Create a linetype with diamond
I'm trying to create a linetype like this one at the bottom
Is it even possible? I only get long dash short dashed lines from this.
I've followed this tutorial: https://www.youtube.com/watch?v=l9frj83w68M
The content in the .lin -file (attatched) reads: A,.12,-.039729,.08,-.04
Alfred.NESWADBA
to create the diamond part within a linetype you need to create a symbol and use that symbol in your linetype.
Creating symbols (shape ==> shx): >>>click<<<
Creating linetypes with symbols: >>>click<<<
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2026
(not an Autodesk consultant)
Kent1Cooper
You could do the same with a text character.  Several symbol fonts contain characters that are squares, and you could put one in rotated 45 degrees, with a coinciding line portion.  It could take some care in fine-tuning the positioning and scale, but it might be easier than defining a Shape for it with the necessary Shape file to contain it.
Kent Cooper, AIA
Found this:
Character            Name                   Hex                     Dec
⧅                         bsolb                  029C5                 10693
Could I use this and rotate?
Should I use the symbol or the Hex-code?
WarrenGeissler
As @Kent1Cooper said - you need to find a font that has that symbol defined:
*Symbol,Symbol
A,2,-1,["\U+29C5",standard,y=-0.76,x=-0.0,s=1.5,r=45],-1.5
Where "Standard" text style has a font of "@Malgun Gothic"
Warren Geissler
Drafting Manager Denver Water
_____________________________________________
Please ACCEPT AS SOLUTON if this works
(...and doesn't melt your computer or cause Armageddon)
