When i type in single or 2 character commands (l,m,pl) I get an odd error where the last character is duplicated in the que. for instance, I type "l" SPACE the command line will show the following:
Command: l LINE
Specify first point: l <------ this "l" should not be here and prevents mouse input
polyline gives:
Command: pl PLINE
Specify start point: l <----- again the extra "l"
This error does not always occure but it's often enough to pose a significant disruption. other commands give a similar result (move, erase). I have turrned off autocomplete, autocorrect, dynamic input. with limited to no change. I have also unloaded all of my lsp files and addons. Problem is occuring on multiple computers and both 2014 and 2015.
Any ideas out there?
Pendean,
No, I am using the spacebar for enter (though using the enter key has the same effect).
No, I have dissabled "auto compleet" and "auto correct" as the delay caused by the search causes errors in processing commands.
I do use a KVM but I have tried with 3 different keyboards (wired) and I have bypassed the KVM and it has no effect (still have corrupt commands)
Did you try to reset your settings to default? This issue can be linked to a corrupted user profile, and the fact that the problem happens in different product versions can be related that the customer settings had been migrated fro one version to another.
Windows start button -> All programs -> Autodesk -> AutoCAD 2015 -> Reset Settings to default
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
I tried resetting the user profile, it did not fix the issue. If I log in as a different user then the problem is non existant, this isolates the problem too the computer user profile. As I don't want to delete my account on my workstation, The following is my solution:
logged in as a different user, started acad, quit
opened regedit
went to HK_Current_User\software
exported autodesk tree
logged in as my main user account
opened regedit
deleted the autodesk tree
imported the autodesk tree from other user (same machine)
Autocad is now working as expected 🙂
Thank you for the assistance.
