Create section issue
This widget could not be displayed.
Hello to everyone,
I'm trying to create a 2D section from a 3D model, with the command shown in figure but this tool allow only to select *inventor file.
Regardless of all that, how can I create a 2D section from a 3D model?
Thank you.
cadffm
Hi
not all "3D" is 3D, read the help about this command [F1].
If Acad ask for an Inventor file ONLY, there are no valid objects for 2D sections in your file.
Try this: Start command: _BOX
and create a 3DSolid.
Is it working now?
Sebastian
imadHabash
Viewbase command Creates a base view from model space or Autodesk Inventor models. If model space does not contain any visible solids or surfaces, the Select File dialog box is displayed to enable you to select an Inventor model.
you can start SECTIONPLANE command ( valid in Model space ) and VIEWSECTION command ( valid in Paper space ) .
VIEWSECTIONVIEWSECTION
Imad Habash
SECTIONPLANE command doesn't work. "no solid, surface or mesh selected".
How can I solve?
imadHabash
it seems that you don't have any 3d solid objects !! would you please attache here your objects for test ?
Imad Habash
