& Construction
Integrated BIM tools, including Revit, AutoCAD, and Civil 3D
& Manufacturing
Professional CAD/CAM tools built on Inventor and AutoCAD
I'm trying to get this into a .stl from a .dwg in order to print it. The only thing it seems to export is the rectangle. When I command line list and click on the pointy ends it says 1 object found.
Exporting to makerware by the way.
It has a gap in it, use SURFSCULPT and turn it into 3dsolid, then STLOUT
but you have to fix the gap first.
@Patchy Even when I fix the gap, I can't even seem to make my points solids? Any tips?
Thank you for the surfsculpt I understand how that works now, and I understand the stlout command too!
I'm tracing your drawing:
Using the command 3DPOLY, pick 4 corners, put a POINT at the tip and then use LOFT command.
it will become a solid.
How to buy
Privacy | Do not sell or share my personal information | Cookie preferences | Report noncompliance | Terms of use | Legal | © 2025 Autodesk Inc. All rights reserved
Type a product name
