Creating shortcuts/aliases for use in command line
kreuzfahrer477
Observer Observer
Message 1 of 9
kreuzfahrer477
Observer
Observer
Hi all
Lately ive been trying to create a shortcut that i can use in command line and command will take effect after i press enter.
Lets say for example i wanna type in command line "IS" and use that for ISOLATEOBJECTS command. Or "HH" for HIDEOBJECTS
Ive tryed to set up shortcut command in manage tab>edit aliases>edit aliases (a notepad opens with commands) all the way down under "User Defined Command Aliases" (see picture below) and run REINIT command after that.
Still shortcut commant isnt working.
Also nothing seems to work under CUI shortcuts
How exactly to i create this kind of shortcuts in ACAD architecture 2025?
Replies (8)
Message 2 of 9
Patchy
That looks kind of different way to add newaliases.JPG command, did you use ADD as shown here?
Message 3 of 9
kreuzfahrer477
Observer
Observer
I jave also tried and use that, sadly not working as well.
Message 4 of 9
Patchy
Try this, copy and paste the line below into your autocad command line, then hit Enter
(findfile "acad.pgp")
Is it the one you were editing ?
Message 5 of 9
imadHabash
Make sure that you finish the whole procedure for adding a new shortcut, especially when this option is selected (see below image)
Imad Habash
Message 6 of 9
kreuzfahrer477
Observer
Observer
Yes its this one that i have edited, i have phisicly found file in acad users acad file route. Saved the pgp file and run RAINIT command in acad.
Message 7 of 9
kreuzfahrer477
Observer
Observer
Yes i made sure this is checked as well also not working 😞 i guess im stuck with that VBA script or smting which i dont know how to create this kind of commands..
Message 8 of 9
greg
Observer
Observer
You might want to try using the CUI - create command function to create a macro that enacts the command with the schortcut text you define.
Message 9 of 9
yanhan.lim
Hi @kreuzfahrer477 ,
Thanks for posting your query on the AutoCAD Architecture community forum.
From your described workflow, it seems like you have done the customization workflow correctly.
Shortcut creation help documentation for reference - https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Creating-a-keyboar...
I tried on my end to create a shortcut on my end and it does work.
Screen recording reference - https://go.screenpal.com/watch/cTf3QlnjdI3
My first suggestion:
  • Review the format of your PGP file and ensure your custom shortcut matches that of the help documentation or the rest of the default shortcuts
  • After editing and saving your PGP file, try restarting your program.
My next suggestion:
  • I have attached a zip file containing my customized PGP file (the same one shown in the screen recording). You may copy my custom shortcut over and see if that works for you
Best regards,
Yanhan
Yanhan Lim
QA Analyst
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
