Couting Dynamic Blocks
MikeKovacik4928
MikeKovacik4928
I would like to post this as a separate question. It was solved as part of another post, which was "annotation on attributes in blocks".
The main question still hasn't been solved, but this side issue was solved by John Vellek.
John, if you could post you answer here, I would like to close this issue with an "accept as solution"
Solution for my case was
Use the dataextraction command (this counts lookup and visibility states)
another suggested solution, which didn't work for my case, was using the DBcount lisp routine (this only counts visibility states)
Michael Kovacik
AutoCAD 2d & 3d (29 yrs)& Inventor (7 yrs)
Manufacturing (30 yrs) Draughtsman/Designer
Autodesk Product Design Suite Ultimate 2018
Johannesburg, South Africa
0 Me gusta
Responder
Soluciones aceptadas (1)
981 Vistas
5 Respuestas
Respuestas (5)
john.vellek
Solución aceptada
HI @MikeKovacik4928,
Just to add my two cents (which is frequently only worth one cent) I like to use data extraction to count the dynamic blocks. It will even let you count and sort by Visibility states.
John Vellek
0 Me gusta
gpcattaneo
Try this... (press F2 to display results)
(defun c:dbcount ( / blks n blk bL bL+)
    (vl-load-com)
    (if (setq blks (ssget "_X" '((0 . "INSERT"))))
        (progn
            (repeat (setq n (sslength blks))
                (if (eq :vlax-true (vla-get-isdynamicblock (setq blk (vlax-ename->vla-object (ssname blks (setq n (1- n)))))))
                    (setq bL (acad_strlsort (cons (vla-get-effectivename blk) bL)))
            (setq bL (reverse bL))
            (while bL
                (if bL+
                    (setq bL+ (cons (cons (car bL) (length (vl-remove-if-not '(lambda (b) (eq b (car bL))) bL))) bL+))
                    (setq bL+ (list (cons (car bL) (length (vl-remove-if-not '(lambda (b) (eq b (car bL))) bL)))))
                (setq bL (vl-remove-if '(lambda (b) (eq b (car bL))) bL))
            (princ "\n ") (princ "\n ")
            (foreach x bL+
                (princ (strcat "\n  " (itoa (cdr x)) "  Dynamic Block: " (car x) ))
    (princ)
0 Me gusta
MikeKovacik4928
This routine doesn't seem to work.
I get the following message after using appload with your routine
Command: APPLOAD
dbcount.lsp successfully loaded.
Command: malformed list on input
Command:
See attached screenshots
I have also run another lisp which counts dynamic blocks but only their visibility states not lookup states.
This lisp uses the same command name as your lisp ie dbcount.
Not being a lisper I don't know whether that has anything to do with it.
Looking at the message I don't think so, but am not really sure
Michael Kovacik
0 Me gusta
gpcattaneo
Work fine for me, try attached (renamed) file.
0 Me gusta
MikeKovacik4928
okay
it works now (see 05 & 07)
Still doesn't do what I want it to do.(see 06)
Doesn't count the lookup states or visibility states
Dataextract is still the way to go for me (see 06)
Mike
0 Me gusta
