create Centerline in 3D mass
The "theme-lib.utility-macros.ftl" widget cannot be found.
hannes.randhahn
hannes.randhahn
Hello Team,
I was wondering if there is a simple lisp or function to draw centerlines within 3D volumes?
cheers for the help.
This widget could not be displayed.
Valentin_CAD
@hannes.randhahn ,
Do you want something like this? If so, type LINETYPE at the command line, load the centerline linetype and apply.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
hannes.randhahn
Thanks, actually I was looking for a function to draw this line auto centre in the volume by a click or something. As of now I have to draw that by selecting XYZ perpendicular at the mass and draw a line in the middel .Takes forever on a big model
Valentin_CAD
@hannes.randhahn ,
You may find a LISP in the Visual LISP, AutoLISP and General Customization Forum as this one:
Emilio Valentin
hannes.randhahn
Ok Thanks a lot - I will check on it and see if it works for me
