Count palette returns unrelated objects as errors
AutoCAD 2022. I have a block with rectangles. Count palette appears to return the correct count but stepping through the objects in the error report is highlighting rectangles in unrelated blocks. I explode the rectangles in the block I am trying to count and that clears the errors. Temporarily. There should not be errors like this just because another block also has a rectangle in it!
Because the count palette will not count visibility states I do a SAVE AS to create the next simple block for the next part variation to count. Now the first block is showing a count error as a "renamed block" as it is now somehow connected to the Save As block. WHAT?
Does anyone know how to disconnect all these connections AutoCAD Count is finding to separate objects and reporting as errors that should be unrelated?
I had REALLY high hopes for the Count palette but the deeper I get the more it appears to be another great idea from Autodesk with a half way implementation so that it will be shelved and never used again.
