Creating a new part by modifying an xref.
DouglasBauer
Message 1 of 8
DouglasBauer
I'm trying to create a new part by modifying an xref that is already in the design.  Essentially, I just want to do a "make from".  This is what I done so far.  I created a new drawing, inserted my xref and saved as the new part. It looks like if I open that new part and try to modify it, Acad seems to be resorting back to the original xref to modify.  Am I asking too much?>
Replies (7)
Message 2 of 8
imadHabash
would you please clarify more your issue ?
Imad Habash
Message 3 of 8
pendean
Community Legend
Community Legend
Are you perhaps just needing to change the VISRETAIN variable setting in your new file?
Message 4 of 8
Kent1Cooper
@DouglasBauer wrote:
....  I created a new drawing, inserted my xref ....
Which command did you use?  Insert or Xref?
Kent Cooper, AIA
Message 5 of 8
paullimapa
Perhaps you need to actually make a copy of the xref dwg and attach that into your new dwg so that any changes made to the copy does not impact the original xref.
Paul Li
IT Specialist
@The Office
Message 6 of 8
TheCADnoob
are you dealing with nested xrefs?
CADnoob
Message 7 of 8
DouglasBauer
Im trying to dimension the hole thru
Message 8 of 8
TheCADnoob
have you tried NCOPY
CADnoob
