I often copy images from AutoCAD into Word. To do this I select the objects in AutoCAD, right click and copy them to the Clipboar. Then in Word I do a Paste Special - Picture (Windows Metafile). This works great in AutoCAD 2016 but when I copy the same image from AuotCAD 2017 the result is unacceptable. Centerlines copied from 2016 display well in Word; centerlines copied from 2017 display as continuous lines in Word. I have attached a PDF of an sample drawing pasted from AutoCAD 2016 and the same file opened and copied from AutoCAD 2017.
Solved by rickhiebert. Go to Solution.
Solved by tran.nguyen. Go to Solution.
Hello @rickhiebert,
We are aware of this issue and it is on our radar. In the meantime can you try the workaround of turning your hardware acceleration off?
If needed, here are instructions on how to do that:
Please let me know if this works for you. Thank you for your question.
