CREATE CUSTOM CHEVRON HATCH PATTERN
Message 1 of 11
Its possible to get a pattern of chevron hatch pattern as a size of 200x1200x2mm gap...
Accepted solutions (3)
Replies (10)
Message 2 of 11
Kent1Cooper
Use the herringbone pattern at a rotation of 45 degrees [or 135, or...].  If that doesn't do what you want, post an image of what a chevron pattern should look like.
Kent Cooper, AIA
Message 3 of 11
chevron-tile-pattern-saddle-chevron-chevron-tile-pattern-photoshop-chevron-pattern-subway-tile-backsplash.jpg
HERRINGBONE AND CHEVRON HATCH PATTERN DIFFER I WANT LIKE THIS PATTERN.....AT A SIZE OF 200X1200X2MM
Message 4 of 11
hugha
Try this:
; Written by HatchKit Professional
; HatchKit (c)1990-2019 Cadro Pty Ltd
; www.hatchkit.com.au/
;-Date : 2019/09/27
;-Time : 21:37:40
;-HatchKit Output Filetype : Revit with HatchKit Add-In
;%VERSION=3.0
;%UNITS=MM
*Chevron1200x200+2
;%TYPE=MODEL
44.977879,0,0,2414.82470,10.103899,1200,-46894.572127
135.02212,-2,0,2414.82470,-10.103899,1200,-46894.572127
44.977879,0,282.84,2414.82470,10.103899,1200,-46894.572127
135.02212,-2,282.84,2414.82470,-10.103899,1200,-46894.572127
90,0,0,0,-1701.05627,282.84,-2.8311396
90,848.53,848.53,0,-1701.05627,282.84,-2.8311396
90,-2,0,0,-1701.05627,282.84,-2.8311396
90,850.53,848.53,0,-1701.05627,282.84,-2.8311396
as discussed elsewhere, representing 2mm mortar may be overfine modelling and this could be sufficient:
;-Date : 2019/09/27
;-Time : 21:48:42
;%VERSION=3.0
;%UNITS=MM
*Chevron1200x200+0
;%TYPE=MODEL
45,0,0,200,200,1200,-1200
135,0,0,200,-200,1200,-1200
90,0,0,0,848.5281
hth,
Hugh Adamson
Tags (0)
Message 5 of 11
sorry to say same error happening kindly send 100x600x1mm this will change work as booommmm......
Message 6 of 11
hugha
change work as booommmm??
Are you trying to load the pattern with 2mm gap with Revit's Fill Manager?
That won't work for you in the same way as your attempting to load the
herringbone pattern with a 2mm gap did not work for you. The Revit Fill
manager will not allow it and will issues the same message.
If you MUST model to such a fine degree than you can circumvent the Revit
Fill Manager by employing the HatchKit Add-In for Revit to load outsized
patterns.
A 100x600x1mm pattern definition can be readily derived from that for a
200x1200x2mm pattern by halving every value within the definition apart from
the first value on each line which contains the element angle. As each
pattern element can be defined by a line of form
angle, x-origon, y-origin, x-offset, y-offset, +ve stroke-length, -ve
stroke-length
scaling can be achieved by changing all values (apart from the first) by the
same scaling factor possibly with Excel or even more easily within our
Add-in.
hoping this helps,
Hugh Adamson
www.hatchkit.com.au
Message 7 of 11
Kent1Cooper
@Anonymous wrote:
.... THIS PATTERN.....AT A SIZE OF 200X1200X2MM
What's the 1200mm dimension?  It looks like @hugha 's patterns [the first of which has the same issue as before -- "perpendicular" lines are not  perpendicular] are based on the upper one here, but might you really want the lower one?
And again, are you talking about those dimensions being true actual tile [or whatever they are] size, or center-to-center of joint size?
Kent Cooper, AIA
Message 8 of 11
Kent1Cooper
@Kent1Cooper wrote:
What's the 1200mm dimension? ....
Try this, using the lower  part of my image [overall  extent in length = 1200, long edge = 1000], and with the "size" being nominal, i.e. to the center of the 2-unit-wide joints  [not the tiles themselves], and with accurate 45-degree-multiple angles for all linesets:
*CHEVRON, Chevron pattern, 200x1200 nominal with 2-wide joints
90, -1,2.41421356, 1414.21356237,1414.21356237, 280.01428535,-2.82842712
90, 1,2.41421356, 1414.21356237,-1414.21356237, 280.01428535,-2.82842712
90, 706.10678119,707.52099475, 1414.21356237,1414.21356237, 280.01428535,-2.82842712
90, 708.10678119,707.52099475, 1414.21356237,-1414.21356237, 280.01428535,-2.82842712
45, 1,2.41421356, 200,200, 997.17157288, -1002.82842712
45, 1,-0.41421356, 200,200, 997.17157288, -1002.82842712
135, -1,2.41421356, 200,-200, 997.17157288, -1002.82842712
135, -1,-0.41421356, 200,-200, 997.17157288, -1002.82842712
But I agree with @hugha -- the joints are so tiny compared to the tile size that there must be only a very limited set of circumstances in which it's worth showing both edges of the joints.  If you're showing it at a size such that the joint width is apparent, you probably won't be showing enough of it to really see the pattern.
Kent Cooper, AIA
Message 9 of 11
ChicagoLooper
Yes it is possible. If you know how to create a Block, then you can do it using Super Hatch command.
Create or draw your hatch pattern. Then turn it into a block. Next, use Super Hatch command, found on the Express Tools Ribbon. It will 'tile' your block to fill up your area. Put some thought into how you draw your hatch and how you turn your hatch into a block. If you don't, your Super Hatch won't tile nicely. If you need to scale or rotate your hatch, keep your eye on the command line, there are scale and rotate options built into the command.
Screencast:
Chicagolooper
Message 10 of 11
Please how do I create a chevron pattern 1200mm x 200mm with a 30-degree angle
Message 11 of 11
Kent1Cooper
There's some ambiguity there....  Which 1200mm [long edge or overall]?  Which 30° angle?
Or maybe the length from one and the angle from the other?  And/or might you want the 200mm along the angled edge, rather than perpendicular to the long edges?  Or some other configuration I haven't thought of?
And the same questions apply as before about the joints: single-line or double, and if double, how wide is the joint and are the tile sizes actual [tile edges themselves] or nominal [to the mid-line of the joints]?
Also, because of the nature of Hatch pattern definitions, it may not be possible to have a precise 30° angle [whichever it is].
Kent Cooper, AIA
