Hey everyone,
So I am working in AutoCAD 2013 and have a weird problem going on. I recently purchased a gaming mouse (Logitech G602) that has 6 buttons on the side, and two more on the left click that I can program to any key. I have never used keyboard shortcuts before so setting them up was a new task for my but I did it....ALMOST flawlessly. I have the shortcuts set for the F# keys and then my mouse buttons are linked to those F# keys respectfully.
So I have 1 button set for "MOVE" and 1 set for "COPY", and when I select the objects I want to move I hit that button and then I can select the base point, JUST like actually typing in the command. But when I hit the copy button with the SAME objects selected, it deselects the objects and tells me to select the objects again.
It does that with both the mouse button and the F key, but when I type in the command it works like it should, keeps the selection and then tells me to select the base point.
Any ideas on what I did wrong? Here are some screen shots I grabbed:
Solved by rkmcswain. Go to Solution.
I believe it did! but now i have another question..... I took that macro from the copy command itself?.....why does it work their but no the shortcut?
Well, those macros are essentially saying "if the objects are selected, then proceed with the command. If not then 'cancel' twice, and then proceed with the command from the beginning".
I can duplicate the problem in AutoCAD 2019. Not sure why it doesn't work. If you always want to copy pre-selected objects this way, you could replace the macro with this:
._copy;
So from what I'm understanding, there is an error in the autocad code that doesn't let that macro get used with keyboard shortcuts? It's just weird how the "MOVE" command works just fine but the "COPY" needs to be formatted different when both of them have the same macro apart from the end command.... that just doesn't seem right. but it's working correct now (I believe) so I just changed the "MOVE" macro on my shortcut to match (I'm OCD like that) and now they work just like typing the command.
still bugs me that they don't like the standard macro autodesk created though haha
You're misunderstanding something. There was no copying. I took the stock OOTB "copy" and "move" commands (already in the CUI) and added them to the keyboard shortcuts node. Then assigned an F key to each of them. It appears to be a bug, especially since OP says the same thing is happening as far back as r2013.
