corner cuts
corner cuts
corner cuts
im having a problem cutting out a corner in a 3d box
TheCADnoob
What have you tried that isnt working?
What are you trying to achieve?
CADnoob
john.vellek
Hi @crafter2u,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
Your question is a bit vague so I thought I would get the conversation started.  I made a quick video that shows a 3D box.  I use the Chamfer command (you can set a specific distance) to quickly cut the corner. I also show how you can use a line, extrude to give it height and then use it to slice off the corner. Another method might be to use another copy of the box, and place it so a SUBTRACT will create what you want. Let me know if I am close or if you are asking something else.
John Vellek
Hi, @Anonymous Thank you for sharing your problem with the community.
Use chamfer while you are sketching and 2nd method is using subtract method like draw the object and subtract from the corner and you will get the desired output.
If the above matter helps you get overcome your problem please accept it as the solution for your problem.
Bhavesh Raghwani
