AutoCAD Forum
Correcting Scale from PDF Import
3 REPLIES 3
1959 Views, 3 Replies
I have imported a pdf drawing into AutoCAD 2018. The scale on the pdf is 3/32" = 1' - 0". When I check the measurement in AutoCAD it's off. I've been searching for a couple hours now and can't seem to get it right. I've tried changing the scale from to 10 and 1000. How do I correct the scale in AutoCAD? See attached currently with scale changed to 10 prior to import. Scale Incorrect.PNG
3 REPLIES 3
sthompson1021
sthompson1021
As long as you have a known dimension in your PDF, just use SCALE with the reference option.
cadffm
pendean
pendean
Community Legend
Community Legend
... or use ALIGN command with it scale option.
Do you have a known/for sure dimension? There is a good chance your PDF is not the correct scale either, print it to paper and measure it.
AutoCAD Inside the Factory
