COULDN'T DRAW A STRIGHT LINE when i draw lines using angles
Message 1 of 9
COULDN'T DRAW A STRIGHT LINE when i draw lines using angles...it appears like wave lines..plz help me
Replies (8)
Message 2 of 9
cadffm
It's all okay, it's just your monitor (and graphic setting)..
Your monitor have "pixels", million dots in a array
You can turn ON your smooth line /aliasing feature
Command: GRAPHICSCONFIG
But the line data and program output is everytime the same.
Sebastian
Message 3 of 9
my autocad version is 2010. This command is not working.
Message 4 of 9
cadffm
a good information for the first post 😉
Right, this command came with version 2011
Press [F1], search for Manual Performance Tuning Dialog Box
and 3DCONFIG command
I don't have such a old version running today, so i can not help.
(but as i wrote: Nothing to do with your object data, it's just the screen display)
S
Sebastian
Message 5 of 9
LyleHardin
CADffm is right. Nothing to worry about. It's perfectly normal. The line is a mathematically perfect line in AutoCAD, it's just that the screen cannot display a perfect line with its rows and columns of pixels.
Message 6 of 9
cadffm
And the next topic in your Help[F1] Adaptive Degradation and Performance Tuning Dialog Box
There is the LINE ANTIALIASING,
HTH
Sebastian
Message 7 of 9
k thanks..I found that line antialiasing tool..I TURNED OFF/ON...still the same wave lines are coming when i draw line slightly angled...when I print the diagram same waves lines are there...
Message 8 of 9
cadffm
I guess you have a PRINTER and not a PLOTTER,
a printer printet step by step only dots too. (A Plotter "really" draw this line as line)
Perhaps you see that (we can not see your result because you didn't share a photo about the paper print)
So it could be 100% normal, it's impossible for us to say Yes or no with the informations we have..
Feel free to create a DWG with one single line,
set up your pagesetup well with Printer = "DWG To PDF.pc3"
save the pagesetup, print the page,
save the file
print PDF file to paper, make a scan or photo of paper
share DWG, PDF and your copy/photo with us.
Sebastian
Message 9 of 9
leeminardi
FYI, the waves you refer to are sometimes called "jaggies" or stair-stepping.   You can find more information here.  As noted, the solution is to get a higher resolution display and/or specify a higher resolution for your printer (increase the dpi - dots per inch).  Anti-aliasing can also be used. In effect it softens the corners of the stairs by averaging the intensity of the end pixels on each "step" thus blurring the image a bit.
lee.minardi
