do??? (I would like to use this script file as there are so many layers to create - editing them manually will be time consuming)
Above mentioned script works for me.
Also I guess the tick mark of Description tab in the Layer box is ON
Press F2 after the script finished and check the output window results with the attached image.
Do you have a Layer State Export File or sample drawing with all of the layers already setup? I've been converting my "clean and restore" lisp into a script for a button and use a LAS file in the lisp. It's taken a bit of trial and error but I eventually got it to work. I added the requirement to delete the layer state because it won't import if it exists in the drawing when importing.
I think that if you already have a DWG or LAS with all of the layers setup then you could do it this way with the button
This is the text used:
-layer;a;d;<Layer state>;i;"<LAS file>";r;<Layer state>;;;
#edit Sorry I've just realised I'm necroing an old post *facepalm*
