copy paste not working
why can not coy object dwg to dwg ( above dwg not working copy paste action?
Michiel.Valcke
did you use the COPYBASE command, or just CTRL+V ?
imadHabash
Salam Ahmad,
your files size are too big,i have never ever reach for these sizes.these sizes ahmad give us a sign that there is a big problems and unwanted data exist in this file.
So all what you have to do is PURGE (R) then AUDIT .
Command: -PURGE
Enter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/Orphaned data/All]:
Good Luck and i hope it's work well..Smiley Happy
Imad Habash
I used both commands but n anwser ..
*P* Save a tree. Don't print this e-mail unless it's really necessary
imadHabash
Try to follow ( Copy & Paste ) .... it may help.
Imad Habash
yes i did both command but it file size 34 mb to 24.8 mb only reduced.. is
there any other ways to reduce file size
I think file has some problem that is why cant copy paste also...... ?
piyush.parihar24
After opening the file first unlock all the layers. Remove unwanted layers and blocks then use purge all command once all purges out save the file and then copy paste.
Please mark this as the solution if it resolves your issue. Kudos gladly accepted. ⇘ .
