Creating a Button Macro with point filters
Message 1 of 9
Hi Everyone.
I'm trying to create a button macro that will allow me to snap to an entity and use it's Z value as the elevation I want to work at. I'm attempting this since I really don't want to select an entity and click a grip and write down the elevation and then type that in the ELEV prompt. I have written the steps out but I'm a novice in terms of syntax and getting it write in the macro.
Here are my steps:
1. type elev
2. type .Z
3. digitize point
4. prompted for .XY and digitize point from step 3
5. prompted for second point type .XY
6. type @
7. prompted for Z enter 0
8. enter 0 for thickness
This is what I currently have for my macro: ^C^C_elev;.z (the simple part - having difficulty with getting steps 4 to 8 in it)
I'm constantly working in a 3D environment and always looking for a way to set my elevation simply by clicking an entity (or anywhere on that entity) and using that points Z value to be my working elevation. I'm using AutoCAD OEM and not using Map or Civil (which I presume would have this function available to it).
Any help would be greatly appreciated.
Sean
Replies (8)
Message 2 of 9
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Have you tried using the Action Recorder to record the steps? You can then save the macro with a name and use it as a command in a button or a tool palette command.  Give it a try and see if that works the way you like or need more information.
John Vellek
Message 3 of 9
Hi John,
I tried that earlier for a different button but it seemed to remember the data that I was using. Can the macro created by the action recorder be modified (I don't just mean the name).
If there is a way to get a macro generated from the action recorder that I can use on any data I will gladly try that option out as well.
Thanks for the advice - I'll try it with this macro.
Message 4 of 9
john.vellek
Hi @Anonymous,
Please try this macro. It should pause for user inputs.  If this works, you can use the FIilterforZ as a command in a button.
John Vellek
Message 5 of 9
Kent1Cooper
Could you do it by setting a New UCS with that point as its Origin, rather than with the ELEV command?  [No need to answer the Thickness question that way, at least.]  Since a new Origin is the basic request at the UCS prompt, something like [minimally tested]:
^C^CUCS;\;
Kent Cooper, AIA
Message 6 of 9
SEANT61
Based on the original Command Macro request, give this a try:
^C^C_elev;0,0,0;.xy;@;\;
May your cursor always snap to the location intended.
Message 7 of 9
SEANT61
Actually, the original macro request is more accurately met by:
^C^C_elev;0,0,0;.xy;@;\0.0;
Message 8 of 9
SEANT61,
thank you for the assistance. this is exactly what i'm looking for.
greatly appreciated
Sean
Message 9 of 9
SEANT61
You're welcome.
