I have created a deployment of autocad 2017 using the provided "create a deployment" tool. I've added hotfix 2 and 3 to the deployment. When installing from an elevated command line using the "SCCM" command given in the SCCM Text file after creating the deployment, the install completes, and both hotfix 2 and 3 are installed successfully.
However, after promoting the source files into SCCM itself, and running the deployment via an advertisement within SCCM, the product installs, but NOT the Updates.
The phenomenon/bug can be re-created without using SCCM as well. By running the same successful command line in an elevated command prompt, but running as the "SYSTEM" account. The product itself installs, but not the updates.
This is the 2nd AutoCAD release in a row that has not worked for deploying updates via SCCM. Autocad 2016's issue was never fixed, and it appears a similar problem now exists for 2017.
FYI, easy to test this phenomenon using PSTOOLS, run "psexec.exe -i -s cmd" from an elevated command prompt to open a command prompt running as the "SYSTEM" account, then run the deployment setup command line from there. This duplicates the failed behavior that happens when SCCM launches the installer as the "SYSTEM" account on targeted computers.
Thanks for any help or suggestions, although I'm doubtful this will fixed by Autodesk, so I plan to convert the updates into "Additional Software" like the 2016 workaround posts suggested last year, instead of using the documented "Add Updates" feature that has been fundamentally broken for two product releases in a row.
