I would like to post this as a separate question. It was solved as part of another post, which was "annotation on attributes in blocks".
The main question still hasn't been solved, but this side issue was solved by John Vellek.
John, if you could post you answer here, I would like to close this issue with an "accept as solution"
Solution for my case was
Use the dataextraction command (this counts lookup and visibility states)
another suggested solution, which didn't work for my case, was using the DBcount lisp routine (this only counts visibility states)
Michael Kovacik
AutoCAD 2d & 3d (29 yrs)& Inventor (7 yrs)
Manufacturing (30 yrs) Draughtsman/Designer
Autodesk Product Design Suite Ultimate 2018
Johannesburg, South Africa
