Creating a Custom Size for Printing
I am truing to emulate imperial size of 24"Xx36" to it's metric equivalent 914mmx610mm.
This is how I set up the drawings tab: I go to the tab and right click and select "Page Setup Manager"
Then I select the referenced tab and hit "Modify". I select the printer (in this case HP) and click on "Properties". Then I click on "Custom Properties". Next I select the Landscape layout under "Paper Size" tab, and click on "More Sizes". I select "Metric" in the bottom right corner and punch in the numbers: 914 for "Width" and 610 for "Height". Now when I click "OK". AutoCAD throws an error reading "The final paper size to be printed is invalid given the selected configuration for this printer." However, if I go back to "Paper Sizes" and for "Height" I enter 609.6 (instead of 610) then when I click on "OK" I don't get the error message. So AutoCAD is accepting 609.6 instead of 610. I just want to be consistent with the actual sizes and would prefer to enter 610 instead of 609.6.
I just want to know how I can enter 610 instead of 609.6. Thank you to everyone.
