Create view, Modify view, Update & Styles and Standards panels are missing in layout tab after layout is selected - Autocad 2023
dongay.panda
dongay.panda
In Autocad 2022 after selecting layout tab (located besides model tab), in the ribbon layout tab appears and under which 6 panels appear.  They are:
  1. Layout
  2. Layout Viewports
  3. Create view
  4. Modify view
  5. Update
  6. Styles and Standards
But however in Autocad 2023 & Autocad 2024 versions Create view, Modify view, Update & Styles and Standards panels are missing.  How to bring these?   Please help.
But when I open Autocad Electrical 2023 or 2024 all the 6 panels are available when I select Layout tab next to Model tab (below).
ennujozlagam
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Ribbon-and-toolbar...
dongay.panda
After spending some time with Acad 2022 CUI, I have known the solution.
I had to export partial customization File MODELDOC from Acad 2022 and imported in Acad 2023/2024 and problem was got solved.
paullimapa
Curious did that partial MODELDOC cui in 2022 come from installation of a different add-on?
Paul Li
IT Specialist
@The Office
dongay.panda
MODELDOC had come with default installation of 2022.
ControlsFreak
Observer
Observer
Use the Customize User Interface (CUI) Editor to add the tools:
  1. Type CUILOAD and hit Enter.
  2. Click the "Browse..." button.
  3. Browse to C:\Program Files\Autodesk\AutoCAD 2015\UserDataCache\en-us\Support\.
  4. Select ModelDoc.cuix, then click Open.
  5. Click Load. then close
  6. Type WSSETTINGS and make sure "Automatically save workspace changes" is selected.
    If the Base button does not appear on the Home tab of the ribbon, restart AutoCAD.
