Copy Paste Problem In Autocad
Vighnesh_sVSH9P
Observer Observer
Vighnesh_sVSH9P
Observer
Observer
I am using AutoCAD software on my system. In our block, we have a part code. When I click on it, the Enhanced Attribute Editor appears, where we can view the descriptions as well. However, when I copy the part code or description and paste it into an Excel file or AutoCAD, it appears as follows:
( {\rtf1\ansi\ansicpg65001\deff0\deflang16393{\fonttbl{\f0\fnil\fcharset0 Microsoft Sans Serif;}} \uc1\pard\f0\fs17{\rtf1\ansi\ansicpg65001\deff0\deflang16393{\fonttbl{\f0\fnil\fcharset0 Microsoft Sans Serif;}}} )
Kindly let me know the solution.
tramber
What about using the properties palette ? (CTRL+1)
When a block is selected and has attributes, the text should be accessible and copyable from the bottom of the palette.
Just to say about a fast alternative.
Could not simulate the issue.
Vighnesh_sVSH9P
Observer
Observer
Just I Re-installed autocad but it's showing same.
Vighnesh_sVSH9P
Observer
Observer
{\urtf1\ansi\ansicpg65001\deff0\deflang16393{\fonttbl{\f0\fnil\fcharset0 Microsoft Sans Serif;}}
\uc1\pard\f0\fs17 G08C352030-0109-SHLV} this one is coming
Vighnesh_sVSH9P
Observer
Observer
https://www.youtube.com/watch?v=sv9augFLr6U&list=LL&index=1
I found the solution; it's not an AutoCAD issue but a system settings issue.
Thank You for your support
