Creating a hatch into a closed polyline with LISP
Dear all,
I want to create a hatch inside a closed polyline with Lisp. Unfortunaly it won't work. My Lisp Code:
(defun FKT:ARROW ()
(command "_.pline" '(0 150) '(600 0) '(0 -150) "_c" "")
(setq ENT (entlast))
(command "_hatch" "SOLID" ENT "")
);defun
I use AutoCAD 2017. Thanks for all your help.
j.palmeL29YX
This works here:
(defun c:arrow	(/ ent)
  (princ)
Jürgen Palme
Kent1Cooper
If you want to use FKT:ARROW as a command you can type in, put a C: before the name:
  (defun C:FKT:ARROW ()
If not, you must use it by entering the function name with enclosing parentheses:
  (FKT:ARROW)
Kent Cooper, AIA
Heureka! - Thanks so much, it works :).
May can you explain me in addition, why does it works this way? What is the meaning of the command (princ) in this case and why do I have to enter the Symbol ENT inside the brackets behind the slash? Thanks for your support!
Kent1Cooper
Neither of those is what makes it work.  It's the c: before the command name that makes it work.
The (princ) is referred to as "quiet exit" so that you don't see nil at the Command line after you run it -- see Help about that and (prin1) and (print).  AutoLisp functions/command-definitions return the last thing in them at the end.  This command definition ends with a (command) function, which always returns nil, and that will appear at the Command line and confuse some people if it isn't squelched by ending with a function that does nothing and returns nothing.
The (/ ent) is "localizing variables" -- see Help for the (defun) function.  It's not essential, but good practice, and depending on your use of variable names, could prevent different routines interfering with each other.
Kent Cooper, AIA
