Creating bullets in mtext using punctuation and pressing tab
dkrampen
dkrampen
I have a line of text that has created a custom bullet.  I am attempting to recreate this custom bullet.  The line of text says, "SEE: TEST A"  I assume that tab was hit after the colon.  When I go to recreate this I open an mtext window, I type in see:, I press tab and enter my text.  My assumption is when I press enter a bullet will be created.  This is not the case.  What am I doing wrong?  I included a sample dwg with the culprit and my attempt to recreate.  Thanks for the help!
dkrampen
WRONG FILE HERES THE RIGHT ONE!
dkrampen
So the plot thickens.  I reopened the drawing.  I noticed both texts had a bullet now.  I noticed that when I created the bullet:  put in a letter bullet, enter punctuation, hit tab, end information and hit enter, it doesn't create the next bullet.  But if I go through the same procedure and then left click off the text and then re-select the text, my text has a bullet attribution.  What the heck is going on?
Victoria.Studley
Hi @dkrampen,
It's a bit difficult to understand exactly what's happening based on your description. Could you record a quick Screencast and post it in your response, so that we can see exactly what's happening in real time on your end?
When I try the same workflow in AutoCAD 2018, the bulleted and lettered lists seem to be working as designed.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Victoria Studley
Principal Experience Designer - Fusion Configurations
Join us in the Fusion Insider Program
Fusion Learn & Support | Fusion Documentation
Victoria.Studley
Hi @dkrampen,
Do you still need help with this issue? Will you be able to record a quick Screencast to show us what's happening?
Victoria Studley
john.vellek
Hi @dkrampen,
When I opened the second attachment you added, I am able to rt-click after the Letter "bullet" and it creates the next bullet just fine.  I am not sure about your other test with the punctuation so it would be nice to see a Screencast as requested by @Victoria.Studley.
I did check the drawing for errors and everything appears to be fine. Perhaps this is just a display issue.  Have you tried toggling any of the features in GRAPHICSCONFIG to see if makes any difference? Or, perhaps turning off Hardware Acceleration altogether?
John Vellek
