creating hole in sphere
golfsferr
golfsferr
I have created a hollow half sphere and I am trying to cut 5 holes in the surface in top view. I have circles above my sphere surface. I have presspulled I have extruded I have projected and I can't create a hole. Actually I would like to trim out the hole then take the trimmed surface and put it back 2mm lower to create a depression. Obviously I'm a newbie and I would appreciate some help, Thanks.
leeminardi
Make sure that your "hollow sphere" is a solid with a finite wall thickness.
Here's a cutaway view of a hollow sphere with a cylinder intersecting it.
Use subtract to remove the cylinder from the sphere.
You can use intersect with a sphere and cylinder to get the plug for the hole.
Using a "trimmed surface and put it back 2mm lower to create a depression" would yield a surface that is not concentric with the sphere's outer surface.  It would be better to create a sphere with a radius of the depression and then use intersect or subtract to make the final solid.
A 2D cutaway view would help to explain what you are trying to create.
lee.minardi
Washingtonn
You could use three spheres (All with the same center point).
Sphere 1 having the required outside diameter.
Sphere 2 having the required inside "hollow" diameter.
Sphere 3 having the required recess diameter (2mm less that sphere 1).
Create extruded cylinders for your holes and subtract from Sphere 1.
Union Sphere 1 and Sphere 3 to create the recesses (let's call resulting solid Sphere 1).
Slice Sphere 1 as required to get half sphere.
Subtract Sphere 2 from Sphere 1 to get hollowed out half Sphere 1 with recesses.
If you need the recesses perpendicular to the outside surface, the Cylinders ("holes") should pass through the center of the sphere.
golfsferr
Thanks folks for the great ideas. I'll focus on both to see if one of the suggestion will fix my error but I have tried the 3 sphere idea. It's the actual trim that just doesn't' work but then all the sudden I try the process again and it will  trim. But then next time it won't, very frustrating. I was wonder if there was a tolerance issue that was off. But thanks again, I will try them both.
golfsferr
Now I have 2 surface stuck together I need to separate. Yes I tried the separate function. I probably just did it wrong.
