AutoCAD Forum
Creating Points at Crossing Polylines
15 REPLIES 15
Message 1 of 16
estringer
1165 Views, 15 Replies
estringer
I was wondering if there is a way to create points at crossing polylines? Preferably I would want to be able to specify 2 polyline layers and get points at any intersections of polylines on those layers.
15 REPLIES 15
Message 2 of 16
VincentSheehan
in reply to: estringer
VincentSheehan
Could this help? Create a block with a point then use this Lisp to place the block at crossing lines.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 3 of 16
leeminardi
leeminardi
One of Lee-Mac's intersection programs may be your answer.
https://www.lee-mac.com/intersectionfunctions.html
lee.minardi
lee.minardi
Message 4 of 16
estringer
in reply to: VincentSheehan
estringer
Do you know if putting the point in a block will change how it is "seen" in the drawing? We are using the points for programming a Total Station and I am trying to see if there are more efficient ways to place the points.
Message 5 of 16
autoid374ceb4990
Are you doing the programming?
If you are depending on 3rd party software and the software is capable of reading the insertion point of blocks, then create a block with one POINT and make the POINT coordinates the insert point.
Message 6 of 16
VincentSheehan
VincentSheehan
You could explode the blocks afterwards.
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Vincent Sheehan
Sr. Civil Designer
Poly In 3D Blog
Message 7 of 16
estringer
in reply to: leeminardi
estringer
I do not have any experience with Lisp routines so am a little confused on how Lee's work. Am I supposed to combine the two different sets of code into one file or am I supposed to create and load both?
Message 8 of 16
Kent1Cooper
Kent1Cooper
You can combine them into one file, APPLOAD that file, and use the INTERSET command that's defined in the second one.  [You don't use the function defined in the first one directly -- it is called on by the second one.]
Kent Cooper, AIA
Kent Cooper, AIA
Message 9 of 16
estringer
in reply to: Kent1Cooper
estringer
I have tried combining them in the same file, once with the called function first and once with the called function last and get the same error on both. See below:
Message 10 of 16
leeminardi
leeminardi
Extract the .lsp file from the attached.  Load the program with APPLOAD then give the inter command.
lee.minardi
lee.minardi
Message 11 of 16
estringer
estringer
Thank you! That worked perfectly!
Message 12 of 16
estringer
estringer
Thank you for everyones help!
Message 13 of 16
Kent1Cooper
Kent1Cooper
@estringer wrote:
Whoops -- I hadn't noticed that the called routine itself calls for another.  You will also need to get that function from higher on the same web page.  You can also add it into the one file, or all three can be in separate files if you make sure all get loaded.
Kent Cooper, AIA
Kent Cooper, AIA
Message 14 of 16
estringer
estringer
This one?
This one?
Message 15 of 16
Kent1Cooper
Kent1Cooper
Yes.
Kent Cooper, AIA
Yes.
Kent Cooper, AIA
Message 16 of 16
estringer
estringer
Thank you.
Thank you.
AutoCAD Inside the Factory
